  3. Node-RED
  4. "Sketch Config" (I_CONFIG) Handler
Scheduled Pinned Locked Moved Node-RED
3 Posts 2 Posters 2.2k Views 1 Watching
  • C Offline
    C Offline
    cranky
    This flow takes care of the challenge/response for when a sensor asks what config to use (Metric or imperial).
    By default, the code returns M for metric. I don't believe Imperial is used anywhere, but it can be changed to I... if you support it in your code. (Honestly, no clue, but some sketches do make use of the call getConfig() .)
    [{"id":"8e3e8f02.7fd0c","type":"mqtt-broker","z":"63842e72.893f78","broker":"localhost","port":"8883","clientid":"","usetls":false,"verifyservercert":true,"compatmode":true,"keepalive":"15","cleansession":true,"willTopic":"","willQos":"0","willRetain":null,"willPayload":"","birthTopic":"","birthQos":"0","birthRetain":null,"birthPayload":""},{"id":"57ad0c01.895c9c","type":"mqtt in","z":"63842e72.893f78","name":"Sensor Requests Config","topic":"MySensors/+/255/3/0/6","broker":"8e3e8f02.7fd0c","x":105,"y":993,"wires":[["cd60b38.ef7405"]]},{"id":"86a8016b.bd47a","type":"mqtt out","z":"63842e72.893f78","name":"","topic":"","qos":"","retain":"","broker":"8e3e8f02.7fd0c","x":672,"y":993,"wires":[]},{"id":"65a6cc53.392ccc","type":"function","z":"63842e72.893f78","name":"Metric/Imperial definition","func":"var config = \"M\" ; //M for metric, and I for imperial\n\nmsg.payload = config + \"\\n\";\nreturn msg;","outputs":1,"noerr":0,"x":488,"y":993,"wires":[["86a8016b.bd47a","165c11cd.40adbe"]]},{"id":"165c11cd.40adbe","type":"debug","z":"63842e72.893f78","name":"","active":true,"console":"false","complete":"false","x":692,"y":952,"wires":[]},{"id":"cd60b38.ef7405","type":"delay","z":"63842e72.893f78","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":295,"y":993,"wires":[["65a6cc53.392ccc"]]},{"id":"9687065f.28c08","type":"comment","z":"63842e72.893f78","name":"I_CONFIG handler ([0-255];255;3;0;6;[M or I])","info":"Whenever a sensor announces itself to the network as [any];255;3;0;6;(null),\n\nThe cntroller returns a M for metric or I for imperial. \nTo my understanding, imperial measurement reportings aren't used.\n\n\nA rate limiter was required as to keep NR and the sensor from a spam-loop","x":298,"y":1030,"wires":[]}]```
    barduinoB 1 Reply Last reply
    • C cranky
      barduinoB Offline
      barduinoB Offline
      barduino
      @cranky ,
      do you have a git repository where we can download all the stuff?
      • C Offline
        C Offline
        cranky
        Not yet, but that was my goal tomorrow.
        My GH account is https://github.com/jwcrawley
        It'll be obvious when I add in the repo :) I'll also mention it here.
        Sincerely,
        Cranky
        12.1k
