  3. Knockoff Arduino Pro Mini not giving 3.3V
4 Posts 2 Posters 1.8k Views 2 Watching
  • cslauritsenC Offline
    cslauritsen
    I did my first build using one of the chinese knockoff arduino pro mini 3.3V from aliexpress. During the assembly process I powered the circuit thru an arduino uno connected to laptop USB. It also worked fine from a battery. Now the build part is done, I want to "deploy" the sensor with wall-wart power. On a wall wart, the sensor came up and successfully presented to the gateway. I got one or 2 readings transmitted from the sensor, but almost immediately thereafter, the radio traffic seemed to come to a halt. I noticed this only happened when powering from a wall wart.
    I suspected voltage ripple was affecting the radio and noticed I hadn't added a 4.7uF cap to the radio power pins. I added it, but it made no difference. Since it worked fine with battery power or arduino uno power, I did some voltage checks of 2 different cheap pro minis. When fed 5V on RAW, they output something like in the range of 4 to 4.8V on VCC. So I added a spare 3.3V regulator to my build and now everything works fine, even when powered with the wall wart.
    Has anyone had a similar experience? Am I missing something--I thought the 3.3V pro minis had a 3.3 regulator on them??
    PS The Pro Mini 3.3V from sparkfun I bought a while back ($10/each) puts out a steady 3.3V on VCC.
    • gerritvG Offline
      gerritvG Offline
      gerritv
      I would check the part number on the regulator. Just because it is sold as 3.3V mini doesn't mean that it is :-(
      Feeding >3.3VDC to the radio potentially made it give up its magic smoke.
        cslauritsen
        Thanks. I'll try to figure out where the regulator is on these things. It wan't patently obvious to me. Agreed, I may have hosed this radio.
        • gerritvG Offline
          gerritvG Offline
          gerritv
          The regulator has 3 terminals, on one side, 2 on the other. Usually near 2 'large' capacitors
