  2. Announcements
  3. 1.4 Beta
1.4 Beta
1.4betahelp
129 Posts 18 Posters 124.1k Views 4 Watching
    @ServiceXp
    The sensor fetches the unit setting from Vera at startup. Something probably fails during this data exchange. You'll have to look at the debug logs to see what happens.
    This behavior might change in 1.4 with sensors just reporting SI-units and controller makes the necessary conversion/scaling.
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    @hek
    This is the first time I've ssh into vera, so I have no idea what I'm looking for.. I have 2 Everspring ST-814's that display correctly, and of course 2 MySensor sensor which did in 1.3, but not in 1.4b1.
    I found this, but not sure if this is what you need.
    02 08/22/14 7:47:04.914 luup_log:87: Arduino: Incoming internal command '0;0;3;9;read: 2-2-0 s=1,c=1,t=0,pt=7,l=5:22.6' discarded for child: nil <0x2f8b3680>
    50 08/22/14 7:47:04.916 luup_log:87: Arduino: Set variable: 2;1;1;0;0;22.6 <0x2f8b3680>
    50 08/22/14 7:47:04.916 luup_log:87: Arduino: Setting variable 'CurrentTemperature' to value '22.6' <0x2f8b3680>
    50 08/22/14 7:47:04.916 luup_log:87: Arduino: urn:upnp-org:serviceId:TemperatureSensor1,CurrentTemperature, 22.6, 92 <0x2f8b3680>
    06 08/22/14 7:47:04.917 Device_Variable::m_szValue_set device: 92 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 22.5 now: 22.6 #hooks: 3 upnp: 0 v:0xda4620/NONE duplicate:0 <0x2f8b3680>
    01 08/22/14 7:47:04.918 LuaInterface::CallFunction_Variable func: w_switch Device_Variable 92 urn:upnp-org:serviceId:TemperatureSensor1:CurrentTemperature failed [string "..."]:14: bad argument #1 to 'sub' (string expected, got nil) <0x2f8b3680>
    01 08/22/14 7:47:04.919 LuaInterface::CallFunction_Variable func: w_switch Device_Variable 92 urn:upnp-org:serviceId:TemperatureSensor1:CurrentTemperature failed [string "..."]:14: bad argument #1 to 'sub' (string expected, got nil) <0x2f8b3680>
    RJ_Make
    hekH 1 Reply Last reply
    • RJ_MakeR RJ_Make
      @hek
      @ServiceXp
      The node will be transferring celsius data until it manage to receive settings from controller (this is done in the background) by setup().
      Attach your failing sensor to the computer. Upload sketch with debug enabled. And look at the Serial monitor. Restart a sensor a few times .
      RJ_MakeR 1 Reply Last reply
        @ServiceXp
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @hek
        Thanks, I'll do that when I get home later. Just so I'm clear..
        To enable debugging: I Remove the "//" before the #define DEBUG ** in and ONLY in** the /libraries/MySensors/Config.h file ? Then upload the sketch again to the sensors? (I don't have to upload the gateway sketch also do I?)
        RJ_Make
        • RJ_MakeR RJ_Make
          @hek
          @ServiceXp
          Yes correct!
            @ServiceXp
            Yes correct!
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @hek
            I can only find MyConfig.h file, and DEBUG was already without the "//".
            So I noticed something VERY strange. It seems when I have the sensors connected to the computer, they start reading in Fahrenheit, and once I pull the USB cable it reverts back to Celsius with-in 30-60 seconds..
            RJ_Make
            • RJ_MakeR
              RJ_MakeR
              RJ_Make
              Yep, I have no idea how to debug this. The debug window reads in Fahrenheit, (and in Vera), but 30-60 seconds after I disconnect the usb cable from my computer (at which point I can't use the serial com window) it reverts back to Celsius.
              I've deleted one of the sensor nodes and child from Vera, cleared the eEPROM and re-install sketch and re-incuded back into Vera...
              I just don't understand why it works while connected to my computer...
              RJ_Make
              • RJ_MakeR RJ_Make
                @ServiceXp
                No, this seems strange. The unit settings should get stored in eeprom.
                  @ServiceXp
                  RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  @hek
                  Do you think I can rule out my sensor hardware as it works with 1.3? Is there any way I can determine if it's being written to eEPROM while connected to the computer and then after it's disconnected (to see if it's getting overwritten)?
                  RJ_Make
                  • RJ_MakeR RJ_Make
                    @hek
                    @ServiceXp
                    Do you call process() in loop()?
                    But, really.. Don't put too much effort into this. Just hardcode sensor to send fahrenheit until conversion is done by controller plugin.
                      @ServiceXp
                      RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      wrote on last edited by RJ_Make
                      #126
                      @hek
                      I'm using the boiler plate sketch provided in the 1.4b1 files. The only modifications I've done is add battery code. (Copy and Paste).
                      How to I hard code sensor to send in Fahrenheit?
                      Sorry you have to hold my hand through this, I'm very new at this.....
                      RJ_Make
                      • RJ_MakeR RJ_Make
                        @hek
                        @ServiceXp
                        Change
                        float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                        To
                        float temperature = static_cast<float>(static_cast<int>((sensors.getTempFByIndex(i)) * 10.)) / 10.;
                        But I still wonder what goes wrong...
                          @ServiceXp
                          Change
                          To
                          RJ_MakeR
                          RJ_MakeR
                          RJ_Make
                          @hek
                          Worked perfectly for the temperature sensor, but it appears the Humidity and Temp. Sketch handles this differently. Not sure what to replace and where.
                          RJ_Make
                          • RJ_MakeR
                            RJ_MakeR
                            RJ_Make
                            Not very nice but I think this will work..
                              //float temperature = dht.getTemperature();
                             float temperature = dht.getTemperature()*9/5 + 32;
                             if (isnan(temperature)) {
                             lastTemp = temperature;
                               if (!metric) {
                              temperature = dht.getTemperature()*9/5 + 32;   //dht.toFahrenheit(temperature);
                            RJ_Make
