  3. What solder paste are you guys using?
solder pastesoldersoldering
4 Posts 3 Posters 1.6k Views 2 Watching
  • S Offline
    Samuel235
    So then, as the title reads; what solder paste are you guys using when soldering IC's with no leads, QFP, DFN, SOP, etc etc.
    I'm looking around and all i can find is the chinese/hong kong stuff. I've heard its pretty bad so whats your solder paste of choice?
    While we're at it, what about your flux too?
    MySensors 2.1.1
    • S Offline
      for flux: usually no clean flux, rosin. liquid or gel, pen sometimes.
      • those on mysensors store work well for me.
      • I have other a bit more expensive like kester.
      but the cheap one work ok. depends what you do. No clean is very common, but not recomended if circuit is high impedance >1M. I have one board which will be high impedance, so I will take care ;)
      for solderpaste:
      • cheap chinese work well for me on some stuff. I didn't tried it for reflowing.
      • For reflowing, I use, more expensive, well known chipquick, and I try to respect his temperature curve for better performance! but not the same price! I use leaded no clean, it's for hobby, and easier to use and to have good result, so I have no problems with those concerns.
      • There is also kester, multicore brand.
      • F Offline
        F Offline
        Fabien
        For flux, usually JBC FL-15 from my local dealer. Clean with water. Very good results.
        • S Offline
          Samuel235
          I'm yet to venture into the world of expensive but quality solder and flux. I'm still using materials from Aliexpress. When i get into the more quality of boards i will bring in the extra cost of those high quality products.
          Thanks for your feedback guys!
          MySensors 2.1.1
          12.2k
