  3. MyController.org
  4. Soil Sensor Trips wrong way (dry>wet not wet>dry)
Scheduled Pinned Locked Moved MyController.org
16 Posts 2 Posters 4.5k Views 2 Watching
  • J jkandasa
    @crusher70 said:
    Hi there,
    I have tried setting the "Trigger When" option to 1 and 0 but it still seems to be reversed.
    Many thanks.
    Glen
    What exactly your sensor returns 0 and 1? or string value like wet , dry something like? If it is string should be case sensitive.
    Also you have configured Dampening type as Consecutive with 2 counts, which means this condition should satisfy two times continuously.
    Recommendation: If you are sending string value from sensor Tripped variable is not a suitable one. Better use VAR1...VAR5 or suitable variable type.
    crusher70C
    crusher70C
    crusher70
    @jkandasa
    Hi and thank you for your help with this.
    I'm using the default MySensor sketch, the read function is as follows:-
    the serial output shows that when the sensor is wet (not triggered) a 1 is sent and Dry (triggered) a 0 is sent.
    I have changed the Dampening to none for now.
      // Read digital soil value
      int soilValue = digitalRead(DIGITAL_INPUT_SOIL_SENSOR); // 1 = Not triggered, 0 = In soil with water
      if (soilValue != lastSoilValue) {
        Serial.println(soilValue);
        gw.send(msg.set(soilValue==0?1:0));  // Send the inverse to gw as tripped should be when no water in soil
        lastSoilValue = soilValue;
    J 1 Reply Last reply
    • crusher70C crusher70
      @jkandasa
      J
      J
      jkandasa
      @crusher70
      Thank you for the code. Yes, your sensor sends 1 and 0. You have to configure two alarm definitions.
      one as you showed here and another one should be like trigger when == 0
      crusher70C 1 Reply Last reply
      • J jkandasa
        @crusher70
        crusher70C
        crusher70C
        crusher70
        wrote on last edited by crusher70
        @jkandasa
        Thank you jkandasa,
        I was looking at it from completely the wrong direction trying to cover everything with just one alarm. I have reconfigured as you suggested and also added a forward payload which turns on a relay to water plants and turns it off when soil is wet.
        Working perfectly thank you so much for your help with this.
        Glen
          @jkandasa
          Thank you jkandasa,
          Glen
          J
          J
          jkandasa
          wrote on last edited by jkandasa
          @crusher70
          Perfect! you can also configure one safety alarm for your relay. For example controller turned on relay based on wet, dry signal. Later if we do not receive any data from sensor, relay will be keep on turned ON and water over flow will happened.
          To avoid this you can configure one additional alarm for relay. Say turn OFF relay if it's continually ON for more than 20 minutes.
          Condition: Realy == 1 and in Dampening: Active time 20 minutes
          crusher70C 2 Replies Last reply
          • J jkandasa
            @crusher70
            crusher70C
            crusher70C
            crusher70
            @jkandasa
            Great idea! Ill do that now. Thanks again for being so helpful.
            Glen
            • J jkandasa
              @crusher70
              crusher70C
              crusher70C
              crusher70
              @jkandasa
              Ok one final nob question if you don't mind?
              I have configured the Alarm as suggested but set the active time for 1 min for testing. The alarm triggers as it should but I cant see where the triggering of this alarm turns off the relay. Sorry if this is a silly question but I can't for the life of me see where to configure it.
              Many thanks
              Glen
                @jkandasa
                Many thanks
                Glen
                J
                J
                jkandasa
                @crusher70
                Hey, no problem at all. you can ask as many questions you want.
                Can you post your configuration screenshot?
                • J jkandasa
                  @crusher70
                  crusher70C
                  crusher70C
                  crusher70
                  @jkandasa
                  As requested this is the alarm i have configured.
                    @jkandasa
                    J
                    J
                    jkandasa
                    @crusher70
                    Alarm triggers but there is no notification to execute for this alarm. You have to create new notification with Send payload relay =1. and map your new notification with this alarm.
                    • J jkandasa
                      @crusher70
                      crusher70C
                      crusher70C
                      crusher70
                      @jkandasa
                      Ah now I understand thank you once again.
                      Regards
                      Glen
                      • J jkandasa
                        @crusher70
                        crusher70C
                        crusher70C
                        crusher70
                        @jkandasa
                        Thanks jkandasa work great. I shall leave you alone to rest up for a while as its 4:30 am over there. I'm sure I'll have more questions at some point in the future, but for now you have been a great help so thank you very much. Take care and have a great day.
                        Regards
                        Glen
                          @jkandasa
                          Regards
                          Glen
                          J
                          J
                          jkandasa
                          @crusher70 well! Thank you!
