  3. Humidity repeater, easy question...?
3 Posts 2 Posters 1.1k Views 2 Watching
  • Mark SwiftM
    Mark SwiftM
    Mark Swift
    Hi Guys,
    I'm using the humidity sketch from the dev build. Quick question, to enable it as a repeater, so I simply add
    #define MY_REPEATER_FEATURE
    and change
    sleep(SLEEP_TIME); // Sleep (non repeater) to wait(SLEEP_TIME); // Sleep (non repeater)
    Is that all that's required?
    Mark
    • mfalkviddM
      You should also change
      to use wait, otherwise the node might drop packages during this time.
      • Mark SwiftM
        Mark SwiftM
        Mark Swift
        wrote on last edited by Mark Swift
        @mfalkvidd I currently have this, what do you suggest I change?
         * Version 1.0 - Henrik EKblad
         * This sketch provides an example how to implement a humidity/temperature
         * sensor using DHT11/DHT-22
        // Enable debug prints
        // #define MY_DEBUG
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        DHT dht;
        float lastTemp;
        float lastHum;
        boolean metric = true;
          sendSketchInfo("Temperature + Humidity", "1.0");
          present(CHILD_ID_HUM, S_HUM);
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            #ifdef MY_DEBUG
            Serial.print("T: ");
          if (isnan(humidity)) {
              lastHum = humidity;
              #ifdef MY_DEBUG
              Serial.print("H: ");
              Serial.println(humidity);
          // sleep(SLEEP_TIME); // Sleep (non repeater)
          // wait(SLEEP_TIME); // Wait (repeater)
        Edit: Apologies, I see what you're advising to do, I missed that line. I've made the change now.
