  3. Hydroponics (Update 1/31) w/pics
16 Posts 4 Posters 11.1k Views 9 Watching
  • barduinoB
    barduinoB
    barduino
    wrote on last edited by barduino
    Hi Folks
    Here is a first update on this project.
    First some pictures of the hardware.
    (please ignore the dying plants, they are from another experiment)
    The plant fountain was 100% home designed and printed and I added a 5 gallon bucket, lid and pump inside. The electronics are not connected yet.
    And my development/test electronics
    Arduino, relay for the pump and an RTC module
    This will allow me to complete phase 1 which is basically running the pump for x minutes, stoping for y minutes during a time interval (e.g. 8am 6pm)
    This first pump module is obviously using MySensors and although I want it to work independently of a controller i'm using MySensor to report data and implement some commands.
    I've tried to do things with some architecture, using classes but C++ is still a bit of a mystery to me, so feedback is welcome as always.
    The current and planned architecture goes as follows:
    Hydro.ino Module
    • Main Module
    • Implements MySensors Library
    • Updates controller on data being monitored
    • Receives ad-hoc commands from controller (such as turn pump on) and sends them to the correct module
    //#define MY_REPEATER_FEATURE
    // Define Node ID
    #define MY_NODE_ID 7
    // INCLUDES //
    #include <Time.h>
    #include <DS1302RTC.h>  // A  DS3231/DS3232 library
    #include "HydroConfig.h"
    #include "MyPump.h"
    // Skecth name and version
    #define SKETCH_NAME "Hydro9"
    #define SKETCH_VERSION "v0.1"
    // Pin Assignments
    #define BUTTON_PIN  4  // Arduino Digital I/O pin number for button
    Bounce debouncer = Bounce();
    int oldValue = 0;
    unsigned long lastUpdate = 0;
    MyMessage msgPump(MY_PUMP_ID, V_STATUS);
    MyPump myPump(MY_PUMP_RELAY_PIN);
      // Setup the button
      pinMode(BUTTON_PIN, INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      myPump.rtc_init();
      // Request latest time from controller at startup
      requestTime();
      wait(2000);// Wait for time form controller
      Serial.print("Current time: ");
      Serial.println(myPump.currentDateTime().c_str());
      myPump.pumpCycleRun(1);
      myPump.pumpCycleStop(1);
    void presentation()  {
      present(MY_PUMP_ID, S_BINARY, "Pump");
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value == 0) {
        send(msgPump.set(myPump.pumpSwitch()), false);
      oldValue = value;
      if(myPump.pumpCheck())
        send(msgPump.set(myPump.isOn()), false);
      if (message.isAck()) {
        // Change relay state
        if (message.getBool())
          myPump.pumpOn();
          myPump.pumpOff();
      myPump.rtc_set(controllerTime);
    MyPump Module:
    • Handles all pump related features
    • Turn pump on/off
    • Check cycle to verify if pump should be on or off
    • X min On, Y min Off Cycle
    • Run Cycle from start time to end time (e.g. 8:00 to 18:00)
    • Run Cycle based on light of day (TBI)
    • Select Normal vs Circulate water (TBI) - Using solenoid valves to direct the water between the plant fountain and the bucket
    Here is the pump running at 1 minute on, 1 minute off cycle
    Starting sensor (RNNNA-, 1.6.0-beta)
    Radio init successful.
    RTC module activated
    RTC Sync TieStatus: 2 timeSet 2 Ok!
    send: 7-7-0-0 s=255,c=3,t=1,pt=0,l=0,sg=0,st=ok:
    Current time: 2015/12/12 16:28:55
    send: 7-7-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:1.6.0-beta
    send: 7-7-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    send: 7-7-0-0 s=255,c=3,t=11,pt=0,l=6,sg=0,st=ok:Hydro9
    send: 7-7-0-0 s=255,c=3,t=12,pt=0,l=4,sg=0,st=ok:v0.1
    send: 7-7-0-0 s=1,c=0,t=3,pt=0,l=4,sg=0,st=ok:Pump
    Init complete, id=7, parent=0, distance=1
    2015/12/12 16:29:52 PUMP ON
    send: 7-7-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
    2015/12/12 16:30:52  PUMP OFF
    send: 7-7-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
    2015/12/12 16:31:52 PUMP ON
    2015/12/12 16:32:52  PUMP OFF
    2015/12/12 16:33:52 PUMP ON
    2015/12/12 16:34:53  PUMP OFF
    2015/12/12 16:35:52 PUMP ON
    Again, feedback is welcome
      Samuel235
      I'm very interested in doing something along these lines in the near future. I may be jumping back in here if i do, then we could develop something together that may bring others into the world of MySensors.
      MySensors 2.1.1
      • barduinoB
        barduinoB
        barduino
        Hi Folks
        I got a question for the community.
        There is no Hydroponics dedicated sensor id in MySensors Lib and probably the same with the controllers out there.
        What would be better:
        • Have a V_CUSTOM sensor with multiple messages inside?
        • Have multiple standard sensors with single type messages inside?
        So for now what I need to report and manage is:
        • Is pump Running (V_STATUS)
        • Pump mode Off, Normal, Schedule, Daylight (V_SCENE)?
        • Minutes run/stop cycle (V_LEVEL)?
        • Start/End time for timer schedule (V_LEVEL)?
        • Light level for Daylight schedule (V_LEVEL)?
        • Pump Switch (V_STATUS)?
        So far I'm using...
        MyMessage msgLight(MY_PUMP_ID, V_LEVEL);
        MyMessage msgTime(MY_PUMP_ID,V_VAR1);
        upload-b0574f70-2359-4849-8f32-a3c6dae29b6c
        • barduinoB
          barduinoB
          barduino
          Hi folks,
          Quick update on my progress.
          I was wondering how other controllers could handle this situation.
          If anyone has some input I would appreciate the feedback.
          Here is how I split the nodes and messages.
          upload-9787f916-e061-497e-8fa6-f2138fc0ab58
          upload-3ae87651-8ac8-4d2f-b170-32844c86e61c
          upload-3d0617aa-9af5-4153-a21c-c3995deb6b7e
          Had to combine V_LEVEL with other messages such as V_VOLUME in order to have 2 similar messages on the same sensor.
          I wonder if "normal"controllers just treat one message one sensor?
            Samuel235
            I'm not sure how your have your 'home page' configured with this data but i personally would love to have 1 single panel for this on the home page of the home automation controller/display showing the vitals (temp, pump on, light on, etc) then have it as a grouped page so you click onto it and it then displays all of this data like you have posted above as a separate control page for fine tuning.
            I know this is how i would have it set up in my OpenHAB system however, I have never used Vera before so I'm not sure if you can have/configure group pages like this. Either way, I love the look of this and like i mentioned before, i will be looking to do something along these lines in 2016 hopefully. Just waiting on the price of EC Probes to come down to a reasonable price and availability.
            Awesome project dude, keep up the good work!
            MySensors 2.1.1
            barduinoB 1 Reply Last reply
            • S Samuel235
              barduinoB
              barduinoB
              barduino
              Hi @samuel235
              I guess i've tried to re-invent the wheel.
              What you see is a controller developed by me. Each "card"represents a sensor with messages inside, as long as they are of different type. This seems to be a design flaw, I've made it too flexible and UI wise is a nightmare.
              They are grouped by nodes.
              The image I've posted is from a phone for factor. It looks like this on anormal screen:
              upload-15dbb14c-e1cd-4640-85a6-fc0ef67f9236
              After this experiment, one sensor one message seems to be the way to go.
              I'm also starting to experiment with openHab
              S 1 Reply Last reply
              • barduinoB barduino
                Hi @samuel235
                Samuel235
                @barduino Is this connected to the same controller as the rest of your automation system? Or do you run a separate controller (vera) specifically for your hydroponic setup?
                MySensors 2.1.1
                • barduinoB
                  barduinoB
                  barduino
                  Hi Folks,
                  Another update on this project
                  I've finally finished with the software. Added a DHT22 for air temperature and humidity and also a Dallas for the water temperature.
                  Assembling the hardware was a bit more challenging then anticipated, but with no PCB, i've decided to use a proto shield and maintain support/flexibility for both UNO and MEGA boards. Soon after I've realized the code does not fit a UNO (too much debug eventually)
                  Also created a simple case to enclose it all.
                  The Column it self
                  If anyone would likr to take a look at the code, feed back is much appreciated!
                  Hydro9.zip
                  Finally the dashboard looks like this
                  0_1454265720134_upload-dbcd7b52-42f2-44ca-9290-b00e74d38e00
                  EDIT: Forgot to add the startup log
                  Initializing DHT... Done!
                  Dallas Temperature IC Control Library Demo
                  Locating devices...Found 1 devices.
                  Parasite power is: OFF
                  Device 0 Address: 2817611D070000C3
                  Device 0 Resolution: 9
                  The DS1302 is write protected. This normal.
                  read: 0-0-7 s=255,c=3,t=1,pt=0,l=10,sg=0:1454110229
                  Time value received: 1454110229
                  Pump Time:2016/01/29 23:30:28
                  send: 7-7-0-0 s=255,c=3,t=15,pt=1,l=1,sg=0,st=ok:0
                  read: 0-0-7 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  Starting presentation
                  send: 7-7-0-0 s=1,c=0,t=3,pt=0,l=11,sg=0,st=ok:Pump Switch
                  send: 7-7-0-0 s=2,c=0,t=23,pt=0,l=10,sg=0,st=ok:Pump Cycle
                  send: 7-7-0-0 s=3,c=0,t=25,pt=0,l=9,sg=0,st=ok:Pump Mode
                  send: 7-7-0-0 s=4,c=0,t=23,pt=0,l=14,sg=0,st=ok:Pump Scheduler
                  send: 7-7-0-0 s=5,c=0,t=23,pt=0,l=13,sg=0,st=ok:Pump Daylight
                  send: 7-7-0-0 s=6,c=0,t=6,pt=0,l=10,sg=0,st=ok:Air Sensor
                  send: 7-7-0-0 s=7,c=0,t=6,pt=0,l=12,sg=0,st=ok:Water Sensor
                  send: 7-7-0-0 s=10,c=0,t=23,pt=0,l=9,sg=0,st=ok:Pump Time
                  End presentation
                  **************** PUMP STATUS ***********************
                  Pump Mode is:  Daylight
                  Pump Cycle:    On:15 Off:15
                  Pump Schedule: Start:07:33 Stop:17:30
                  Pump Daylight: Start:70 Current:59
                  Pump Time:     2016/01/29 23:30:34
                  ************* ENVIRONMENT STATUS *******************
                  Air temperature:10.60 Air humidity:37.90
                  Water temperature:10.00
                  send: 7-7-0-0 s=1,c=1,t=2,pt=1,l=1,sg=0,st=ok:0
                  send: 7-7-0-0 s=3,c=1,t=19,pt=2,l=2,sg=0,st=ok:3
                  send: 7-7-0-0 s=4,c=1,t=24,pt=0,l=5,sg=0,st=ok:07:33
                  send: 7-7-0-0 s=4,c=1,t=25,pt=0,l=5,sg=0,st=ok:17:30
                  send: 7-7-0-0 s=5,c=1,t=37,pt=2,l=2,sg=0,st=ok:70
                  send: 7-7-0-0 s=5,c=1,t=35,pt=2,l=2,sg=0,st=ok:59
                  send: 7-7-0-0 s=2,c=1,t=37,pt=2,l=2,sg=0,st=ok:15
                  send: 7-7-0-0 s=2,c=1,t=35,pt=2,l=2,sg=0,st=ok:15
                  send: 7-7-0-0 s=10,c=1,t=24,pt=0,l=20,sg=0,st=ok:2016/01/29 23:30:34
                  send: 7-7-0-0 s=6,c=1,t=0,pt=7,l=5,sg=0,st=ok:10.6
                  send: 7-7-0-0 s=6,c=1,t=1,pt=7,l=5,sg=0,st=ok:37.9
                  send: 7-7-0-0 s=7,c=1,t=0,pt=7,l=5,sg=0,st=ok:10.0
                  2016/01/29 23:30:34 Light level: 59
                    Hi Folks,
                    The Column it self
                    Hydro9.zip
                    End presentation
                    Samuel235
                    @barduino - Fantastic! I absolutely love this project of yours dude. Keep it evolving over time, make some upgrades and mods and you will be on to even more of a winner. The first thing i would advise as Revision/Version 2 would be to get that all put onto PCB's, get the footprint of the electronics small as you can, have it so the power comes into a connector on the side of the box rather than a cable running in. Then, I'd get those electronics inside of the column itself. either in the base or the top would be the obvious place to go for. Please don't stop here, its functional now, but make it a 'whole package' and you will be loved by thousands! Well, if you can class me as thousands that is.
                    Seriously good work though. I'm now expecting you to show us a video of everything working and integrated ;)
                    MySensors 2.1.1
                    • S Samuel235
                      barduinoB
                      barduinoB
                      barduino
                      @samuel235
                      Thanks for your enthusiastic support!!! :smiley:
                      The reason for the big power supply is that I intend to have 2 solenoid valves to control the water flow, one to send water to the column the other to recirculate the water in the bucket (needed when adding nutrients or adjusting the PH). Those run on 12v and can consume some amps.
                      The next step would be to add a water level sensor, I'll fry the pump if the water level drops to low.
                      The most difficult parts to get are the PH sensor and the TPM/TDS sensor, not only expensive but most of then are not designed to be permanently submerged.
                      In the long run I'm also planning for 3 peristaltic pumps to send nutrients, acidic solution and base solution to adjust PH and nutrients level. These often run on 12v.
                      The idea of getting the electronics on the column is quite interesting. It would have to be on top since the rest of the column is not water tight. I would need to find some clever way to deal with the cables.
                      Any way, I've just finished adding the plants. Not the ideal time to plant anything (its winter here) but the frost is gone and they say lettuce goes well with cold temperatures.
                      This is what it looks like week 0. We'll see how it goes.
                      S DwaltD 2 Replies Last reply
                        @samuel235
                        Samuel235
                        @barduino - No need to explain anything about hydroponics to me, I sent myself insane with researching it in the hope to do something like this. But like you also mentioned, the cost of the PH and nutrient sensors was just too much for me right now, i can't justify that in my current situation, which is why i'm passionate and enjoying your project :)
                        MySensors 2.1.1
                          @samuel235
                          DwaltD
                          DwaltD
                          Dwalt
                          @barduino I stumbled across this project a year or so ago while researching something similar to your project. There are some good resources there. I never got around to following up on it but your project is tempting me...mixing water with electronics, what's not to love.
