  3. how to query domoticz's security panel
9 Posts 4 Posters 5.9k Views 3 Watching
    MikaelK
    wrote on last edited by MikaelK
    Is there a way to retrieve domoticz's security panel's status ? It would be nice for example to activate motion sensors only when it's "armed away".
    edit for clarification : I'd like to retrieve domoticz"s security status from the sensor node by polling the gateway every now and then.
    Regards,
    Mikael
    • F
      F
      flopp
      Maybe this can do the job?
      http://www.domoticz.com/wiki/Domoticz_API/JSON_URL's#Retrieve_status_of_specific_device
        MikaelK
        Thanks, and sorry, my question was not clear enough : I would like to retrieve this information from the sensor node, in order to only activate the motion detection and message transmission when domoticz's security is "armed away".
        Regards
        Mikael
        • sundberg84S
          sundberg84S
          I use lua:
          if (devicechanged['Motiondetector'] == 'On' and otherdevices['Security Panel'] == 'Arm Away') then
          S 1 Reply Last reply
          • sundberg84S sundberg84
            I use lua:
            stress nero
            @sundberg84 said in how to query domoticz's security panel:
            I use lua:
            is there a way to put the motion sensor in bypassed mode or does it have to be a combination of the security panel being armed. I have a vera controller and there is a button to arm and bypass when in bypassed i get no alerts, how can that be done in domticz.
            • S stress nero
              I use lua:
              sundberg84S
              sundberg84S
              @stress-nero i do it with Lua code.
                stress nero
                @sundberg84 can you give me an example, and with lua will you be able to have a button that can toggle the armed and bypassed states.
                • S stress nero
                  sundberg84S
                  sundberg84S
                  @stress-nero - Yes - there is both a button and a security panel in Domoticz GUI you can use to set alarm mode. Also yes, I combine different states to be able to set the motion sensors in bypassed mode. There are two modes Arm home or Arm away. When I have arm home only my outer motion detectors are active (or they are active all the time, but only notify)
                  (Home is a variable set by the current status of the security device.
                  -- If away - start alarm/watch
                  if (Home == 'Away' and uservariables["var_alarm"] < 2) then
                  	--Start motion detection
                  	os.execute("bash /home/pi/domoticz/scripts/lua/startmotion.sh")
                  	--Set status
                  	commandArray['Inbrottsalarm'] = 'Arm Away'
                          commandArray['Variable:var_alarm']='2'
                  	commandArray['Group:Taklampor']='Off'
                  	commandArray['Group:Brytare Inne']='Off'
                  	commandArray['WW sovlampa'] = 'Off'
                  	--Log
                  	commandArray['SendNotification']='Alarm Status#Away = Alarm armed#-2'
                  	print('Activating alarm and motiondetection')
                  end
                    stress nero
                    thank for the input
