  3. MyController.org
  4. Soil Sensor Trips wrong way (dry>wet not wet>dry)
Scheduled Pinned Locked Moved MyController.org
16 Posts 2 Posters 4.5k Views 2 Watching
  • crusher70C
    crusher70C
    crusher70
    wrote on last edited by crusher70
    Hi there,
    I have tried setting the "Trigger When" option to 1 and 0 but it still seems to be reversed.
    Many thanks.
    Glen
    J 1 Reply Last reply
    • crusher70C crusher70
      Hi there,
      Many thanks.
      Glen
      J
      J
      jkandasa
      @crusher70 said:
      Hi there,
      Many thanks.
      Glen
      What exactly your sensor returns 0 and 1? or string value like wet , dry something like? If it is string should be case sensitive.
      Also you have configured Dampening type as Consecutive with 2 counts, which means this condition should satisfy two times continuously.
      Recommendation: If you are sending string value from sensor Tripped variable is not a suitable one. Better use VAR1...VAR5 or suitable variable type.
      crusher70C 1 Reply Last reply
      • J jkandasa
        @crusher70 said:
        Hi there,
        Many thanks.
        Glen
        crusher70C
        crusher70C
        crusher70
        @jkandasa
        Hi and thank you for your help with this.
        I'm using the default MySensor sketch, the read function is as follows:-
        the serial output shows that when the sensor is wet (not triggered) a 1 is sent and Dry (triggered) a 0 is sent.
        I have changed the Dampening to none for now.
          // Read digital soil value
          int soilValue = digitalRead(DIGITAL_INPUT_SOIL_SENSOR); // 1 = Not triggered, 0 = In soil with water
          if (soilValue != lastSoilValue) {
            Serial.println(soilValue);
            gw.send(msg.set(soilValue==0?1:0));  // Send the inverse to gw as tripped should be when no water in soil
            lastSoilValue = soilValue;
          @jkandasa
          J
          J
          jkandasa
          @crusher70
          Thank you for the code. Yes, your sensor sends 1 and 0. You have to configure two alarm definitions.
          one as you showed here and another one should be like trigger when == 0
          • J jkandasa
            @crusher70
            crusher70C
            crusher70C
            crusher70
            @jkandasa
            Thank you jkandasa,
            I was looking at it from completely the wrong direction trying to cover everything with just one alarm. I have reconfigured as you suggested and also added a forward payload which turns on a relay to water plants and turns it off when soil is wet.
            Working perfectly thank you so much for your help with this.
            Glen
              @jkandasa
              Thank you jkandasa,
              Glen
              J
              J
              jkandasa
              wrote on last edited by jkandasa
              @crusher70
              Perfect! you can also configure one safety alarm for your relay. For example controller turned on relay based on wet, dry signal. Later if we do not receive any data from sensor, relay will be keep on turned ON and water over flow will happened.
              To avoid this you can configure one additional alarm for relay. Say turn OFF relay if it's continually ON for more than 20 minutes.
              Condition: Realy == 1 and in Dampening: Active time 20 minutes
              crusher70C 2 Replies Last reply
              • J jkandasa
                @crusher70
                crusher70C
                crusher70C
                crusher70
                @jkandasa
                Great idea! Ill do that now. Thanks again for being so helpful.
                Glen
                • J jkandasa
                  @crusher70
                  crusher70C
                  crusher70C
                  crusher70
                  @jkandasa
                  Ok one final nob question if you don't mind?
                  I have configured the Alarm as suggested but set the active time for 1 min for testing. The alarm triggers as it should but I cant see where the triggering of this alarm turns off the relay. Sorry if this is a silly question but I can't for the life of me see where to configure it.
                  Many thanks
                  Glen
                    @jkandasa
                    Many thanks
                    Glen
                    J
                    J
                    jkandasa
                    @crusher70
                    Hey, no problem at all. you can ask as many questions you want.
                    Can you post your configuration screenshot?
                    • J jkandasa
                      @crusher70
                      crusher70C
                      crusher70C
                      crusher70
                      @jkandasa
                      As requested this is the alarm i have configured.
                        @jkandasa
                        J
                        J
                        jkandasa
                        @crusher70
                        Alarm triggers but there is no notification to execute for this alarm. You have to create new notification with Send payload relay =1. and map your new notification with this alarm.
                        • J jkandasa
                          @crusher70
                          crusher70C
                          crusher70C
                          crusher70
                          @jkandasa
                          Ah now I understand thank you once again.
                          Regards
                          Glen
                          • J jkandasa
                            @crusher70
                            crusher70C
                            crusher70C
                            crusher70
                            @jkandasa
                            Thanks jkandasa work great. I shall leave you alone to rest up for a while as its 4:30 am over there. I'm sure I'll have more questions at some point in the future, but for now you have been a great help so thank you very much. Take care and have a great day.
                            Regards
                            Glen
                              @jkandasa
                              Regards
                              Glen
                              J
                              J
                              jkandasa
                              @crusher70 well! Thank you!
