  3. Connecting the relay
11 Posts 4 Posters 6.4k Views 3 Watching
  • sundberg84S
    sundberg84S
    Hi!
    There are many threads about power and relays in the forum - I have had relays you need to connect ground through the arduino before it works. Try that (ie take your not workig schematics but move ground to arduino and see what happens).
    • V
      V
      vil1driver
      wrote on last edited by vil1driver
      • sundberg84S sundberg84
        Hi!
        moskovskiy82
        @sundberg84
        Nope. Connected GND to arduino leaveing external VCC. Same result
        • sundberg84S
          sundberg84S
          @moskovskiy82 Ok, next i would try to change power supply and se what happens.
            moskovskiy82
            Done. Took another powersupply )which can only go 4,5 or 6V but at true 2Amps output. Same thing.
              moskovskiy82
              The problem as i can see it doesn't go to off properly. Going to on state is fine.
              • M moskovskiy82
                I have a project with 4 relays and several sensors. I was wondering how to connect all this.
                As the picture below shows that connecting the relays to the same power supply as arduino is not working. Relay doesn't get disconnected or connected. Only the led lights up or dims a little bit. And feeding all of them through arduino is above its current limit on 5V pin...
                rvendrameR
                rvendrameR
                rvendrame
                @moskovskiy82
                The 5V and VIN pins are not the same thing, per original arduino nano schematics.
                Usually the relay "click" generates some noise on the power lines, which may disturb ( = freeze, hang) arduino and/or nRF radio.
                Maybe once you connect it through the 5V, the regulator is reducing that noise? You might try to add capacitors between relay's VIN and GND, 47uF could be a starting point.
                ESP8266 GW + mySensors 2.3.2
                Alexa / Google Home
                M 2 Replies Last reply
                • rvendrameR rvendrame
                  @moskovskiy82
                  moskovskiy82
                  @rvendrame
                  Well yes. I understand that Vin passes everything through the voltage regulator. This is why i am surprised that the relay works while being fed throught the 5V pin of the arduino and doesn't work when connected directly to a 5V supply.
                    @moskovskiy82
                    moskovskiy82
                    @rvendrame
                    Thank you!!!! The scheme solved it all!
                    Connecting 5V t6 Vin resulted on voltage drop. So the D1-D13 pins produced less than 5V which was not enough for the in pin
                    rvendrameR 1 Reply Last reply
                    • M moskovskiy82
                      @rvendrame
                      rvendrameR
                      rvendrameR
                      rvendrame
                      @moskovskiy82 , it makes sense. Glad you ruled it out!
                      Alexa / Google Home
