  3. Slim Node Si7021 sensor example
137 Posts 18 Posters 98.4k Views 20 Watching
  • m26872M m26872
    @rsachoc Great with pictures! It looks like you haven't enabled the pull-up resistors by filling the solder jumpers in the middle of the board? Like this: https://cdn.sparkfun.com/assets/3/f/6/5/a/52855764757b7f06478b4567.jpg
    rsachocR
    rsachocR
    rsachoc
    @m26872 oh! I didn't realise I needed to do that, could that be the problem? Do I just need to fill with solder the bit just below where the DA and "-" is?
    m26872M 1 Reply Last reply
    • rsachocR rsachoc
      m26872M
      m26872M
      m26872
      @rsachoc It's probably it. And yes, it's rigth there. Make sure all of the three small pads interconnect.
      rsachocR 1 Reply Last reply
      • m26872M m26872
        rsachocR
        rsachocR
        rsachoc
        @m26872 thanks! No time tonight, but a job for testing tomorrow.
        • D
          DavidZH
          You could also use the 328 pullups! I had an unwilling Chinese light sensor (MAX44099) that drew a lot of power either with the VCC on or off. Since it's battery powered that is undesireable.
          I used digitalWrite(SDA, LOW); digitalWrite(SCL, LOW); to tie the bus to ground. When the sensor wakes up, it writes HIGH to those pins and the bus is back online. Used a 500ms wait after this to let the sensors stabilise.
          That sensor is now on a 6µA sleep current and a average 128µA over 2 hours measured with a 2 minute sleep cycle.
          • rsachocR
            rsachocR
            rsachoc
            Tried it this evening, still no luck, let me see what I can get up to over the weekend.
            • D DavidZH
              m26872M
              m26872M
              m26872
              @DavidZH True, internal pull-ups (20k?) should probably be enough for the normal i2c use (short wires, low speed, etc). But I wonder if pull-ups are consuming any significant power during passive state like sleeping sensor. Of course it's a good solution in case there're issues preventing the bus from beeing silent. Or worse, pulled down continuously.
              What was your current before the change?
              I think 500ms awake is a lot.
              • rsachocR rsachoc
                m26872M
                m26872M
                m26872
                @rsachoc Crap. Maybe it's something else then.:disappointed:
                • D
                  DavidZH
                  I switch them off with a LOW write before the sensor goes to sleep and you're absolutely right about the wait time being very long. In this case I didn't mind because the sensor is powered by a solar panel.
                  I can't really remember what the exact value but it was an order of magnitude... I also used the voltage divider way to measure voltage because the Moteino has a regulator on board, so that upped the sleep current a little (10M resistor to keep the current low).
                  I went searching because the current went UP when I switched the power to the sensor off before sleep. Gammon.co.au is a very useful source, but I can't remember where I dug this hack up.
                  I will be making other battery sensors for inside with a HTU21d and I will post more on those in a 'My Project' mega gallery including measurements. (And dig around in the HTU datasheet for the start up time....)
                  • rollercontainerR
                    rollercontainerR
                    rollercontainer
                    According to the datasheet the absolute maximum time to get ready is 80ms.
                    • D
                      DavidZH
                      Thanx! Saves me a trip! :grin:
                      • rollercontainerR
                        rollercontainerR
                        rollercontainer
                        RTFM :-P
                        https://www.silabs.com/Support Documents/TechnicalDocs/Si7021-A20.pdf
                        Page 5
                        • rsachocR
                          rsachocR
                          rsachoc
                          Ok, so I messed up my previous sensor trying to solder the bridge (don't ask...) I have now (I think) soldered it and reconnected it, am now getting the following:
                          Serial started
                          Voltage: 3359 mV
                          send: 132-132-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=fail:0
                          send: 132-132-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=fail:1.5.4
                          send: 132-132-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
                          sensor started, id=132, parent=0, distance=1
                          send: 132-132-0-0 s=255,c=3,t=11,pt=0,l=15,sg=0,st=fail:EgTmpHumBat5min
                          send: 132-132-0-0 s=255,c=3,t=12,pt=0,l=10,sg=0,st=fail:1.0 151106
                          send: 132-132-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=fail:
                          find parent
                          send: 132-132-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                          send: 132-132-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=fail:
                          Node and 2 children presented.
                          I'm going to try get everything on a breadboard, but now I see fails, what's that all about?
                          PS will upload some pics of the soldered bridge...
                          • rsachocR rsachoc
                            Serial started
                            Voltage: 3359 mV
                            find parent
                            m26872M
                            m26872M
                            m26872
                            @rsachoc google "mysensors st fail"
                            • L
                              L
                              LastSamurai
                              I am currently trying to use that red 3.3v module too and it doesn't seem to work. I have the sketch from above running with the "normal" blue module where I remove the voltage converter so that it works at 3.3V without a problem.
                              Then I switched to the red one (with these small 3 solderpads connected) and the scl/sda lines switched (the order is different form the blue one) but the program gets stuck at the same position as above (without the st=fail's though). So I assume that
                              fails. Does anyone have one of these sensors up and running? Any ideas where the error is? Otherwise I guess I have to stick with the blue ones.
                              • L LastSamurai
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @LastSamurai
                                The red ones are HTU21D and need another library (they are different from the SI7021).
                                Use the Adafruit library for this module (look on their site for HTU21D).
                                • GertSandersG GertSanders
                                  @LastSamurai
                                  rsachocR
                                  rsachocR
                                  rsachoc
                                  @GertSanders hmmm I think I'm using that same one as @LastSamurai so I suspect that's the issue? It's the one linked in the first post
                                  I guess if that's the problem it should have been obvious to me, it even says HTU21D on mine! Silly me!
                                  • rsachocR rsachoc
                                    GertSandersG
                                    GertSandersG
                                    GertSanders
                                    @rsachoc
                                    Either one of these libraries will work with the HTU21D modules.
                                    Both modules do the same, but have different I2C adresses so you can actually use both at the same time (of you like to compare them), but you need different libraries to call each one.
                                    L 1 Reply Last reply
                                      @rsachoc
                                      L
                                      L
                                      LastSamurai
                                      @GertSanders Thanks, I don't know why I didn't realize that ;)
                                      I will try that out tomorrow.
                                      • L LastSamurai
                                        rsachocR
                                        rsachocR
                                        rsachoc
                                        @LastSamurai I'm having a go as well at updating the .ino file with the different library, but I'm not a coder so I'm "having a hack" - if you have any luck could you post your code?
                                        • rsachocR rsachoc
                                          L
                                          L
                                          LastSamurai
                                          wrote on last edited by LastSamurai
                                          #90
                                          @rsachoc Yes, I actually just tried it out and its working.
                                          Here is my code for now (just for testing):
                                          I basically just switched libraries
                                          by m26872, 20151109
                                          Changed by LastSamurai
                                          15052016
                                          #include <SparkFunHTU21D.h>
                                          #include <RunningAverage.h>
                                          //#define DEBUG
                                          #ifdef DEBUG
                                          #define NODE_ID 100             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
                                          #define CHILD_ID_TEMP 0
                                          #define CHILD_ID_HUM 1
                                          // #define SLEEP_TIME 15000 // 15s for DEBUG
                                          #define SLEEP_TIME 300000   // 5 min
                                          #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
                                          #define BATTERY_REPORT_CYCLE 2016   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
                                          #define VMIN 1900
                                          #define VMAX 3300
                                          #define AVERAGES 2
                                          int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
                                          int measureCount = 0;
                                          float lastTemperature = -100;
                                          int lastHumidity = -100;
                                          HTU21D humiditySensor;
                                            DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                                            DEBUG_PRINT("Voltage: ");
                                            DEBUG_PRINT(readVcc());
                                            DEBUG_PRINTLN(" mV");
                                            delay(500);
                                            DEBUG_PRINTLN(" *C");
                                            gw.begin(NULL, NODE_ID);
                                            gw.sendSketchInfo("TempHumTest2", "1.0 17052016");
                                            gw.present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
                                            DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
                                            raHum.clear();
                                            humiditySensor.begin();
                                            measureCount ++;
                                            batteryReportCounter ++;
                                            bool forceTransmit = false;
                                            if (measureCount > FORCE_TRANSMIT_CYCLE) {
                                              forceTransmit = true;
                                            // Read and print internal temp
                                            float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
                                            DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
                                            // Check battery
                                            if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
                                              long batteryVolt = readVcc();
                                              DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
                                              uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
                                              DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
                                              batteryReportCounter = 0;
                                            gw.sleep(SLEEP_TIME);
                                          // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                                          // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
                                          long readVcc() {
                                          // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
                                          double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
                                            unsigned int wADC;
                                            double t;
                                            // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
                                            ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
                                            ADCSRA |= _BV(ADEN);  // enable the ADC
                                            delay(20);            // wait for voltages to become stable.
                                            ADCSRA |= _BV(ADSC);  // Start the ADC
                                            while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
                                            wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
                                            t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
                                            return (t);   // The returned temperature in degrees Celcius.
                                           * Parameters
                                            bool tx = force;
                                            float temperature = humiditySensor.readTemperature();
                                            if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
                                              gw.send(msgTemp.set(temperature,1));
                                              measureCount = 0;
                                              DEBUG_PRINTLN("T sent!");
                                            int humidity = humiditySensor.readHumidity();
                                            raHum.addValue(humidity);
                                            if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
                                              gw.send(msgHum.set(humidity));
                                              lastHumidity = humidity;
                                              measureCount = 0;
                                              DEBUG_PRINTLN("H sent!");
