  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 676.6k Views 99 Watching
  • K kolaf
    Are any of you having trouble with this binding together with other bindings that use serial ports? It looks as if the different bindings try to use the same serial port lock, so I get a conflict where things fail til initialize. Think it had something to do with the serial port library...
    TimO
    @kolaf Is it zwave again? Last time I tried to fix the conflict I needed to change the zwave binding.
    • K
      K
      kolaf
      It is both zwave and rfxcom. I played about it in the oh2 community some time ago, let me see if I can find a link.
      • K
        K
        kolaf
        It is my post: https://community.openhab.org/t/rfxcom-2-0-binding/4427/28?u=frankose
        • T TimO
          There is a new build of the jar available!
          Changes:
          • Added delay before checking the SerialGW (@andreacioni )
          • Requests are answered by the binding (The binding returns "0" if no value was set before)
          https://github.com/tobof/openhab2-addons/issues/8
          G
          G
          gonzalonal
          wrote on last edited by gonzalonal
          #142
          Hello @TimO .
          Just tested the last build of the binding. Works great.
          I see you manage to answer the nodes requests without having to trigger a rule to respond.
          I though that wasn't possible due to the limitation of the API. Did they manage to solve this from the OH side?
          Does the binding itself keeps track of the items values, or does it querys OH (or its persistence service) for getting the right value?
          Gonzalo
          • G gonzalonal
            Hello @TimO .
            Gonzalo
            TimO
            Hi @gonzalonal !
            I'm glad it works, thanks for testing!
            Sadly the limitation of the API is still there, but for the implementation of the requestAck feature I needed to implement a memory and now reused this memory to answer requests.
            There is a really big BUT coming with this implementation: we currently can't use persistence out of the box. For this a rule is needed. After startup of OH we need to use "sendCommand(ITEMNAME, VALUE)", where VALUE Is the value stored in persistance. With that the memory of the binding is filled initially.
            Hopefully I will find an easier way in the future .
            G 1 Reply Last reply
            • T TimO
              Hi @gonzalonal !
              G
              G
              gonzalonal
              #144
              I get what you mean @TimO .
              Unfortunatelly, using the rule method you suggest would create a lot of traffic (depending on how many sensors you have) at boot up time. Maybe there are some sensors that wouldn't behave the intended way if receiving the "last value" repeteadly.
              An example. Lets supose I have an automatic gate, that everytime it receives a command, wether its a "1" or "0" it toggles its moving direction. Like the most common automatic gates remotes.
              Gate is closed.
              Press button > Gate opens
              Press button > (if gate moving) Gate stops
              Press button > (if gate open) Gate closes
              Now, suppose last command send to the gate made it close. Suddenly, OH restarts itself because of power failure or whatever. It runs the rule to load the memory of the binding, while at the same time it sends to the sensors the last status taken from the persistance service. This would make the gate to open without your notice.
              This may create dangerous escenarios.
              I hope you can understand what I mean.
              Maybe it would be a better idea to handle requests with rules in the way I suggested in the github issue, that is the same way as the OH-1 mysensors serial binding works.
              Let me know if I can help in any way.
              Regards.
              Gonzalo.
              • T
                TimO
                @gonzalonal Good point! :worried:
                If a request (or a message in general) is received there is no "commandReceived" in OH, so you can't trigger a rule based on a message received. So doing it with a rule is not possible.
                A workaround would be to use "postUpdate()" to update the value after restart. This isn't implemented yet, but is no big deal. This would be a workaround for the workaround, because we still need the rule. :confused:
                In the OH1 binding the request is answered with the state of the item, as I would like to to do too.
                Line 277: https://github.com/bloft/openhab/blob/master/bundles/binding/org.openhab.binding.mysensors/src/main/java/org/openhab/binding/mysensors/internal/MySensorsBinding.java
                G 2 Replies Last reply
                • T TimO
                  G
                  G
                  gonzalonal
                  #146
                  Hi @TimO . Good we got in the same page.
                  I think this topic needs some more thinking.
                  I was reading OH wiki and found this about receivedCommand.
                   Implicit Variables inside the Execution Block
                  Besides the implicitly available variables for items and commands/states (see the script documentation), rules can have additional pre-defined variables, depending on their triggers:
                  * Every rule that has at least one command event trigger, will have the variable
                  receivedCommand available, which can be used inside the execution block.
                  * Every rule that has at least one status change event trigger, will have the variable
                  previousState available, which can be used inside the execution block.
                  https://github.com/openhab/openhab/wiki/Rules
                  Maybe this is not available anymore, or at least on OH2.
                  For now, I think it would be a better approach to use postUpdate at systemStart to populate the binding memory. With this, we'll avoid sending commands to the nodes.
                  Regards!
                  • T TimO
                    G
                    G
                    gonzalonal
                    #147
                    Hi again @TimO .
                    Just an idea.
                    What do you think about solving this problematic in this way:
                    We create a group whose members are all those items that later will populate the binding's memory. I have a group named mysqlpersisted where I put all the items whose data will be stored in my SQL DB. So I could use that group. For this example, let's call it "MemoryGroup"
                    Then, we can create the following rule:
                    rule "Populate MySensors binding memory"
                    when
                    System started
                    then
                    (maybe add a delay to allow persistance services to load)
                    MemoryGroup?.members.forEach[i |
                            postUpdate(i.name, i.previousState(true))
                    Using this method, memory would get populated everytime OH boots up, with data belonging to the persistance service that we use. And we use postUpdate, so no command is sent to the nodes.
                    With this I think we solve both problems as data in the binding will be concurrent with the persistance service data.
                    Let me know what you think about this.
                    Regards!
                    • T
                      TimO
                      Hi @gonzalonal !
                      I was thinking in the same direction and I have played a litte bit with different rules. I had no success in finding a rule that worked. Additionally I don't like the workaround. ;-)
                      A good solution would be, to trigger a rule, if a request is received, but there too I had no success till now.
                      I'm still struggling with it ...
                      • T
                        tomkxy
                        @TimO Do you think it would be hard to add MQTT support to the binding? I had a brief look to your code and it looks like the protocols are nicely isolated.
                        • T
                          TimO
                          I'm currently trying to migrate my production environment from OH1 to OH2. I'm now using two serial gateways.
                          @kolaf : The problem you described occured to me too. In my case I use two serial gateways. I've added a little method that ensures that a connection to more than two serial ports via nrjavaserial is possible. It works within the OH2 binding. Could you test if it works with the RFXCOM binding you are using? A new jar is available on github. OH2 is currently using an old version of nrserialjava that has a bug. I don't know how to switch the version yet.
                          @tomkxy : I will integrate MQTT in my OH2 Installation soon and will come back to your request after that.
                          K 1 Reply Last reply
                          • undeeU
                            undeeU
                            undee
                            The binding doesn't seem to handle the "requestTime" function yet. Time-aware sensors would be able to handle temporary OpenHAB outages by executing some scheduled actions autonomously, which I could use in the window cover controllers I'm developing.
                            • T TimO
                              K
                              K
                              kolaf
                              @TimO Thanks for the update. Unfortunately it did not seem to change anything for me, rfxcom still fails trying to use the wrong lock file. If it is helpful I can send you the log. Appreciate your input and effort.
                              • K
                                K
                                kolaf
                                The weird thing is that it seems to work with an older version of OH2 (and an old version of your binding), but not with the more recent beta releases.
                                • T
                                  TimO
                                  @kolaf : My guess is, the implementation in the could be the problem. Please do a litte test: remove the mysensors.jar file from the addons folder. Start OH2. RFXCOM should start fine now. Copy the mysensors.jar in the addons folder. OH2 will try to load the binding. What is the result?
                                  I suppose this way both binding work fine together?!
                                  • T TimO
                                    K
                                    K
                                    kolaf
                                    @TimO I tried this before, and removing the MySensors binding made the rfxcom binding work. However, this was not the case this time. I will try a bit later to also remove the zwave binding.
                                    20:56:34.098 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:serial_zstick:43b9314d' changed from UNINITIALIZED to INITIALIZING
                                    20:56:34.115 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
                                    20:56:34.115 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:serial_zstick:43b9314d' changed from INITIALIZING to ONLINE
                                    RXTX Warning:  Removing stale lock file. /var/lock/LCK..ttyACM0
                                    20:56:34.361 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is     initialized
                                    20:56:34.384 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave     controller
                                    20:56:34.385 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to     5000ms. Soft reset is false.
                                    20:56:34.419 [INFO ] [me.event.ThingStatusInfoChangedEvent] -     'zwave:serial_zstick:43b9314d' changed from ONLINE to     INITIALIZING
                                    20:56:34.444 [INFO ] [smarthome.event.InboxUpdatedEvent   ] - Discovery Result     with UID     'sonos:zoneplayer:RINCON_5CAAFD2BB4D801400' has been updated.
                                    20:56:34.578 [INFO ] [smarthome.event.InboxUpdatedEvent   ] - Discovery Result     with UID     'sonos:zoneplayer:RINCON_5CAAFD21C16201400' has been updated.
                                    20:56:34.756 [INFO ] [smarthome.event.InboxUpdatedEvent   ] - Discovery Result     with UID     'sonos:zoneplayer:RINCON_5CAAFD2BB4FE01400' has been updated.
                                    20:56:34.852 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                                    20:56:34.866 [INFO ] [smarthome.event.InboxUpdatedEvent   ] - Discovery Result with UID 'hue:bridge:0017881c7280' has been     updated.
                                    20:56:34.869 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
                                    20:56:34.998 [INFO ] [.openhab.core.internal.CoreActivator] - openHAB runtime has been started (v2.0.0, build 201602200203).
                                    20:56:35.015 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'demo.sitemap'
                                    20:56:35.444 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysensors.things'
                                    20:56:35.491 [INFO ] [smarthome.event.ThingAddedEvent     ] - Thing 'mysensors:bridge-ser:gateway' has been added.
                                    20:56:35.500 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from UNINITIALIZED to     INITIALIZING
                                    RXTX fhs_lock() Error: opening lock file: /var/lock/LCK..ttyACM0: File exists. It is mine
                                    �a�� testRead() Lock file failed
                                    RXTX Warning:  Removing stale lock file. /var/lock/LCK..mysensorsUSB
                                    20:56:37.420 [WARN ] [ssage.ApplicationCommandMessageClass] - NODE 37: Not initialized yet, ignoring message.
                                    20:56:37.426 [ERROR] [WaveSerialHandler$ZWaveReceiveThread] - Protocol error (CAN), resending
                                    20:56:37.427 [WARN ] [ssage.ApplicationCommandMessageClass] - NODE 37: Not initialized yet, ignoring message.
                                    20:56:37.429 [WARN ] [ssage.ApplicationCommandMessageClass] - NODE 37: Not initialized yet, ignoring message.
                                    20:56:38.773 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from INITIALIZING to ONLINE
                                    20:56:38.774 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rfxcom.things'
                                    20:56:38.780 [INFO ] [smarthome.event.ThingAddedEvent     ] - Thing 'rfxcom:bridge:rfxtrx' has been added.
                                    20:56:38.790 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'rfxcom:bridge:rfxtrx' changed from UNINITIALIZED to INITIALIZING
                                    20:56:38.792 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'rfxcom:bridge:rfxtrx' changed from INITIALIZING to OFFLINE
                                    RXTX fhs_lock() Error: opening lock file: /var/lock/LCK..mysensorsUSB: File exists. It is mine
                                    �`�� testRead() Lock file failed
                                    20:56:38.805 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Connection to RFXCOM transceiver failed: null
                                    • K kolaf
                                      K
                                      K
                                      kolaf
                                      It appears that I get these errors even if I remove all the offending bindings. I think I need to start with a completely clean installation and see how it goes. I will let you know.
                                      • K
                                        K
                                        kolaf
                                        Success, I think.
                                        I started a brand-new installation of the latest OH2 snapshot, and sequentially added the rfxcom, z-wave, and mysensors bindings. After fiddling a bit with getting serial ports recognised by OH2 and getting the permissions correct, it seems to work. I still get some weird error messages, but apparently the library is able to work through its issues :-). An example of what I mean is included.
                                        08:30:03.894 [INFO ] [smarthome.event.ThingAddedEvent     ] - Thing 'mysensors:bridge-ser:334037be' has been added.
                                        08:30:03.910 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:334037be' changed from UNINITIALIZED to INITIALIZING
                                        RXTX fhs_lock() Error: opening lock file: /var/lock/LCK..rfxtrxUSB: File exists. It is mine
                                        @�2� testRead() Lock file failed
                                        08:30:04.043 [INFO ] [smarthome.event.ItemAddedEvent      ] - Item 'mysensors_bridge_ser_334037be' has been added.
                                        08:30:04.219 [INFO ] [rthome.event.ItemThingLinkAddedEvent] - Link 'mysensors_bridge_ser_334037be-mysensors:bridge-ser:334037be' has been added.
                                        08:30:07.060 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:334037be' changed from INITIALIZING to ONLINE
                                        • K
                                          K
                                          kolaf
                                          Returns out that I am still seeing the problem sometimes. If I change the configuration so that the bindings are reloaded (especially the zwav binding) it fails to reconnect to the serial port. I found someone who had posted an updated serial binding which supposedly solved some related problem (I think), but I'm not sure. It does not appear to have had any effect on the problem.
                                          The modified version is available from one of the last posts here: https://github.com/openhab/openhab2-addons/issues/671
