  3. Yet another PCB to address (nearly) all Arduino pins
26 Posts 6 Posters 12.6k Views 9 Watching
  • P
    P
    phil83
    Hi TD,
    many thanks for the library, I incorporated the drill holes and it looks much better now!
    Best regards,
    Philipp
    V GertSandersG 2 Replies Last reply
    • P phil83
      Hi TD,
      Best regards,
      Philipp
      V
      V
      vikasjee
      @phil83 said:
      Hi TD,
      Best regards,
      Philipp
      HI Philipp,
      Will you like to share your files with this final version of your PCB? This is an excellent stuff. Appreciate your design skills...
      • P phil83
        Hi TD,
        Best regards,
        Philipp
        GertSandersG
        GertSandersG
        GertSanders
        @phil83 If small is the target, use the SMD version of the NRF24L01+. Here is a small NRF24 library.
        0_1456596545540_NRF24L01plus.lbr
        • tbowmoT
          tbowmoT
          tbowmo
          @phil83
          Nice board, but still would suggest MYSX.. It's got different variants, with more / less pins available..
          I'm playing around with a boardlayout that's 18x30mm, with MYSX connector, and nrf24 (SMD) the NRF will protrude over one end of the board with ~5-7mm (Antenna area). so total length will be 18x37mm (or something in that area).
          • TD22057T
            TD22057T
            TD22057
            One more tip: If you want to order a full 10x10 cm board, you can panelize them yourself and use https://github.com/p12tic/eagle-brd-merge to get around the 10x8 limit in the free version of Eagle. Worked great for my mother/daughter board order.
            • P
              P
              phil83
              Hi all,
              many thanks for all the valuable input!
              I will share my files after having tested the board by myself for the first time!
              @GertSanders: I've never thought about using the SMD version of NRF24L01, it really looks interesting!
              @tbowmo: Your board size is really impressive, are you also using the EEPROM and ATSHA on that small size board?
              The smallest and still (hopefully) manufacturable for me seems to be around 44x21mm...
              Right now I'm waiting for all of the parts of my reflow oven, I have some boards for testing here and in case I'm successful with reflowing, I will order new boards in China.
              Best regards,
              Philipp
              • P
                P
                phil83
                @TD22057: My dealer in China does some panelization for me as well, last time I ordered 20 board (size about 25x45mm) and I received 42... That was more than fine for me. But thanks for the link!
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @phil83
                  It's complete with external flash (for OTA), atsha204, voltage regulator, 2 led's and a Si7021. Using 0603 smd components though.. (And it only got components on one side..)
                  Still working on some details, before publishing it though...
                  • P
                    P
                    phil83
                    @tbowmo: Sounds very impressive, chapeau! I'm looking forward to seeing your design when it is finished!
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      @tbowmo I have been working on a similar board. The matter of external connections for switches and external sensors keeps me busy. The 1,27 mm spaced headers seem like a possible solution. But I have not found any female headers with wires (Dupont style) to go with the male versions. How do you solve the connection problem ?
                      • P
                        P
                        phil83
                        @GertSanders: On aliexpress you can find sets of male and female 1.25mm connectors, do you think about something like that:
                        http://de.aliexpress.com/item/20sets-Micro-1-25mm-5pin-Cable-JST-1-25-5-Pin-Male-Female-Connector-plug-with/32464250609.html?spm=2114.010208.3.2.BMcTZF&ws_ab_test=searchweb201556_9,searchweb201644_5_505_506_503_504_301_10020_502_10001_10002_10017_10010_10005_10006_10011_10003_10021_10004_10022_10009_10008_10018_10019,searchweb201560_2,searchweb1451318400_-1,searchweb1451318411_6448&btsid=8ded8c25-db33-49ed-835b-307cb83c0f47
                        • P
                          P
                          phil83
                          As I read your post again, you mean something like this:
                          http://de.aliexpress.com/item/5-sets-Double-Row-Female-Socket-SMD-2-10-20pin-1-27mm-Pin-Header-connector/32542921161.html?isOrigTitle=true
                          • P phil83
                            GertSandersG
                            GertSandersG
                            GertSanders
                            @phil83 the micro connector set with the wires is a very good suggestion. I will look around some more.
                            • P
                              P
                              phil83
                              I finally went on with the project and received the pcbs last week... my soldering oven is running and I could finish the first board (still some parts are missing :-( ) If only I had more time to work on that...
                              Here are some impressions:
                              I soldered some cables so that I can program it and check via ftdi...
                              More to come soon...
                              • P phil83
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @phil83
                                Share this on OpenHardware.io !
