  3. Has anyone made a 2 or 4 channel relay , and is that worked correct ?
40 Posts 7 Posters 12.0k Views 5 Watching
  • TheoLT TheoL
    @Reza I'm not sure. But if I understand you correctly, my gut feeling is that your pin 3 on the Arduino is broken (or not correctly setup in the code). Could be a power issue, but I seriously doubt it.
    Just try the blink sketch example. Hookup an LED to pin 3 and change the BLINK_LED pin to pin 3 instead of 13. That way you can check if pin 3 is working correctly.
    R
    R
    Reza
    i change code to :
    #define RELAY_1 4
    #define NUMBER_OF_RELAYS 2
    and in wiring in1=pin4 and in2=pin5
    so pin 5 is working but pin4 is not work !!!
    TheoLT 1 Reply Last reply
    • R Reza
      i change code to :
      #define RELAY_1 4
      TheoLT
      TheoLT
      TheoL
      @Reza In that case, since it's so predictable, it's a bug in your sketch. At least that's what I think. Unfortunately I have busy weekend and week ahead, so I don't think I have the time to investigate your code. I'm really sorry. I have to check if I have a spare relay, and if I can find one I'm willing to check your sketch. But as mentioned before I can't promise that.
      Hopefully others might be able to help you sooner. Take care.
      R 1 Reply Last reply
      • TheoLT TheoL
        R
        R
        Reza
        ok :( thank you very much
        • NuubiN
          NuubiN
          Nuubi
          Maybe using increment operator causes your problem [https://www.arduino.cc/en/Reference/Increment]
          Replacing pin++ with pin=pin+1 in your code should fix it.
          • NuubiN Nuubi
            R
            R
            Reza
            hi thank you , I will test this and I will report results
            • R Reza
              TheoLT
              TheoLT
              TheoL
              @Reza
              So I took your Sketch and refactored it. Just to be sure that nothing strange is in the code. I don't think there was anything strange in it. I just don't like the ID of defining one relay and calculate the others. But that's just me. I'd like to be able to debug, but with the way this sketch is set-up, checking what might be wrong is just harder to do.
              Haven't tested it on an Arduino, don't have any empty breadboard at the moment.
              #define RELAY_1          3     // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
              #define NUMBER_OF_RELAYS 2     // Total number of attached relays
              #define RELAY_ON         HIGH  // GPIO value to write to turn on attached relay
              #define RELAY_OFF        LOW   // GPIO value to write to turn off attached relay
              #define SKETCH_NAME      "Relay"
              #define SKETCH_VERSION   "1.0"
              MySensor gw; // don't bother with singing yet. First get the sketch and hardware to work...!!!!
                gw.begin( incomingMessage, AUTO, true ); // Initialize library and add callback for incoming messages
                gw.sendSketchInfo( SKETCH_NAME, SKETCH_VERSION); // Send the sketch version information to the gateway and Controller
                for ( int sensor = 0; sensor < NUMBER_OF_RELAYS; sensor++ ) {
                  gw.present( sensor + 1, S_LIGHT );           // Present the actuator to the GW
                  pinMode( RELAY_1 + sensor, OUTPUT );         // Assign Relay_pin as output
                  digitalWrite( RELAY_1 + sensor, RELAY_OFF ); // turn of the relay (some relay need inverted value. You'll have to check yours.). Turning it of is for safety!!!
                  gw.wait( 50 );                               // my gateway sometimes just can't handle to much child presents after each other
                  gw.request( sensor + 1, V_LIGHT );           // Request current state from Home Automation controller. I just don't see any reason to store it in the EPROM
                if ( message.type==V_LIGHT ) { // We only expect one type of message from controller. But we better check anyway.
                   int relayPin = RELAY_1 + message.sensor - 1;
                   if ( message.sensor >= 1 && message.sensor <= NUMBER_OF_RELAYS ) { // make sure message is for a known pin. You wouldn't want to write to a pin that's being used for the radio.
                     digitalWrite( relayPin, message.getBool() ? RELAY_ON : RELAY_OFF ); // Change relay state
                     Serial.print( ", relay_pin: " );
                     Serial.print( relayPin );
              Sketch should work. Please post the serial output of this sketch.
              My first steps would be:
              1. Use the sketch I provided (should work, or I missed something).
              2. Disconnect RELAY from Arduino.
              3. Connect LEDs to the arduino with resistor (330 Ohm should be just fine)
              Test this. The reason I would remove the relay is to be sure there's no power issue. The arduino should be able to provide enough power for driving a simple LED.
              If this works you know that it's a hardware problem and from there on, you can investigate what the problem is.
              R 2 Replies Last reply
              • TheoLT TheoL
                @Reza
                R
                R
                Reza
                @TheoL said:
                @Reza
                very very thank you , i will test this and i will comeback <3
                • TheoLT TheoL
                  @Reza
                  R
                  R
                  Reza
                  wrote on last edited by Reza
                  #37
                  @TheoL said:
                  @Reza
                  @TheoL this is trueeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee <3 <3 <3
                  so where was problem ? so this sketch will work for 4 or 8 channel ?
                  this problem was just for me ? or all ?
                  • R Reza
                    @TheoL said:
                    @Reza
                    TheoLT
                    TheoLT
                    TheoL
                    @Reza The Sketch is working? If so great. I wasn't sure, because I wasn't able to test it. I can't tell what was wrong. I just rewrote it. In theory it's possible to add 6 relays this way. This is because pin 9 is in use by the NFR24L01+ antenna. You could use pin 2 as a starting pin (you don't need to connect the radio to pin 2, because it's not using it). So you might be able to add up 7 relays with this sketch.
                    Because you also have pin 0 + 1 and the 6 analog pins, you can add up to 15 relays, but you'll need a different Sketch for this. Just let me now if you can get it to work with the max of 7 relays.
                    • TheoLT TheoL
                      R
                      R
                      Reza
                      yes this is working true.
                      ok.
                      very very very very thank you <3 <3 <3
                      • R Reza
                        ok.
                        TheoLT
                        TheoLT
                        TheoL
                        @Reza Glad that I could help. I was just thinking. I've added a wait in between the presentation of the relays childs to the gateway. Maybe that made the difference. Anyway good luck and enjoy the greatness of MySensors and it's wonderful community.
