  3. Custom power meter
Custom power meter
31 Posts 15 Posters 34.0k Views 14 Watching
  • E
    E
    ewgor
    Have anyone integrated this with Openhab? can we find somwhere some Openhab items, rules for this sketch that @maglo18 posted here http://forum.mysensors.org/topic/1464/sct-013-030-current-monitor-sensor?
    Thanks for any help!
    • G
      G
      Gambituk
      Hi @maglo18 i have been using a current only version of emon for quite some time, i am interested in adding the ac-ac transformer to calculate the apparent power more accurately. Do you have a project page for your build with diagrams and specs? What type of transformers are you using (i can just about read it from picture) and how happy are you with the performance?
      Thanks Gambituk
      • E
        E
        ewgor
        wrote on last edited by ewgor
        Hi All,
        Did anyone worked with this sensor SCT-013-000 and Openhab? I would like to ask how can I integrate this with Openhab so to be able to display the apparent power consumption in watts, to display the Kwh starting a certain date lets say starting on 12th this month or from today as for example and to display to total Kwh.
        @maglo18 where are you from?
        Any help or suggestion will be kindly appreciated.
        Thanks All!
          maglo18
          @GambitukI am very happy with performance. I'm logs power every 10s and voltage every 60s. It is sufficient. I built like on this site http://openenergymonitor.org/emon/buildingblocks/measuring-voltage-with-an-acac-power-adapter
          You can use transformer what you like but you must add voltage divider to have voltage max 2,5V on input in arduino if you use arduino 5V
          PS Poland/Warsaw
          E 1 Reply Last reply
          • M maglo18
            PS Poland/Warsaw
            E
            E
            ewgor
            @maglo18 I saw some words in your pictures that looks familiar like faza or analizator :)
            Can you share your latest Arduino sketch or if you have a complete tutorial about this project would be helpful.
            • J
              J
              jeti
              @maglo18: is the sketch in the first post your latest version? I would also like to do a very similar build and would like to get the best base :)
              thanks!
                maglo18
                This is my last and my final sketch
                #include "EmonLib.h"             // Include Emon Library
                EnergyMonitor emon1;             // Create an instance
                EnergyMonitor emon2;             // Create an instance
                EnergyMonitor emon3;             // Create an instance
                #define CHILD_ID 0
                #define CHILD_ID2 1
                #define CHILD_ID3 2
                unsigned long lastSend;
                unsigned long SEND_FREQUENCY = 10000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                unsigned long lastSend2;
                unsigned long SEND_FREQUENCY2 = 300000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                MyMessage realPowerMsg(CHILD_ID,V_VAR1);
                MyMessage apparentPowerMsg(CHILD_ID,V_VAR2);
                MyMessage powerFActorMsg(CHILD_ID,V_VAR3);
                MyMessage supplyVoltageMsg(CHILD_ID,V_VAR4);
                MyMessage IrmsMsg(CHILD_ID,V_VAR5);
                MyMessage realPowerMsg2(CHILD_ID2,V_VAR1);
                MyMessage apparentPowerMsg2(CHILD_ID2,V_VAR2);
                MyMessage powerFActorMsg2(CHILD_ID2,V_VAR3);
                MyMessage supplyVoltageMsg2(CHILD_ID2,V_VAR4);
                MyMessage IrmsMsg2(CHILD_ID2,V_VAR5);
                MyMessage realPowerMsg3(CHILD_ID3,V_VAR1);
                MyMessage apparentPowerMsg3(CHILD_ID3,V_VAR2);
                MyMessage powerFActorMsg3(CHILD_ID3,V_VAR3);
                MyMessage supplyVoltageMsg3(CHILD_ID3,V_VAR4);
                MyMessage IrmsMsg3(CHILD_ID3,V_VAR5);
                  gw.begin(NULL, 4, false, 0);
                  Serial.begin(115200); // opens serial port, sets data rate to 9600 bps
                  gw.sendSketchInfo("Energy Meter x 3v2", "1.2");
                  gw.present(CHILD_ID, S_POWER);
                  gw.present(CHILD_ID2, S_POWER);
                  gw.present(CHILD_ID3, S_POWER);
                  emon1.voltage(A3, 116.26, 1.7);  // Voltage: input pin, calibration, phase_shift
                  emon1.current(A0, 29.0);       // Current: input pin, calibration.
                  emon2.voltage(A4, 116.66, 1.7);  // Voltage: input pin, calibration, phase_shift
                  emon2.current(A1, 29.0);       // Current: input pin, calibration.
                  emon3.voltage(A5, 115.91, 1.7);  // Voltage: input pin, calibration, phase_shift
                  emon3.current(A2, 29.0);       // Current: input pin, calibration.
                  unsigned long now = millis();
                  emon1.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
                  //emon1.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
                  emon2.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
                  //emon2.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
                  emon3.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
                  //emon3.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
                  if (sendTime) {
                    float realPower       = emon1.realPower;        //extract Real Power into variable
                    float realPower2       = emon2.realPower;        //extract Real Power into variable
                    float realPower3       = emon3.realPower;        //extract Real Power into variable
                    if(realPower > 0 && realPower < 10000){
                    gw.send(realPowerMsg.set(realPower,1));
                    if(realPower2 > 0 && realPower2 < 10000){
                    gw.send(realPowerMsg2.set(realPower2,1));
                    if(realPower3 > 0 && realPower3 < 10000){
                    gw.send(realPowerMsg3.set(realPower3,1));
                    lastSend = now;
                  bool sendTime2 = now - lastSend2 > SEND_FREQUENCY2;
                  if(sendTime2){
                    float apparentPower   = emon1.apparentPower;    //extract Apparent Power into variable
                    float powerFactor     = emon1.powerFactor;      //extract Power Factor into Variable
                    float supplyVoltage   = emon1.Vrms;             //extract Vrms into Variable
                    float Irms            = emon1.Irms;             //extract Irms into Variable
                    float apparentPower2   = emon2.apparentPower;    //extract Apparent Power into variable
                    float powerFactor2     = emon2.powerFactor;      //extract Power Factor into Variable
                    float supplyVoltage2   = emon2.Vrms;             //extract Vrms into Variable
                    float Irms2            = emon2.Irms;             //extract Irms into Variable
                    float apparentPower3   = emon3.apparentPower;    //extract Apparent Power into variable
                    float powerFactor3     = emon3.powerFactor;      //extract Power Factor into Variable
                    float supplyVoltage3   = emon3.Vrms;             //extract Vrms into Variable
                    float Irms3            = emon3.Irms;             //extract Irms into Variable
                    if(apparentPower > 0 && apparentPower < 10000){
                    gw.send(apparentPowerMsg.set(apparentPower,1));
                    if(powerFactor > 0 && powerFactor < 10000){
                    gw.send(powerFActorMsg.set(powerFactor,1));
                    if(supplyVoltage > 0 && supplyVoltage < 1000){
                    gw.send(supplyVoltageMsg.set(supplyVoltage,1));
                    if(Irms > 0 && Irms < 1000){
                    gw.send(IrmsMsg.set(Irms,1));
                    if(apparentPower2 > 0 && apparentPower2 < 10000){
                    gw.send(apparentPowerMsg2.set(apparentPower2,1));
                    if(powerFactor2 > 0 && powerFactor2 < 10000){
                    gw.send(powerFActorMsg2.set(powerFactor2,1));
                    if(supplyVoltage2 > 0 && supplyVoltage2 < 1000){
                    gw.send(supplyVoltageMsg2.set(supplyVoltage2,1));
                    if(Irms2 > 0 && Irms2 < 1000){
                    gw.send(IrmsMsg2.set(Irms2,1));
                    if(apparentPower3 > 0 && apparentPower3 < 10000){
                    gw.send(apparentPowerMsg3.set(apparentPower3,1));
                    if(powerFactor3 > 0 && powerFactor3 < 10000){
                    gw.send(powerFActorMsg3.set(powerFactor3,1));
                    if(supplyVoltage3 > 0 && supplyVoltage3 < 1000){
                    gw.send(supplyVoltageMsg3.set(supplyVoltage3,1));
                    if(Irms3 > 0 && Irms3 < 1000){
                    gw.send(IrmsMsg3.set(Irms3,1));
                    lastSend2 = now;
                • E
                  E
                  ewgor
                  Thank you for sharing this code.
                  I modified your code only for a CT sensor which is connected to A0. The CT is connected to a 40 Watts lamp and this is what i get on Arduino serial monitor:
                  sensor started, id 4
                  send: 4-4-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                  send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                  send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=18,st=ok:Energy Meter x 3v2
                  send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.2
                  send: 4-4-0-0 s=0,c=0,t=13,pt=0,l=0,st=ok:
                  send: 4-4-0-0 s=0,c=1,t=24,pt=7,l=5,st=ok:0.1
                  what is the last value (0.1)? Amps? if i turn off the lamp the i get 0.0!
                  In your sketch i see you calculate the real power, power factor, Vrms (volts?) and Irms (Amps?)
                  why is displaying in the serial monitor only one value which i assume is Irms?
                  I would like to calculate only the power and to export this to openhab but.....i dont know how :(
                  • D
                    deennoo
                    Hi Nice job hère !
                    Do you think your sketch can work with this ?
                    http://fr.aliexpress.com/item/PEACEFAIR-AC-100A-Electric-power-monitoring-and-communication-module-power-meter-power-energy-Volt-Ammeter/32373508101.html
                    nicofly974N 1 Reply Last reply
                    • D deennoo
                      Hi Nice job hère !
                      nicofly974N
                      nicofly974N
                      nicofly974
                      @maglo18
                      I have a question about your sensor
                      I want to do a similar sensor, with 3 or more Amp meter but just one voltage.
                      Is it possible ( or a bad idear) to use transformer for measuring voltage and use as power suply (with regulation 5v and 3,3v) for sensor?
                      Thank's
                        maglo18
                        You can use one voltage and use few Amps but only on one phase . If you want to measure Amps on other phases you should add another voltage meter on each phases.
                        You can't to use transformer for power supply because on transformer for measuring is AC voltage and power supply for arduino is DC voltage
                        • nicofly974N
                          nicofly974N
                          nicofly974
                          For precision, I've just one phase at home, but I want few Amps meter for different "sectors" of the house.
                          My question was: Is it a good idea to use the transformer (I've a AC 220V to AC 12v 3VA) for both using: power supply of the sensor (with rectifier bridge and capacity and regulator) and for voltage meter (with divider bridge as you do in your sensor).
                          Or it's a bad idear: Is it possible, in this configuration, to generate a voltage variation when arduino send informations?
                          • staehlerS
                            staehlerS
                            staehler
                            Where do I get the calibration of a SCT-013-000 from. I found this description https://openenergymonitor.org/emon/buildingblocks/ct-and-ac-power-adaptor-installation-and-calibration-theory but unfortunately, I've no idea how to measure the correct calibration.
                            As far as I understand this article, there could be a total error of 19.5% in uncalibrated case.
                            Can anybody help an non-electrician ;-)
                            • Richad HarianjaR
                              Richad HarianjaR
                              Richad Harianja
                              @maglo18
                              Help me please, I have a SCT 013-000 sensor but i do not have python program code. I want to use these sensors to measure electric current power. The sensor is connected with raspberry pi.
