  3. Issues with setting up my Arduino Nano SerialGateway
17 Posts 4 Posters 8.1k Views 4 Watching
  • Christian SimonsenC Christian Simonsen
    @Christian-Simonsen
    I've also tried to switch the MISO and MOSI just in case I had got it wrong. No effect. Still the same error.. :( Running out of ideas...
    TheoLT
    TheoLT
    TheoL
    @Christian-Simonsen what is the log saying when you monitor the gateway with serial monitor?
    also query this forum for St0;0;3;0;9;radio init fail. It might help you.
    • sundberg84S
      sundberg84S
      @Christian-Simonsen most have been said above, but my thoughts:
      Radio init fail means
      1. Not wired correctly
      2. Not powered correctly
      3. Not a nrf24 with +
      Do you have a capacitor between grn/vcc on the 3.3v radio? This can make difference...
      Some reading regarding + and not + Nrf modules.
      http://forum.mysensors.org/topic/1153/we-are-mostly-using-fake-nrf24l01-s-but-worse-fakes-are-emerging/4
      http://forum.mysensors.org/topic/1664/which-are-the-best-nrf24l01-modules/2
      Christian SimonsenC 1 Reply Last reply
      • sundberg84S sundberg84
        Christian SimonsenC
        Christian SimonsenC
        Christian Simonsen
        @sundberg84
        The chip marking is "NRF M 24L01+ 1452AB" - so I assume it is a + module.
        I've tried to rewire it multiple times, I will try again.
        • sundberg84S
          sundberg84S
          @Christian-Simonsen - Markings is not a guarantee...
          See the threads i posted, there are alot if images.. maybe you can see something there. Or post a picture of your radios here... maybe we can spot something if you suspect its a fake.
          Also - how do you power your node?
          • TheoLT
            TheoLT
            TheoL
            I'm using both NRF24L01 and NRF24L01+. You have to change the datarate in the MyConfig to 1mb to be able to do that.
            #define RF24_DATARATE RF24_1MBPS
              Christian SimonsenC
              Christian SimonsenC
              Christian Simonsen
              @sundberg84
              Fake NRF chips seems like the most plausible reason so far. The chips do look of bad quality.... but whether the chips are the issues or not is difficult to say..
              Can you judge from the pictures?
              • sundberg84S
                sundberg84S
                No - its not possible to say exacly. Its defenetly a fake - but how bad, not possible to say.
                I read some days ago someone recieved a bad batch and there was no silkscreen / white markings just like you. (See image) alt text
                but I also recieved a batch yesterday without markings - and the one i used today worked great!
                  Christian SimonsenC
                  Christian Simonsen
                  wrote on last edited by Christian Simonsen
                  Ok,
                  Is there a sketch that I can use that I can use to test/debug the NRF module specifically that might help identify what I am doing wrong or the if the module is bad?
                  I see some refer to running "Get Started".... but can't seem to find out what they are referring to...
                    Christian SimonsenC
                    Christian Simonsen
                    I found the TMRh20/RF24 library on GitHub and I uploaded the GetStarted sketch to the Arduino. Not sure if it is working but atleast a lot started happening in the Serial Monitor.
                    RF24/examples/GettingStarted
                    *** PRESS 'T' to begin transmitting to the other node
                    Sent response 16908288
                    Sent response 0
                    Sent response 1040677376
                    Sent response 0
                    Sent response 671495
                    Sent response 4294903807
                    Sent response 50331648
                    Sent response 65536
                    Sent response 16777292
                    Sent response 0
                    Sent response 33554434
                    Sent response 0
                    Sent response 167903239
                    Sent response 32639
                    Sent response 2
                    Sent response 512
                    Sent response 1057423360
                    Sent response 1057161279
                    Sent response 4294967295
                    Sent response 0
                    Then I pressed "T" in the Serial Monitor and then this happend:
                    *** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK
                    Now sending
                    failed
                    Failed, response timed out.
                    Now sending
                    Sent 127157552, Got response 0, Round-trip delay 1730592 microseconds
                    Now sending
                    Sent 129889960, Got response 0, Round-trip delay 3673784 microseconds
                    Now sending
                    Sent 134565556, Got response 0, Round-trip delay 4033292 microseconds
                    Now sending
                    Sent 139600664, Got response 0, Round-trip delay 4093332 microseconds
                    Now sending
                    Sent 144695808, Got response 0, Round-trip delay 16792 microseconds
                    Now sending
                    Sent 145714324, Got response 0, Round-trip delay 3975708 microseconds
                    Now sending
                    Sent 150691860, Got response 0, Round-trip delay 4035408 microseconds
                    Now sending
                    Sent 155729096, Got response 0, Round-trip delay 4196592 microseconds
                    Now sending
                    Sent 160927500, Got response 0, Round-trip delay 3815552 microseconds
                    To me it seems to work..
                      Christian SimonsenC
                      Christian Simonsen
                      Now I have also tried the original RF24 library by ManiacBug (link). And I got this results in the Serial Terminal.
                      STATUS		 = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
                      RX_ADDR_P0-1	x00 = 0x0000000000 0x0000000000
                      RX_ADDR_P2-5	x00 = 0x00 0x00 0x00 0x00
                      TX_ADDR		 = 0x0000000000
                      RX_PW_P0-6	x00 = 0x00 0x00 0x00 0x00 0x00 0x00
                      EN_AA		 = 0x00
                      EN_RXADDR	x00 = 0x00
                      RF_CH		 = 0x00
                      RF_SETUP	x00 = 0x00
                      CONFIG		 = 0x00
                      DYNPD/FEATURE	x00 = 0x00 0x00
                      Data Rate	 = 1MBPS
                      Model		 = nRF24L01
                      CRC Length	 = Disabled
                      PA Power	 = PA_MIN
                      From what I can understand the Arduino is able to send and receive responses (even though I only have one NRFmodule running... so not sure what is given the response to the NRF... )
                      Now sending 55497...ok...Got response 4294967295, round-trip delay: 55499
                      Now sending 56500...ok...Got response 4294967295, round-trip delay: 56502
                      Now sending 57502...failed.
                      Got response 4294967295, round-trip delay: 58083
                      Now sending 59082...failed.
                      Got response 4294967295, round-trip delay: 59675
                      Now sending 60675...ok...Got response 4294967295, round-trip delay: 60691
                      Now sending 61690...ok...Got response 4294967295, round-trip delay: 61692
                      Now sending 62693...ok...Got response 4294967295, round-trip delay: 62695
                      Now sending 63695...ok...Got response 4294967295, round-trip delay: 63711
                      On in the other mode I'm getting this...
                      Got payload 4294967295...Sent response.
                      The odd part is, why do I then not get the MySensor SerialGateway sketch to work... any thoughts?
                      • naviathanN
                        naviathanN
                        naviathan
                        This isn't working at all. First, yes you have fake chips, I have the same ones, but they work with the RF24 library just fine so far. Second, the payload should be either the current microseconds or a steadily incrementing number. The payload you're getting is the result of either bad power or incorrect pin out to your controller, usually the CE and CSN are wrong.
