  3. Yet another PCB to address (nearly) all Arduino pins
26 Posts 6 Posters 12.6k Views 9 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    Does the layout survive a design rule check ?
    The pads of the 1.27" pinheaders seem very close to each other.
    • P
      P
      phil83
      Hey guys,
      many thanks so far, I will incorporate TD's ideas tomorrow.
      For the A7, many thanks to Gert! Only A0-A5 can be used as digital pins so I will change this!
      Design rule check was fine.
      Thanks again and have a nice evening,
      Philipp
      • P
        P
        phil83
        So this could be an updates pin assignment:
        Arduino Pin/ Function/ Pinhead
        0/ RXI/ not used
        1/ TXO/ not used
        2/ D2/ NRF24 / Pinhead 1 / Button (via jumper)
        3/ D3/ Pinhead 1
        4/ D4/ Pinhead 2
        5/ D5/ Pinhead ISP
        6/ D6/ LED
        7/ D7/ LED
        8/ D8/ 25AA256
        9/ D9/ NRF24
        10/ D10/ NRF24
        11/ MOSI/ Pinhead ISP
        12/ MISO/ Pinhead ISP
        13/ SCK/ Pinhead ISP
        A0/ A0/ Voltage divider
        A1/ A1/ Dallas 18B20
        A2/ A2/ Pinhead 2
        A3/ A3/ Pinhead ISP
        A4/ SDA/ Pinhead I2C
        A5/ SCL/ Pinhead I2C
        A6/ A6/ Pinhead 2
        A7/ A7/ Pinhead 1
        What do you think?
        Best regards,
        Philipp
        • tbowmoT
          tbowmoT
          tbowmo
          like @mfalkvidd asked.. Have you seen the MYSX connector? A "standardized" connector for mysensors platform..
          https://github.com/mysensors-kicad/documentation/blob/master/TheMYSXconnector.pdf
          • P
            P
            phil83
            Regarding the MYSX connector, I have seen the specification before but for me the 2.54mm pinheads are way to big since I wanted to have a really small board that I can also use for quite small sensors (window open for example). I changed some connections and came up with that scheme now:
            I added the caps for the ICs, many thanks again for the hint!
            Philipp
            • P
              P
              phil83
              Hi there,
              I had some more time to work on it and I rearranged the parts on the board. One question for me is how big to make the drill holes for mounting? Is 2mm ok?
              I will clean up the silk screen writings the weekend and then send it out to China :-)
              Many thanks so far,
              best regards,
              Philipp
              • TD22057T
                TD22057T
                TD22057
                You can find Eagle parts for M2, M2.5, M3 drill holes with tight and loose clearance in my Eagle parts library. I created the parts from this blog page.
                • P
                  P
                  phil83
                  Hi TD,
                  many thanks for the library, I incorporated the drill holes and it looks much better now!
                  Best regards,
                  Philipp
                  V GertSandersG 2 Replies Last reply
                  • P phil83
                    Hi TD,
                    Best regards,
                    Philipp
                    V
                    V
                    vikasjee
                    @phil83 said:
                    Hi TD,
                    Best regards,
                    Philipp
                    HI Philipp,
                    Will you like to share your files with this final version of your PCB? This is an excellent stuff. Appreciate your design skills...
                    • P phil83
                      Hi TD,
                      Best regards,
                      Philipp
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @phil83 If small is the target, use the SMD version of the NRF24L01+. Here is a small NRF24 library.
                      0_1456596545540_NRF24L01plus.lbr
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @phil83
                        Nice board, but still would suggest MYSX.. It's got different variants, with more / less pins available..
                        I'm playing around with a boardlayout that's 18x30mm, with MYSX connector, and nrf24 (SMD) the NRF will protrude over one end of the board with ~5-7mm (Antenna area). so total length will be 18x37mm (or something in that area).
                        • TD22057T
                          TD22057T
                          TD22057
                          One more tip: If you want to order a full 10x10 cm board, you can panelize them yourself and use https://github.com/p12tic/eagle-brd-merge to get around the 10x8 limit in the free version of Eagle. Worked great for my mother/daughter board order.
                          • P
                            P
                            phil83
                            Hi all,
                            many thanks for all the valuable input!
                            I will share my files after having tested the board by myself for the first time!
                            @GertSanders: I've never thought about using the SMD version of NRF24L01, it really looks interesting!
                            @tbowmo: Your board size is really impressive, are you also using the EEPROM and ATSHA on that small size board?
                            The smallest and still (hopefully) manufacturable for me seems to be around 44x21mm...
                            Right now I'm waiting for all of the parts of my reflow oven, I have some boards for testing here and in case I'm successful with reflowing, I will order new boards in China.
                            Best regards,
                            Philipp
                            • P
                              P
                              phil83
                              @TD22057: My dealer in China does some panelization for me as well, last time I ordered 20 board (size about 25x45mm) and I received 42... That was more than fine for me. But thanks for the link!
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @phil83
                                It's complete with external flash (for OTA), atsha204, voltage regulator, 2 led's and a Si7021. Using 0603 smd components though.. (And it only got components on one side..)
                                Still working on some details, before publishing it though...
                                • P
                                  P
                                  phil83
                                  @tbowmo: Sounds very impressive, chapeau! I'm looking forward to seeing your design when it is finished!
                                  • GertSandersG
                                    GertSandersG
                                    GertSanders
                                    @tbowmo I have been working on a similar board. The matter of external connections for switches and external sensors keeps me busy. The 1,27 mm spaced headers seem like a possible solution. But I have not found any female headers with wires (Dupont style) to go with the male versions. How do you solve the connection problem ?
                                    • P
                                      P
                                      phil83
                                      @GertSanders: On aliexpress you can find sets of male and female 1.25mm connectors, do you think about something like that:
                                      http://de.aliexpress.com/item/20sets-Micro-1-25mm-5pin-Cable-JST-1-25-5-Pin-Male-Female-Connector-plug-with/32464250609.html?spm=2114.010208.3.2.BMcTZF&ws_ab_test=searchweb201556_9,searchweb201644_5_505_506_503_504_301_10020_502_10001_10002_10017_10010_10005_10006_10011_10003_10021_10004_10022_10009_10008_10018_10019,searchweb201560_2,searchweb1451318400_-1,searchweb1451318411_6448&btsid=8ded8c25-db33-49ed-835b-307cb83c0f47
                                      • P
                                        P
                                        phil83
                                        As I read your post again, you mean something like this:
                                        http://de.aliexpress.com/item/5-sets-Double-Row-Female-Socket-SMD-2-10-20pin-1-27mm-Pin-Header-connector/32542921161.html?isOrigTitle=true
                                        • P phil83
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @phil83 the micro connector set with the wires is a very good suggestion. I will look around some more.
