  3. Humidity Sketch w/ DHT22: readings not reliable
10 Posts 5 Posters 5.6k Views 4 Watching
  • H Offline
    H Offline
    HenryWhite
    wrote on last edited by HenryWhite
    Hi!
    When using the official temperature/humidity sketch with a 10k resistor between data and 3.3V VCC, the readings are not stable; I have lots of
    "Failed reading temperature from DHT"
    "Failed reading humidity from DHT"
    It seems that the temperature reading is successfull only every 4-5th time, while the humidity reading works every 1-2nd time.
    I'm using an 8mhz arduino pro mini 3.3V.
    Any ideas why this happens? Could a capacitor solve this problem?
    • S Offline
      maybe add gw.wait before your reading so it has enough time to sense...
      • barduinoB Offline
        barduinoB Offline
        barduino
        Something like this
            Serial.print("Initializing DHT... ");
            DHT _dht;
            _dht.setup(DHT_PIN);
            delay(_dht.getMinimumSamplingPeriod());
            Serial.println("Done!");
        Or check the example here
        • H Offline
          H Offline
          HenryWhite
          guys, as written above, i'm already using the official temperature/humidity sketch.. :smiley:
          So there is a
          gw.wait(dht.getMinimumSamplingPeriod());
          before the reading.
          I tried to increase this period to static 2,5 seconds (default interval should be 2s according to datasheet), but sadly that didn't help.
          Here's what the serial monitor shows (strange, isn't it?):
          • barduinoB Offline
            barduinoB Offline
            barduino
            Ok, lets see if I can replicate your situation
            Would you post the sketch and the log form serial?
            H 1 Reply Last reply
            • barduinoB barduino
              H Offline
              H Offline
              HenryWhite
              for the serial output, see above :)
              default sketch:
               * Version 1.0 - Henrik EKblad
               * This sketch provides an example how to implement a humidity/temperature
               * sensor using DHT11/DHT-22
              #define CHILD_ID_HUM 0
              #define CHILD_ID_TEMP 1
              unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
              DHT dht;
              float lastTemp;
              float lastHum;
              boolean metric = true;
              int node_id = 22;
                gw.begin();
                gw.sendSketchInfo("Humidity", "1.0");
                if (isnan(temperature)) {
                  lastTemp = temperature;
                  if (!metric) {
                  Serial.print("T: ");
                if (isnan(humidity)) {
                    lastHum = humidity;
                    Serial.print("H: ");
                    Serial.println(humidity);
              • L Offline
                L Offline
                lxz
                wrote on last edited by lxz
                I have the same. For the temperature I always thought that there's less variation in values.
                Did you try removing the if (temperature != lastTemp) from the sketch to see if more values are registered?
                • A Offline
                  A Offline
                  AWI
                  I can confirm that 3.3v in combination with some DHT22 sensors is not a stable solution. I switched to si7021/ sht21 completely (more reliable/ lower consumption/ etc.). other experiences
                  • L lxz
                    H Offline
                    H Offline
                    HenryWhite
                    well, i just realised that, goddammit :smile:
                    Since only every 10th reading or so is a failure, i can live with that I think.
                    thanks for the hint. I think I will switch to the si7021 in my pcb design, it seems to be almost the same price as the dht22.
                    Another solution would be to power the DHT22 directly with 3.7V from my Lithium Battery instead the 3.3V from arduino's VCC.
                    • S Offline
                      yes, and with si7021 there is no delay, faster readings, i2c better, low power. I like it too :)
