  3. MyNodes.NET
  4. MyNodes.NET 2.0
MyNodes.NET 2.0
Scheduled Pinned Locked Moved MyNodes.NET
31 Posts 11 Posters 14.3k Views 14 Watching
  • derwishD derwish
    @Qu3Uk Thanks for the hint to unlock the zip archive. I got this problem while testing on some computers with Windows 7, and could not understand how to fix it. In Windows 10 this problem is not present. I'll write about it on the website.
    About the request version. The controller queries the version of the gateway every 10 seconds, to make sure that the gateway is still connected. If the gateway does not respond, the controller will try to reconnect to it. This is a mechanism to protect against disconnects. Log console filters those messages by default, but you can see them if you enable Gateway Messages on config page.
    Q
    Q
    Qu3Uk
    @derwish Ah that makes sense if your using it to check connection, should have twigged that.
    So whats your plans for MyNodes.NET?
    derwishD 1 Reply Last reply
    • W
      W
      wilson64
      Any support for MQTT gateway?
      • Q Qu3Uk
        derwishD
        derwishD
        derwish
        @Qu3Uk If it will be in demand, I will add the functionality that is being asked.
        • derwishD derwish
          derwishD
          derwishD
          derwish
          @derwish I haven't experimented with it yet.
          • derwishD
            derwishD
            derwish
            Updated Troubleshooting section on the website.
            • Greg McFadyenG
              Greg McFadyenG
              Greg McFadyen
              Wow, this is really smart thinking and I've just installed with one gateway and one sensor.
              Well done, thank you.
              • oscarcO
                oscarcO
                oscarc
                Newbie here , could some one please show me how to do a timer for a relay ? my gateway and my relay are already connected to Mynodes but so far i haven't been able to make it switch on or off
                thanks for any help
                • oscarcO oscarc
                  thanks for any help
                  derwishD
                  derwishD
                  derwish
                  @oscarc To start, just plug UI/Toggle. It will send "1" / "0" in your device. You got it in the firmware of the Arduino. When this will work, try different timers. For example, UI/Timer. You'll see its interface in dashboard. Schedule it to send "1" at the right time. If you have any problems, write me (info@mynodes.net) and I'll help you via Skype.
                  oscarcO 1 Reply Last reply
                  • Greg McFadyenG Greg McFadyen
                    derwishD
                    derwishD
                    derwish
                    @Greg-McFadyen Thank you.
                    Guys, if you make an interesting panels, share file/screenshot here.
                    I want to make panels for various kinds of RGB-LED fades for the party. I would be grateful if you help.
                    • derwishD derwish
                      oscarcO
                      oscarcO
                      oscarc
                      @derwish Thank you ,I'll give it a try .
                      • keldandorinK
                        keldandorinK
                        keldandorin
                        This is soooooooo great. I been trying to program something like this for month but as a total N00B it has been harder then I thought. Got a hold bunch off ideas to expand this. :)
                        1. Email Node - Send mail message
                        2. Send message to Azure IoT hub
                        3. Resive message from Azure
                        4. Send Message to Azure mobile hub for Push notifications
                        5. Read From External Database
                        6. Write To External Database
                        Couple of questians
                        Is it possible to run this as a service in windows and not as a console app?
                        Is it possible to make it work on Windows IoT ?
                        And again super nice gateway alot of thx.
                        //Håkan
                        • keldandorinK keldandorin
                          Couple of questians
                          //Håkan
                          derwishD
                          derwishD
                          derwish
                          @keldandorin Hi. I've added your ideas to my task list. Thank you. If you can program in C#, you can try to do it yourself. Read documentation for developers.
                          I haven't experimented with Windows IOT yet, but it certainly works under Linux on the raspberry.
                          On about the service, I'll look for options, how to do it. It is a necessary thing for me too.
                          keldandorinK 1 Reply Last reply
                          • derwishD derwish
                            keldandorinK
                            keldandorinK
                            keldandorin
                            @derwish Cool. I have working code for sending and resiveing messages from azure. Read the dev documents and will try to make a node as soon as I can.
                            • lordsidneyL
                              lordsidneyL
                              lordsidney
                              I'm really interested in this software, but I'm also a .NET beginer. I got an issue when executing web.cmd ==> "dnx.win32.dll could not be loaded. Last error : 87"...
                              Is there someone who could tell me what is going wrong ?
                              • lordsidneyL lordsidney
                                derwishD
                                derwishD
                                derwish
                                @lordsidney This error occurs on Windows 7, if you have not installed the system update. https://github.com/aspnet/dnx/issues/3213
                                • Q
                                  Q
                                  Qu3Uk
                                  Any plans to support the MQTT gateway.. I'm finding I want to use multiple controllers but I find the Ethernet gateway supports only so many connections so I want to move towards using MQTT.
                                  • Q Qu3Uk
                                    derwishD
                                    derwishD
                                    derwish
                                    @Qu3Uk I haven't built MQTT gateway yet. There is a sense to experiment with it?
                                    • sle118S
                                      sle118S
                                      sle118
                                      This looks very interesting!
                                      A couple of questions
                                      • does it require a special mySensor version? I have setup an esp8266 with the most recent github in the stable branch, but the gateways doesn't seem to want to respond to myNodes. The gateway works just fine with veralite
                                      • any way to pull other veralite zwave devices through the gateway? It would complement the vets really well!
                                      • sle118S sle118
                                        derwishD
                                        derwishD
                                        derwish
                                        @sle118 I haven't checked esp8266 gateway. I'll try to build it soon and check it out. The controller should work with any version.
                                        I will add support for zwave devices, as soon as I get one. So far, I have not.
                                        • ManuInNZM
                                          ManuInNZM
                                          ManuInNZ
                                          Hi
                                          I saw someone was trying to create a Docker container for it. Yet I do not seems to get it going.
                                          Did anyone succeed ?
                                          I would love to run it on my Synology to replace Home Assistant.
                                          Manu
