  3. 2 channel relais with 2 buttons sending strange values for on:off
18 Posts 5 Posters 9.3k Views 2 Watching
  • AndurilA
    AndurilA
    Anduril
    @mfalkvidd thank you very much. I use a ESP as gateway and was following this thread, but must have missed that problem in the 200+ posts. I will try to use newest development branch and see if problem still exists.
    • AndurilA
      AndurilA
      Anduril
      ok tested that again, installed a fresh mysensors lib (stable master, downloaded 11.01.16) and first test ran fine. Relay gives 1 or 0 as status, worked even for hours.
      But after powering another node it starts again. Sad that I have no third one here at the moment to test if its a general problem with more than one node or specific to this one. I also reflashed the problematic node (with dht and switch), but nothing changed. Is it possible that a message from the DHT-node brings the ESP to a special mode/error state that makes it misinterprete 0 and 1 readings to 1107296257?
      • AndurilA
        AndurilA
        Anduril
        Did some further tests. As it seems to be related with the ESP gateway maybe @Yveaux has a hint for me.
        When starting the relay node it works fine, until the first message of the DHT node is received. After that it starts to get strange. I already tried to recompile all sketches with newest MS 1.5.1 and cleared all eeproms (except the gw, is that neccesary?)
        just for completeness the sketch of my DHT node. If someone finds something strange in there please let me know.
        #define CHILD_ID 3
        #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
        #define CHILD_ID_HUM 1
        #define CHILD_ID_TEMP 2
        #define HUMIDITY_SENSOR_DIGITAL_PIN 5
        unsigned long SLEEP_TIME = 1000; // Sleep time between reads of switch (in milliseconds)
        unsigned int debounce_nr = 10; // No of cycles doing button test
        unsigned int cycle_min = 10; // No of cycles min for DHT read
        unsigned int cycle_max = 60; // No of cycles max for DHT read (must be cycle_min*n)
        float Temp_dif =0.3; // change in Temp to trigger send
        float Hum_dif =3; // change in Hum to trigger send
        DHT dht;
        float lastTemp;
        float lastHum;
        boolean sendNow = true;
        Bounce debouncer = Bounce();
        int oldValue=-1;
        unsigned int debouncecycle=0;
        unsigned int cycle=0;
        unsigned int cycle_multiplier = 1;
        float temperature;
        float humidity;
          gw.begin();
          gw.sendSketchInfo("DHT with Switch", "1.0");
         // Setup the button
          pinMode(BUTTON_PIN,INPUT);
          // Activate internal pull-up
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
          gw.present(CHILD_ID, S_DOOR);
          delay(10);
          delay(10);
          debouncer.update();
          // Get the update value
          int value = debouncer.read();
          if (value != oldValue) {
             // Send in the new value
             oldValue = value;
          if (cycle >= cycle_min * cycle_multiplier) {
          cycle_multiplier=cycle_multiplier+1;
          temperature = dht.getTemperature();
          //Serial.print("Temp: ");
          //Serial.print(temperature);
          //Serial.print("LastTemp: ");
          //Serial.println(lastTemp);
          if (isnan(temperature)) {
          } else if ((temperature < lastTemp - Temp_dif) or (temperature > lastTemp + Temp_dif)) {
            sendNow=true;
            Serial.println("SendNow set by Temp");
          humidity = dht.getHumidity();
          //Serial.print("Hum: ");
          //Serial.print(humidity);
          //Serial.print("LastHum: ");
          //Serial.println(lastHum);
          if (isnan(humidity)) {
          } else if ((humidity < lastHum - Hum_dif) or (humidity > lastHum + Hum_dif)) {
              sendNow=true;
              Serial.println("SendNow set by Hum");
          if (cycle >= cycle_max){
            sendNow=true;
            Serial.println("SendNow set by cycle_max");
          if (debouncecycle>debounce_nr){
          debouncecycle=0;
          cycle=cycle+1;
          //Serial.print("Anzahl Zyklen: ");
          Serial.println(cycle);
          debouncecycle=debouncecycle+1;
          Serial.print(debouncecycle);
          if (sendNow){
            sendNow = false;
            cycle=0;
            cycle_multiplier=1;
            Serial.println("Zyklen zurueckgesetzt, Daten gesendet.");
            lastTemp = temperature;
            lastHum = humidity;
        • AndurilA Anduril
          #define CHILD_ID 3
          DHT dht;
          float lastTemp;
          float lastHum;
          int oldValue=-1;
          float temperature;
          float humidity;
            gw.begin();
           // Setup the button
            delay(10);
            delay(10);
            debouncer.update();
               oldValue = value;
              sendNow=true;
                sendNow=true;
              sendNow=true;
            debouncecycle=0;
            cycle=cycle+1;
            if (sendNow){
              sendNow = false;
              cycle=0;
              cycle_multiplier=1;
              lastHum = humidity;
          @Anduril is the second node running the same MySensors version as the other node and gateway?
          What Arduino core version are you using for ESP support?
          AndurilA 1 Reply Last reply
          • V
            V
            vampircik
            Used: C:\Users\vampircik\Documents\Arduino\libraries\Bounce2
            Not used: C:\arduino-1.6.3\libraries\Bounce2
            I tried to upload a sketch, an error says no such library
            • YveauxY Yveaux
              AndurilA
              AndurilA
              Anduril
              @Yveaux yeah I compiled all 2 nodes and the gw just yesterday with the same MySensors version. With Arduino core version you mean the version of Arduino IDE? 1.6.6
              Is it necessary/usefull/possible to do a eeprom reset on the gw?
              Btw sometimes MYSController does not recognice all presentation messages. Is that somehow a problem? I don't know why this happens as all my nrf are equiped with 4.7µF (node in question also tried with 2 caps).
              • mfalkviddM
                This is how to check esp core version http://forum.mysensors.org/topic/2708/soft-wdt-reset-on-esp8266/13
                • AndurilA
                  AndurilA
                  Anduril
                  • V
                    V
                    vampircik
                    these relays your sketch works well, but is not displayed correctly in the controller
                    http://ru.aliexpress.com/item/2-channel-New-2-channel-relay-module-relay-expansion-board-5V-low-level-triggered-2-way/1617727658.html
                    and with these relay failures. why is that? although "RelayWithButtonActuator" in truth it works with one group
                    http://ru.aliexpress.com/item/10PCS-LOT-New-original-solid-state-relay-G3MB-202P-DC-AC-PCB-SSR-In-5VDC-Out/32339505849.html
                    • AndurilA
                      AndurilA
                      Anduril
                      @vampircik I don't realy understand what you tried to say. At the moment I have no real relays connected but simply LEDs for testing purposes.
                      @Yveaux I updated the ESP8266 definitions to ver 2.0.0. But now I can't upload a sketch. I get this message:
                      warning: espcomm_sync failed
                      error: espcomm_open failed
                      Do you know what that means?
                      • AndurilA Anduril
                        Did you select the right target board & settings? They did make some changes there with 2.0.0
                        • AndurilA
                          AndurilA
                          Anduril
                          I just left them on standard as before...
                          just found one option named " reset mothode" which was ck and now I set it to nodemcu (only option that seems reasonable to me by it's name). Just worked to upload the sketch. I will do further tests and report back.
                          • AndurilA
                            AndurilA
                            Anduril
                            Still getting those strange numbers for relay status on or off. I will build another node to test this new constellation.
                            • AndurilA
                              AndurilA
                              Anduril
                              Now I tested with a third node the check. Also after node 3 sending data my 0 and 1 from the relay node become large numbers. One thing that seems strange to me is the behavior during reboot of the temp/hum node. First this node is active and sending temp and hum data. Readings from relay are strange as usual. When rebooting the relay signals turn to be 0 and 1 after the temp/hum node has presented itself to the gateway. But after sending the first data for temp/hum it is again receiving those large numbers. Does this make any sense for you @Yveaux?
                              • AndurilA
                                AndurilA
                                Anduril
                                I updated my gateway to newest dev version and now my nodes are communicating correctly (not updated, still 1.5.3). So the problem seems to be gone in 2.0, but I think it would still be nice to know what caused it for those not willing to upgrade to dev branch.
                                For @netram and @kr0815 (and maybe others) who had similiar problems: dev branch fixes this issue.
                                • N
                                  N
                                  netram
                                  Sweet! Thanks for the feedback @Anduril .
