  3. Domoticz
  4. Error Sending switch command
57 Posts 11 Posters 34.6k Views 5 Watching
  • sundberg84S
    sundberg84S
    #40
    Change: gw.begin(incomingMessage, AUTO, true);
    To: gw.begin(incomingMessage, 3, true); (If you want 3 as node id)
    • H
      H
      hugo_pn
      Made a test (with the external antenna on Gateway) the other day and this is what happens.
      I put the nrf24 with the external antenna attached to the Nano and Upload the Serial Gateway Scetch onto it.
      Ran The Serial Monitor and get this
      I remove it from the PC, attach it to the Raspberry Pi I give two switch commands that work, then at the third attempt the message comes to life "Error sending switch command, check device/hardware !"
      2016-01-06 01:04:25.708 MySensors: Using serial port: /dev/ttyUSB0
      2016-01-06 01:04:27.186 MySensors: Gateway Ready...
      2016-01-06 01:04:27.262 MySensors: Gateway Version: 1.5
      2016-01-06 01:04:28.329 Hardware Monitor: Fetching data (System sensors)
      2016-01-06 01:04:56.024 User: admin initiated a switch command
      2016-01-06 01:04:58.436 Hardware Monitor: Fetching data (System sensors)
      2016-01-06 01:05:05.599 User: admin initiated a switch command
      2016-01-06 01:05:28.560 Hardware Monitor: Fetching data (System sensors)
      Back to PC this is what I get.
      0;0;3;0;9;radio init fail
      After a few minutes It's OK again like the beginning.
      • sundberg84S
        sundberg84S
        #42
        It (radio init fail) means that when you power it up (connecting it back to PC) it cant initialise radio.
        Mostly this is = check wires and/or power issues.
        Actions:
        Check wires, check wires and check wires :)
        Try powering your nano without the relay attached if possible (and see if you get Radio Init fails)
        If not - power your relay seperatly if possible (relay often create interferance with radio).
        H 1 Reply Last reply
        • sundberg84S sundberg84
          Actions:
          H
          H
          hugo_pn
          @sundberg84
          Thanks for the reply, the thing is that I'm powering the Nano via USB from the raspberry Pi (serial Gateway with the external antenna).
          The wires I don't think are the problem because it works with the integrated antenna.
          Can I power Up the Nano with the Raspbery Pi USB and a 5V Transformer with out burning everything?
          From what I remember, parallel tension doesn't sum up, but the current does. Wright?
          Will I damage everything, including the Raspberry?
          • sundberg84S
            sundberg84S
            Sorry i missunderstood you, you are talking about the gateway, not the node with the relay right?
            If so, you dont need to power it seperetaly....
            Start with checking your wires...
            • J
              J
              jloc
              Hello friends:
              Happens to me the same error " Error sending command switch , check device / hardware ! " when I update the device status from the application. HOWEVER from the device button it works well.
              I tested with serial GW (internal GPIO ) and GW LAN , with the same results.
              The traces of the device and the GW are:
              Device type: light node: 3 child: 6
              Command Msg GW Msg Device
              On button 3; 6; 1; 0; 2; 1; send 3-3-2-0 s=6,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
              read: 0-2-3 s=6,c=1,t=2,pt=2,l=2,sg=0:1
              This is an ack from gateway
              Incoming change for sensor:6 , New status: 1
              On Domoticz 3; 6; 1; 1; 2; 1; read: 0-2-3 s=6,c=1,t=2,pt=0,l=2,sg=0:1
              send 3-3-2-0 s=6,c=1,t=2,pt=0,l=2,sg=0,st=ok:1
              Off button 3; 6; 1; 0; 2; 0; send 3-3-2-0 s=6,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
              read: 0-2-3 s=6,c=1,t=2,pt=2,l=2,sg=0:0
              Incoming change for sensor:6 , New status: 0
              Off Domoticz 3; 6; 1; 1; 2; 0; read: 0-2-3 s=6,c=1,t=2,pt=0,l=2,sg=0:0
              send 3-3-2-0 s=6,c=1,t=2,pt=0,l=2,sg=0,st=ok:0
              A Someone comes up with an idea?
              • sundberg84S
                sundberg84S
                This might be useful: http://www.domoticz.com/forum/viewtopic.php?f=42&t=8910&p=61791&hilit=switch#p61791
                • N
                  N
                  NBM
                  I have solved the problem. I changes power supply and now it works.
                  Can someone recommend some power supply?
                  • N NBM
                    H
                    H
                    hugo_pn
                    @sundberg84 Thanks for the reply.
                    @NBM
                    That's great news for all of US with this issue. With how many Amp's are you feeding the Arduino now?
                    Regarding the power supply, as @sundberg84 has said " Here is a great discussion: http://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers"
                    Chears
                    • P
                      P
                      PostaanErik
                      I have similar issues with the Relay Actuator and Domoticz
                      I’m using MySensors 1.5, Serial gateway and domoticz on a windows machine.
                      Currently latest version: domoticz-win32-2_4078
                      Working with the standard provided arduino examples.
                      I cannot get Domoticz controlling the relay. The status is presented in domoticz when I use the RelayWithButtonActuator and press the button
                      Hardware is detected in Domoticz, devices are showing up (other devices like pressure/humidity are working fine).
                      I used multiple Arduino pro’s with different NRF’s + capacitator.
                      Disable Ack results in an error when trying to Switch via Domoticz
                      The serial output of the RelayWithButtonActuator looks like this:
                      send: 0-0-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.1
                      send: 0-0-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                      repeater started, id=0, parent=0, distance=0
                      send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=14,sg=0,st=ok:Relay & Button
                      send: 0-0-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                      send: 0-0-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                      When I press the button attached to the arduino:
                      Incoming change for sensor:1, New status: 0
                      send: 0-0-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
                      read: 0-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0:1
                      Incoming change for sensor:1, New status: 1
                      Any help or a working arduino Sketch would be appreciated.
                      Erik
                      • sundberg84S
                        sundberg84S
                        The logs look ok, doesnt the relay switch when you get this?
                        If not My guess its a power problem with the relay.
                        • P
                          P
                          PostaanErik
                          Yes it is switching, but initiated from the attached button
                          • sundberg84S
                            sundberg84S
                            #52
                            But not working from Domoticz and you get "Error sending command to switch" ?
                            Then nothing in the logs i guess when you try to initiate the command from Domoticz?
                            Its a trend here.. dont know if that is domoticz or MySensors but if you dont see anything in GW log trying to initiate the command from Domoticz I would ask this question in the Domoticz forum because then its a issue there.
                            • Cliff KarlssonC
                              Cliff KarlssonC
                              Cliff Karlsson
                              I am not very skilled at these things but I had the same problem for a long time and the only solution I found was to disable ack in domoticz.
                              select hardware in the hardware/devices tab find the mysensors gateway and click setup.
                              Try to find your node and deselect the ack box.
                              • P
                                P
                                PostaanErik
                                Thanks for the input, but this is not working for me :(
                                • P
                                  P
                                  PostaanErik
                                  Small Update: seems that everything "sending" from domoticz is not received at the nodes.
                                  When monitoring the serial from relay, dimmer, rgb....
                                  when i tick devices in domoticz, a sensor is just not receiving:
                                  send: 31-31-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
                                  send: 31-31-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                  sensor started, id=31, parent=0, distance=1
                                  send: 31-31-0-0 s=255,c=3,t=11,pt=0,l=14,sg=0,st=ok:Relay & Button
                                  send: 31-31-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                                  send: 31-31-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                  • H
                                    H
                                    hugo_pn
                                    wrote on last edited by hugo_pn
                                    #56
                                    Hi all,
                                    After trying several things, I decided to try a downgrade on Domoticz going back to Domoticz V2.2563.
                                    Seems to be flawless, Suddenly everything is working fine for the past 6 days.
                                    What do you make of this?
                                    • F
                                      F
                                      flopp
                                      I read this post yesterday and today I solved it.
                                      My GW was restarting as soon as I was sending a command to a MYS node with dimmer child.
                                      I am using nRF PA-LNA, with extra power supply, PA_HIGH. Domoticz 3.8795, MYS 2.1.1. Nano as serial GW.
                                      Tried PA_LOW, new nRF but that didn't help.
                                      Today I found the solution, I disabled DEBUG in GW and now I can't reproduce any restarts.
