  3. [Solved] How disable sleep timer ?
7 Posts 3 Posters 2.1k Views 3 Watching
  • C Offline
    C Offline
    carlierd
    wrote on last edited by carlierd
    I am working on a keyboard project allowing to enter a code on 4 keys and as the keyboard as 16 touch, I will use key 10 to 16 as a scene controller.
    Everything is working correctly except a small thing. I use this sleep function:
    interuptionType = node.sleep(SDA_PIN - 2, FALLING, WAITING_TIME);
    The idea is to sleep between two keys of the code:
    • wait for the second key or
    • awake after 2 seconds if no key was pressed to cancelled the code.
    If the second key is greater than 9 I cancelled the code but the sleep of 2 seconds is still actif !
    How I can disable the sleep timer ? Is there a specific function ?
    Thanks for your help.
    David.
    • mfalkviddM Online
      mfalkviddM Online
      Look at the return value of the sleep function. It will show whether the wakeup reason. If the reason was timer, cancel just like you do after 9 presses.
      • C Offline
        C Offline
        carlierd
        Hello. It's what I done, no problem.
        I will try to clarify what happens:
        • User push key 0-9
        • Start sleep with interruption and 2 seconds timer
        • User push key 10 (before timer reach 2 seconds)
        • The software detects it and return (beginning of the loop)
        • At the beginning of the loop there is an interruption to wait a key and it seems that as the 2 seconds timer is finish the sleep is interrupted ...
        David.
        • M Offline
          M Offline
          m26872
          Post your sketch?
          Once awake you shouldn't need to do anything.
          • C Offline
            C Offline
            carlierd
            This is the code:
             * Code modified from AWI
             * (http://forum.mysensors.org/topic/3128/slim-node-scene-controller-keypad)
             * Buzzer code from Sparkfun
             * (SparkFun Inventor's Kit / Example sketch 11)
            /* Keyboard sensor.        */
            /* Version     : 1.4.10        */
            /* Date        : 15/04/2016                                                           */
            /* Modified by : David Carlier                                                        */
            /*                            RST |             |  A5                                 */
            /*                            RX  |             |  A4                                 */
            /*                            TX  |   ARDUINO   |  A3                                 */
            /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
            /*     Keyboard SDA --------- D3  |             |  A1                                 */
            /*     Keyboard SCL --------- D4  | ATMEGA 328p |  A0                                 */
            /*              +3v --------- VCC |             | GND --------- GND                   */
            /*              GND --------- GND |  8MHz int.  | REF                                 */
            /*                            OSC |             | VCC --------- +3v                   */
            /*                            OSC |             | D13 --------- RFM69 (SCK)           */
            /*                            D5  |             | D12 --------- RFM69 (MISO)          */
            /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
            /*                            D7  |             | D10 --------- RFM69 (NSS)           */
            /*              LED --------- D8  |             |  D9 --------- Buzzer                */
            /* +3v = 2*AA        */
            #include <MyTransportRFM69.h>
            //Constants for MySensors
            #define SKETCH_NAME           "Keyboard Sensor"
            #define SKETCH_VERSION        "1.4.10"
            #define CHILD_ID_DIGICODE     0
            #define KEYPAD_ID_SCENE       1
            #define CHILD_ID_VOLTAGE      2
            #define SDA_PIN               3
            #define SCL_PIN               4
            #define LED_PIN               8
            #define BUZZER_PIN            9
            #define BUZZ_FREQ_KEY         350
            #define BUZZ_TIME_KEY         100
            #define BUZZ_FREQ_ERROR       75
            #define KEYBOARD_SIZE         16
            #define MAX_SCENE             7
            #define BATTERY_FULL          3143    // 2xAA usually gives 3.143V when full
            #define BATTERY_ZERO          2340    // 2.34V limit for 328p at 8MHz
            //Length must equal the total number of notes and spaces
            const byte songLength = 18;
            //Notes is an array of text characters corresponding to the notes
            //in your song. A space represents a rest (no tone)
            char notes[] = "cdfda ag cdfdg gf "; // a space represents a rest
            //Beats is an array of values for each note and rest.
            //A "1" represents a quarter-note, 2 a half-note, etc.
            //Don't forget that the rests (spaces) need a length as well.
            int beats[] = {1,1,1,1,1,1,4,4,2,1,1,1,1,1,1,4,4,2};
            //The tempo is how fast to play the song.
            //To make the song play faster, decrease this value.
            int tempo = 113;
            //Misc. variables
            unsigned long WAITING_TIME = 2000; //Waiting time for key pressing
            boolean keyState[KEYBOARD_SIZE] ;
            //Construct MySensors library
            MySigningAtsha204Soft signer;
            MyHwATMega328 hw;
            MyTransportRFM69 transport;
            MySensor node(transport, hw, signer);
            MyMessage msgCode(CHILD_ID_DIGICODE, V_VAR1);
            MyMessage msgSceneOn(KEYPAD_ID_SCENE, V_SCENE_ON);
            MyMessage msgSceneOff(KEYPAD_ID_SCENE, V_SCENE_OFF);
            MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
            /* Initialization        */
              //Get time (for setup duration)
              #ifdef DEBUG
                unsigned long startTime = millis();
              //Setup buzzer and LED pins
              pinMode(BUZZER_PIN, OUTPUT);
              pinMode(LED_PIN, OUTPUT);
              blinkLedFastly(3);
              //Set keyboard pin
              pinMode(SDA_PIN,INPUT);
              pinMode(SCL_PIN, OUTPUT);
              digitalWrite(SCL_PIN, HIGH);
              //Start MySensors and send the Sketch Version Information to the Gateway
              node.begin();
              node.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
              //Register all sensors
              node.present(CHILD_ID_DIGICODE, S_CUSTOM);
              node.present(KEYPAD_ID_SCENE, S_SCENE_CONTROLLER);
              node.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
              //Load last Scenestates from EEPROM (7 scenestates available)
              for (int i = 0 ; i < MAX_SCENE; i++)
                keyState[i] = node.loadState(i);
                #ifdef DEBUG
                  Serial.print(" "); Serial.print(keyState[i]);
              //Setup done !
              blinkLedFastly(3);
              //Print setup debug
              #ifdef DEBUG
                int duration = millis() - startTime;
                Serial.println("");
                Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
            /* Main loop        */
              //Sleep, node wakes up on key interrupt
              byte interuptionType = node.sleep(SDA_PIN - 2, FALLING);
              //Verify if a key was pressed
              if (interuptionType == 0)
                return;
              //Get time (for a complete loop)
              #ifdef DEBUG
              //Get first digit
              byte key = getKeyPressed();
              tone(BUZZER_PIN, BUZZ_FREQ_KEY, BUZZ_TIME_KEY);
              //Check validity
              if (key == 0)
                blinkLedFastlyAndBuzz(3);
                return;
              //Inform user that key is valid
              blinkLedFastly(1);
              int digicode = key * 1000;
              //Check if key corresponds to a scene touch or a code
              if (key > 9)
                //Update scene state
                node.saveState(key - 10, (boolean)node.loadState(key - 10)?false:true);
                //Report data to the gateway
                long voltage = getVoltage();
                node.send(node.loadState(key - 10)?msgSceneOn.set(key - 10):msgSceneOff.set(key - 10));
                node.send(msgVolt.set(voltage / 1000.0, 3));
                int batteryPcnt = round((voltage - BATTERY_ZERO) * 100.0 / (BATTERY_FULL - BATTERY_ZERO));
                if (batteryPcnt > 100) {batteryPcnt = 100;}
                node.sendBatteryLevel(batteryPcnt);
                //Print debug
                #ifdef DEBUG
                  Serial.print("Scene ");
                  Serial.print(key - 10);
                  Serial.print(": ");
                  Serial.print((boolean)node.loadState(key - 10)?" 1 ":" 0 ");
                  Serial.print("   ");
                  Serial.print(voltage / 1000.0);
                  Serial.print(" v");
                  Serial.print("   ");
                  Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
                  Serial.flush();
                //Wait for next key pressed or WAITING_TIME without action
                  return;
                //Get second digit
                //Check validity
                if (key == 0 || key > 9)
                  return;
                blinkLedFastly(1);
                digicode = digicode + key * 100;
                  return;
                //Get third digit
                //Check validity
                  return;
                blinkLedFastly(1);
                digicode = digicode + key * 10;
                  return;
                //Get fourth digit
                //Check validity
                  return;
                blinkLedFastly(1);
                digicode = digicode + key;
                node.send(msgCode.set(digicode));
                //Print debug
                #ifdef DEBUG
                  Serial.print("Complete code: ");
                  Serial.print(digicode);
                  Serial.print("   ");
                  Serial.print(" v");
                  Serial.print("   ");
                  Serial.flush();
                //Play final song instead of sleeping
                playFinalSong();
                //node.sleep(1000);
            /* Allows to play the final song.                                                     */
            void playFinalSong()
              //Declare local variables
              int i, duration;
              // step through the song arrays
              for (i = 0; i < songLength; i++)
                // length of note/rest in ms
                duration = beats[i] * tempo;
                // is this a rest?
                if (notes[i] == ' ')
                  delay(duration);            // then pause for a moment
                else                          // otherwise, play the note
                  tone(BUZZER_PIN, frequency(notes[i]), duration);
                  delay(duration);            // wait for tone to finish
                delay(tempo/10);              // brief pause between notes
            /* takes a note character (a-g), and returns the corresponding frequency in Hz        */
            /* for the tone() function.                                                           */
            int frequency(char note)
              int i;
              const int numNotes = 8;  // number of notes we're storing
              // The following arrays hold the note characters and their
              // corresponding frequencies. The last "C" note is uppercase
              // to separate it from the first lowercase "c". If you want to
              // add more notes, you'll need to use unique characters.
              // For the "char" (character) type, we put single characters
              // in single quotes.
              char names[] = { 'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C' };
              int frequencies[] = {262, 294, 330, 349, 392, 440, 494, 523};
              // Now we'll search through the letters in the array, and if
              // we find it, we'll return the frequency for that note.
              for (i = 0; i < numNotes; i++)  // Step through the notes
                if (names[i] == note)         // Is this the one?
                  return(frequencies[i]);     // Yes! Return the frequency
              return(0);  // We looked through everything and didn't find it,
                          // but we still need to return a value, so return 0.
            /* Allows to get the pressed key.                                                     */
            byte getKeyPressed()
              //Get first bit
              digitalWrite(SCL_PIN, LOW);
              delayMicroseconds(100);
              //Read all keys
              for(int i = 0; i < KEYBOARD_SIZE; i++)
                keyState[i] = (digitalRead(SDA_PIN) == LOW);
              //Read keyboard table to find the pressed key
              byte keyPressed = -1;
              for(int i = 0 ; i < KEYBOARD_SIZE; i++)
                if (keyState[i])
                  keyPressed = i;
              //Return the result
              return (keyPressed + 1);
            /* Allows to fastly blink the LED.                                                    */
            void blinkLedFastly(byte loop)
              byte delayOn = 150;
              byte delayOff = 150;
              for (int i = 0; i < loop; i++)
                blinkLed(LED_PIN, delayOn);
                delay(delayOff);
            /* Allows to fastly blink the LED and to play a sound on the buzzer.                  */
            void blinkLedFastlyAndBuzz(byte loop)
              byte delayOn = 150;
                tone(BUZZER_PIN, BUZZ_FREQ_ERROR, delayOff);
                delay(delayOff);
            /* Allows to blink a LED.                                                             */
            void blinkLed(byte pinToBlink, int delayInMs)
              digitalWrite(pinToBlink,HIGH);
              delay(delayInMs);
              digitalWrite(pinToBlink,LOW);
            /* Allows to get the real Vcc (return value in mV).                                   */
            /* http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/   */
            long getVoltage()
              ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
              delay(50);  // Let mux settle a little to get a more stable A/D conversion
              //Start a conversion
              ADCSRA |= _BV( ADSC );
              //Wait for it to complete
              while (bit_is_set(ADCSRA, ADSC));
              //Compute and return the value
              uint8_t low  = ADCL;                  // must read ADCL first - it then locks ADCH
              uint8_t high = ADCH;                  // unlocks both
              result = 1125300L / result;           // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
              return result;                        // Vcc in millivolts
            Not very easy to explain the problem !
            David.
            • C carlierd
              This is the code:
              /*                            RST |             |  A5                                 */
              /*                            RX  |             |  A4                                 */
              /* +3v = 2*AA        */
              #define SDA_PIN               3
              #define SCL_PIN               4
              #define LED_PIN               8
              #define MAX_SCENE             7
              int tempo = 113;
              //Misc. variables
              MyHwATMega328 hw;
                #ifdef DEBUG
                blinkLedFastly(3);
                //Set keyboard pin
                node.begin();
                  #ifdef DEBUG
                //Setup done !
                blinkLedFastly(3);
                //Print setup debug
                #ifdef DEBUG
                  Serial.println("");
              /* Main loop        */
                  return;
                #ifdef DEBUG
                //Get first digit
                //Check validity
                if (key == 0)
                  return;
                blinkLedFastly(1);
                if (key > 9)
                  //Print debug
                  #ifdef DEBUG
                    Serial.print(": ");
                    Serial.print("   ");
                    Serial.print(" v");
                    Serial.print("   ");
                    Serial.flush();
                    return;
                  //Get second digit
                  //Check validity
                    return;
                  blinkLedFastly(1);
                    return;
                  //Get third digit
                  //Check validity
                    return;
                  blinkLedFastly(1);
                    return;
                  //Get fourth digit
                  //Check validity
                    return;
                  blinkLedFastly(1);
                  //Print debug
                  #ifdef DEBUG
                    Serial.print("   ");
                    Serial.print(" v");
                    Serial.print("   ");
                    Serial.flush();
                  playFinalSong();
                  //node.sleep(1000);
                int i, duration;
                  // is this a rest?
                int i;
                //Get first bit
                //Read all keys
                  if (keyState[i])
                    keyPressed = i;
                //Return the result
                byte delayOn = 150;
                  delay(delayOff);
                byte delayOn = 150;
                  delay(delayOff);
                delay(delayInMs);
              long getVoltage()
              David.
              M Offline
              M Offline
              m26872
              wrote on last edited by m26872
              @carlierd I can't see any delay (sleep) until you sleep with interrupt again after another. How's that working? When or how does the key reset and settle?
              • C Offline
                C Offline
                carlierd
                Hello @m26872 , I set some serial.print in the code and found that i need to add some node.sleep when an incorrect key is pushed. The problem was due to the fact that the interruption pin is still valid when i restart the loop function !
                David.
                12.2k
