  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 456.1k Views 35 Watching
    moskovskiy82
    What about mq2 or mq135? Any experience? As a gas sensor will be more suitable detecting early fire
    epierreE 1 Reply Last reply
    • M moskovskiy82
      epierreE
      epierreE
      epierre
      please see what it does, this is not a gas sensor this only detect particle size whatever the gas...
      z-wave - Vera -> Domoticz
      • epierreE epierre
        moskovskiy82
        @epierre
        It still detects concentration. Both state CO detection. So in case of fire won't they detect the increase in concentration much faster that the particle sensor like Sharp’s GP2Y1010AU0F or alternative?
        alexsh1A 1 Reply Last reply
        • M moskovskiy82
          @epierre
          alexsh1A
          alexsh1A
          alexsh1
          @moskovskiy82 For a fire smoke, you can use pretty much any gas or particle sensor - there are a quite few gases formed during the burning process. MQ2 is highly sensitivity and has a fast response time. I can recommend it for a fire detection usage. However, I have been disappointed in MQ* sensors in general - there are not accurate, require 24h heat-up time, consume a lot of power etc. The only advantage is the price.
          To detect fire to can use a flame sensor - http://www.instructables.com/id/Flame-detection-using-Arduino-and-flame-sensor/
          • rollercontainerR
            rollercontainerR
            rollercontainer
            Can someone tell me how to read this line?
            float mq135_ro = 10000.0;    // this has to be tuned 10K Ohm
            Do I have to messure the sensor and adjust the variable or do I have to tune the resistance? If I have to do the first thing, when do I have to messure it? In warm state and clean air with a multimeter?
            • alexsh1A
              alexsh1A
              alexsh1
              #204
              @epierre Did you check out the airbeam, which is based on a more expensive sensor Shinyei PPD60PV?
              http://www.takingspace.org/airbeam-technical-specifications-operation-performance/
              They made a step-by-step manual about building the same on Shinyei PPD42NS. I took their code and stripped a few parts and this is what I am left with:
              #include  <SoftwareSerial.h>
              #include  <FlexiTimer2.h>
              int pin = 3;
              volatile  double  rawParticalCount;
              volatile  double  totalParticles  = 0;
              volatile  double  particleCountToDisplay  = 0;
              volatile  double  ratio = 0;
              volatile  uint16_t  timeCounter = 0;
              #define         numberOfPeaksRecording                            5
              volatile        uint32_t        previousPeaks[numberOfPeaksRecording];
              volatile        uint32_t        sumOfPreviousPeaks          = 0;
              volatile        uint32_t        instantGoal                         = 0;
              volatile        int32_t         delta                                     = 0;
              volatile        uint32_t        slowMovingAverage             = 0;
              volatile  boolean readyToSendData = false;
              void  setup() {
                  pinMode(pin,INPUT);
                  FlexiTimer2::set(1,1.0/10000,readPin);
                  FlexiTimer2::start();
              void  loop()  {
                  if(readyToSendData){
                              Serial.print(rawParticalCount,  DEC);
                              Serial.print("  Raw Particle  Count (0-10000) ");
                              Serial.print(ratio, DEC);
                              Serial.print("  Ratio (0-100%)  ");
                              Serial.print(particleCountToDisplay,  DEC);
                              Serial.print("  Particle  Count");
                              Serial.println("");
              void  readPin(){
                  if(digitalRead(pin) ==  LOW){
                      rawParticalCount++;
                  timeCounter++;
                  if  (timeCounter  ==  10000)
                      timeCounter=0;
                      //Changes are made  here  based on  Chris Nafis's code: http://www.howmuchsnow.com/arduino/airquality/grovedust/
                      ratio = rawParticalCount/100.0;
                      //Convert to  percentage, the shinyei reads 10milliseconds  to  90milliseconds  duration  for particles.  Basing on 10milliseconds, smallest  particle  assumingly  from  specification sheet.
                      //FlexiTimer2,  reads 10,000  readings  per second, which would be  1 reading per 100 microseconds. 100 readings  would be  10  milliseconds. Since Shinyei runs  at minimal 10  millisecond range.  I divided 10,000  readings  by  100 to  get 100.
                      //Good  example would be  rawPArticalCount  is  5000  half  of  the 10,000  readings were  active. 5000/100  would be  50  which translate to  50% low pulse occupancy.
                      totalParticles  = (1.1*pow(ratio,3)-3.8*pow(ratio,2)+520*ratio+0.62);
                      rawParticalCount  = 0;
                              //  shift counters  over, code  adapted from  template  provided  by  Mike  Taylor  and Joshua  Schapiro  from  Carnegie  Mellon  University's  CREATE  Lab
                              for (uint8_t  i = 0;  i < (numberOfPeaksRecording-1); i++)  {
                                      previousPeaks[i]  = previousPeaks[i+1];
                              previousPeaks[numberOfPeaksRecording  - 1]  = totalParticles;
                              for (uint8_t  i = 0;  i < numberOfPeaksRecording; i++)  {
                                      sumOfPreviousPeaks  +=  previousPeaks[i];
                              instantGoal = 2*sumOfPreviousPeaks;
                              delta = instantGoal - slowMovingAverage;
                              if  (delta  < -5000){
                                      slowMovingAverage = slowMovingAverage - 250;
                              } else  if  (delta  < -2500){
                                      slowMovingAverage = slowMovingAverage - 120;
                              } else  if(delta  < -1200){
                                      slowMovingAverage = slowMovingAverage - 60;
                              } else  if(delta  < -500){
                                      slowMovingAverage = slowMovingAverage - 25;
                              } else  if(delta  < -5){
                                      slowMovingAverage = slowMovingAverage - 5;
                              } else  if(delta  < -1){
                                      slowMovingAverage = slowMovingAverage - 1;
                              } else  if(delta  > 5000) {
                                      slowMovingAverage = slowMovingAverage + 500;
                              } else  if(delta  > 2500){
                                      slowMovingAverage = slowMovingAverage + 250;
                              } else  if(delta  > 1200){
                                      slowMovingAverage = slowMovingAverage + 120;
                              } else  if(delta  > 500){
                                      slowMovingAverage = slowMovingAverage + 50;
                              } else  if(delta  > 5){
                                      slowMovingAverage = slowMovingAverage + 5;
                              } else  if(delta  > 1){
                                      slowMovingAverage = slowMovingAverage + 1;
                              particleCountToDisplay  = slowMovingAverage;
                      readyToSendData = true;
              I have not adopted it for MySensors yet.
              I like moving average they use, but the values do not make sense to me:
              0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  53470.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 27.0000000000  Ratio (0-100%)  53970.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  54470.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 21.6200008392  Ratio (0-100%)  54970.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  55470.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 24.2800006866  Ratio (0-100%)  55970.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  56470.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 24.1200008392  Ratio (0-100%)  56970.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  57470.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 22.3199996948  Ratio (0-100%)  57970.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  58470.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 20.3600006103  Ratio (0-100%)  58970.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  59470.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 17.6299991607  Ratio (0-100%)  59970.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  60220.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 19.0499992370  Ratio (0-100%)  60720.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 0.0000000000  Ratio (0-100%)  60715.0000000000  Particle  Count
              0.0000000000  Raw Particle  Count (0-10000) 20.6599998474  Ratio (0-100%)  61215.0000000000  Particle  Count
              • epierreE
                epierreE
                epierre
                @alexsh1 the PPDN42 is for 1 micron and 2.5 micron , this one is for 0.5 micron
                airbeam has standard code: https://github.com/HabitatMap/AirCastingAndroidClient/blob/master/arduino/aircasting/aircasting_shinyeiPPD42NS.ino
                or I've not seen ?
                • epierreE epierre
                  or I've not seen ?
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @epierre this is not the air beam code. They introduced "do it yourself" consept similar to the airbeam but with a different sensor (shinyei ppd42ns)
                  • rollercontainerR
                    rollercontainerR
                    rollercontainer
                    Hey guys, I am struggeling to get the MQ135 to work. Is there a step by step howto? Or can someone answer my question from 3 days ago?
                    I would appreciate it very much.
                    • rollercontainerR rollercontainer
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @rollercontainer I followed David Gironi method to calibrate - it is described as follows:
                      Before you can use the sensor, it has to be calibrated. For this, connect the sensor to your circuit and leave it powered on for 12-24 h to burn it in. Then put it into outside air, preferably at 20°C/35% rel. hum. (humidity is not so crucial). Read out the calibration value as such
                      float rzero = gasSensor.getRZero();
                      Wait until the value has somewhat settled (30min-1h). Remember, this is an ADC measurement so you might not want to wait some time between reading the sensor and also do some averaging. Once you have determined your RZero, put it into the MQ135.h. Note: Different sensors will likely have different RZero!
                      #define RZERO 76.63
                      Congrats, you have calibrated the sensor and can now read the CO2 ppm value in your sketch
                      float ppm = gasSensor.getPPM();
                      rollercontainerR 1 Reply Last reply
                      • alexsh1A alexsh1
                        #define RZERO 76.63
                        rollercontainerR
                        rollercontainerR
                        rollercontainer
                        @alexsh1 Thx
                        Is "RZERO" the same as "mq135_ro" or is it a seperate variable? (ro = R0 = RZERO?)
                        rollercontainerR alexsh1A 2 Replies Last reply
                          @alexsh1 Thx
                          rollercontainerR
                          rollercontainerR
                          rollercontainer
                          So, obvious these are two variables. Wherefore is the mq135_ro? Is it the load resistor from signal to ground?
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @rollercontainer let's start from the basic - which MQ-135 do you have? A bare unit or with a logic controller and a variable resistor?
                            • alexsh1A alexsh1
                              rollercontainerR
                              rollercontainerR
                              rollercontainer
                              @alexsh1 I bought a breakout board and desoldered everything but the sensor and the 33Ohm resistor for the heating. Then I soldered a 10kOhm pulldown from analog signal out to ground.
                                @alexsh1 Thx
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @rollercontainer
                                Apologies for the confusion. @epierre did not use this library, but I have used MQ135.h library, but have not adopted it for MySensors and I did not like the sensor's reading jumping up and down.
                                In MQ135.h:
                                // Calibration resistance at atmospheric CO2 level
                                #define RZERO 394.5 //RZERO 76.63
                                I think the principle of RZERO is the same as mq135_ro
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @rollercontainer I have do not done any changes to my breakout board. Just tuning the variable resistor and that's it.
                                  One thing I noticed is that the sensor performs much better in enclosed premises (no windows and no doors). Alternatively, it has to be in the box or something. Any small light draft dramatically changing the readings.
                                  • alexsh1A alexsh1
                                    rollercontainerR
                                    rollercontainerR
                                    rollercontainer
                                    @alexsh1 I dont think so, in epierres sketch both values appear:
                                    https://github.com/empierre/arduino/blob/master/AirQuality-MQ135.ino#L25
                                    https://github.com/empierre/arduino/blob/master/AirQuality-MQ135.ino#L33
                                    So, what the heck is mq135_ro? And what to tune to?
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #216
                                      @epierre OK, I found a mistake in my Shinyei ppd42ns code. Basically, it produces pcs/0.01cf values (normally, anything from 2000 to 10000 per a 30 secs reading).
                                      This sensor use counting method to test dust concentration but not weight method, and the unit it pcs/L or pcs/0.01cf.
                                      This has to be converted into ug/m3 (the EPA standard)and then we can convert it into ppmv. I do not think dividing it by a volume factor is enough. Please see below updated code, which combines both ppd42ns and MH-Z14A sensors.
                                       * Dust Sensor for Shinyei ppd42ns
                                       * 1 : COMMON(GND)
                                       * 2 : OUTPUT(P2)
                                       * 3 : INPUT(5VDC 90mA)
                                       * 4 : OUTPUT(P1)
                                       * 5 : INPUT(T1)・・・FOR THRESHOLD FOR [P2] - not used
                                       * http://www.seeedstudio.com/wiki/images/4/4c/Grove_-_Dust_sensor.pdf
                                       *   connect the sensor as follows :
                                       *    Pin 4 of dust sensor PM1      -> Digital 6
                                       *    Pin 3 of dust sensor          -> +5V
                                       *    Pin 2 of dust sensor PM25    -> Digital 3
                                       *    Pin 1 of dust sensor          -> Ground
                                      * Contributor: epierre and alexsh1
                                      // Define a static node address, remove if you want auto address assignment
                                      #define NODE_ADDRESS_DUST   11
                                      #define NODE_ADDRESS_CO2    13
                                      #define CHILD_ID_DUST_PM10            0
                                      #define CHILD_ID_DUST_PM25            1
                                      #define CHILD_ID_DUST_PM10_MG_M3      2
                                      #define CHILD_ID_DUST_PM25_MG_M3      3
                                      #define DUST_SENSOR_DIGITAL_PIN_PM10  6
                                      #define DUST_SENSOR_DIGITAL_PIN_PM25  3
                                      #define CHILD_ID 0
                                      #define CO2_SENSOR_PWM_PIN 2
                                      unsigned long SLEEP_TIME = 30*1000; // Sleep time between reads (in milliseconds)
                                      //VARIABLES
                                      int val = 0;           // variable to store the value coming from the sensor
                                      float valDUSTPM25 =0.0;
                                      float lastDUSTPM25 =0.0;
                                      float valDUSTPM10 =0.0;
                                      float lastDUSTPM10 =0.0;
                                      unsigned long duration;
                                      unsigned long starttime;
                                      unsigned long endtime;
                                      unsigned long sampletime_ms = 30000;
                                      unsigned long lowpulseoccupancy = 0;
                                      float ratio = 0;
                                      long concentrationPM25 = 0;
                                      long concentrationPM10 = 0;
                                      float concentration = 0;
                                      float concentrationPM25_ugm3;
                                      float concentrationPM10_ugm3;
                                      int temp=273.5+22; //external temperature, if you can replace this with a DHT11 or better
                                      float ppmvPM25;
                                      float ppmvPM10;
                                      float valAIQ =0.0;
                                      float lastAIQ =0.0;
                                      unsigned long duration_co2;
                                      long co2ppm;
                                      MyMessage dustMsgPM10(CHILD_ID_DUST_PM10, V_LEVEL);
                                      MyMessage msgPM10(CHILD_ID_DUST_PM10_MG_M3, V_LEVEL);
                                      MyMessage dustMsgPM25(CHILD_ID_DUST_PM25, V_LEVEL);
                                      MyMessage msgPM25(CHILD_ID_DUST_PM25_MG_M3, V_LEVEL);
                                      MySensor gw1;
                                      MyMessage msg(CHILD_ID, V_LEVEL);
                                        gw.begin(NULL,NODE_ADDRESS_DUST,false);
                                        gw.sendSketchInfo("Dust Sensor PPD42NS", "1.5");
                                        gw.present(CHILD_ID_DUST_PM10, S_DUST);
                                        //gw.send(msgPM10.set("ppm"));
                                        gw.present(CHILD_ID_DUST_PM25, S_DUST);
                                        //gw.send(msgPM25.set("ppm"));
                                        gw.present(CHILD_ID_DUST_PM10_MG_M3, S_DUST);
                                        gw.present(CHILD_ID_DUST_PM25_MG_M3, S_DUST);
                                        pinMode(DUST_SENSOR_DIGITAL_PIN_PM10,INPUT);
                                        pinMode(DUST_SENSOR_DIGITAL_PIN_PM25,INPUT);
                                        gw1.begin(NULL,NODE_ADDRESS_CO2,false);
                                        gw1.sendSketchInfo("AIQ Sensor CO2 MH-Z14A", "1.0");
                                        gw1.present(CHILD_ID, S_AIR_QUALITY);
                                        pinMode(CO2_SENSOR_PWM_PIN, INPUT);
                                        //get PM 2.5 density of particles over 2.5 μm.
                                        concentrationPM25=(long)getPM(DUST_SENSOR_DIGITAL_PIN_PM25);
                                        Serial.print("PM25: ");
                                        Serial.print(concentrationPM25);
                                        Serial.println(" pcs/0.01cf");
                                        concentrationPM25_ugm3 = conversion25(concentrationPM25);
                                        Serial.print(concentrationPM25_ugm3);
                                        Serial.println(" ug/m3");
                                        Serial.print("\n");
                                        //ppmv=mg/m3 * (0.08205*Tmp)/Molecular_mass
                                        //0.08205   = Universal gas constant in atm·m3/(kmol·K)
                                        ppmvPM25=((concentrationPM25_ugm3) * ((0.08205*temp)/28.97));
                                        if ((concentrationPM25 != lastDUSTPM25)&&(concentrationPM25>0)) {
                                            gw.send(dustMsgPM25.set(ppmvPM25,2));
                                            gw.send(msgPM25.set(concentrationPM25_ugm3,2));
                                            lastDUSTPM25 = ceil(concentrationPM25);
                                       //get PM 1.0 - density of particles over 1 μm.
                                        concentrationPM10=getPM(DUST_SENSOR_DIGITAL_PIN_PM10);
                                        Serial.print("PM10: ");
                                        Serial.print(concentrationPM10);
                                        concentrationPM10_ugm3 = conversion10(concentrationPM10);
                                        Serial.print(concentrationPM10_ugm3);
                                        Serial.print("\n");
                                        ppmvPM10=((concentrationPM10_ugm3) * ((0.08205*temp)/28.97));
                                        if ((ceil(concentrationPM10) != lastDUSTPM10)&&((long)concentrationPM10>0)) {
                                            gw.send(dustMsgPM10.set(ppmvPM10,2));
                                            gw.send(msgPM10.set(concentrationPM10_ugm3,2));
                                            lastDUSTPM10 = ceil(concentrationPM10);
                                        while(digitalRead(CO2_SENSOR_PWM_PIN) == HIGH) {;}
                                        //wait for the pin to go HIGH and measure HIGH time
                                        duration_co2 = pulseIn(CO2_SENSOR_PWM_PIN, HIGH, 2000000);
                                        co2ppm = 5000 * ((duration_co2/1000) - 2)/1000;
                                        Serial.print("CO2: ");
                                        Serial.print(co2ppm);
                                        Serial.print(" ppm");
                                        Serial.print("\n");
                                        if ((co2ppm != lastAIQ)&&(abs(co2ppm-lastAIQ)>=10)) {
                                            gw1.send(msg.set((long)ceil(co2ppm)));
                                            lastAIQ = ceil(co2ppm);
                                        //sleep to save on radio
                                        gw.sleep(SLEEP_TIME);
                                        gw1.sleep(SLEEP_TIME);
                                      float conversion25(long concentrationPM25) {
                                        double pi = 3.14159;
                                        double density = 1.65 * pow (10, 12);
                                        double r25 = 0.44 * pow (10, -6);
                                        double vol25 = (4/3) * pi * pow (r25, 3);
                                        double mass25 = density * vol25;
                                        double K = 3531.5;
                                        return (concentrationPM25) * K * mass25;
                                      float conversion10(long concentrationPM10) {
                                        double r10 = 0.44 * pow (10, -6);
                                        double vol10 = (4/3) * pi * pow (r10, 3);
                                        double mass10 = density * vol10;
                                        double K = 3531.5;
                                        return (concentrationPM10) * K * mass10;
                                      long getPM(int DUST_SENSOR_DIGITAL_PIN) {
                                        starttime = millis();
                                        while (1) {
                                          duration = pulseIn(DUST_SENSOR_DIGITAL_PIN, LOW);
                                          lowpulseoccupancy += duration;
                                          endtime = millis();
                                          if ((endtime-starttime) > sampletime_ms)
                                          ratio = (lowpulseoccupancy-endtime+starttime)/(sampletime_ms*10.0);  // Integer percentage 0=>100
                                          concentration = 1.1*pow(ratio,3)-3.8*pow(ratio,2)+520*ratio+0.62; // using spec sheet curve
                                          Serial.print("lowpulseoccupancy:");
                                          Serial.print(lowpulseoccupancy);
                                          Serial.print("\n");
                                          Serial.print("ratio:");
                                          Serial.print(ratio);
                                          Serial.print("\n");
                                          //Serial.print("PPDNS42:");
                                          //Serial.println(concentration);
                                          //Serial.print("\n");
                                          return(concentration);
                                      Please see the terminal printout below. The lowpulseoccupancy and ratio are correct. um/m3 to ppmv conversion is correct as well. I had to dive into physics and a bit of googling to find out how to convert pcs/0.01cf into ug/m3 - this is a tricky one!
                                      send: 11-11-0-0 s=1,c=1,t=37,pt=7,l=5,sg=0,st=ok:5.39
                                      send: 11-11-0-0 s=3,c=1,t=37,pt=7,l=5,sg=0,st=ok:6.45
                                      lowpulseoccupancy:3339978
                                      ratio:11.03
                                      PM10: 6751 pcs/0.01cf
                                      PM10: 10.53 ug/m3
                                      send: 11-11-0-0 s=0,c=1,t=37,pt=7,l=5,sg=0,st=ok:8.80
                                      send: 11-11-0-0 s=2,c=1,t=37,pt=7,l=5,sg=0,st=ok:10.53
                                      CO2: 960 ppm
                                      send: 13-13-0-0 s=0,c=1,t=37,pt=4,l=4,sg=0,st=ok:960
                                      lowpulseoccupancy:1983280
                                      ratio:6.51
                                      PM25: 3527 pcs/0.01cf
                                      PM25: 5.50 ug/m3
                                      send: 11-11-0-0 s=1,c=1,t=37,pt=7,l=5,sg=0,st=ok:4.60
                                      send: 11-11-0-0 s=3,c=1,t=37,pt=7,l=5,sg=0,st=ok:5.50
                                      lowpulseoccupancy:3430970
                                      ratio:11.34
                                      PM10: 7008 pcs/0.01cf
                                      PM10: 10.93 ug/m3
                                      send: 11-11-0-0 s=0,c=1,t=37,pt=7,l=5,sg=0,st=ok:9.13
                                      send: 11-11-0-0 s=2,c=1,t=37,pt=7,l=5,sg=0,st=ok:10.93
                                      CO2: 960 ppm
                                      lowpulseoccupancy:1789340
                                      ratio:5.86
                                      PM25: 3141 pcs/0.01cf
                                      PM25: 4.90 ug/m3
                                      send: 11-11-0-0 s=1,c=1,t=37,pt=7,l=5,sg=0,st=ok:4.09
                                      send: 11-11-0-0 s=3,c=1,t=37,pt=7,l=5,sg=0,st=ok:4.90
                                      lowpulseoccupancy:3271804
                                      ratio:10.80
                                      PM10: 6563 pcs/0.01cf
                                      PM10: 10.23 ug/m3
                                      send: 11-11-0-0 s=0,c=1,t=37,pt=7,l=5,sg=0,st=ok:8.55
                                      send: 11-11-0-0 s=2,c=1,t=37,pt=7,l=5,sg=0,st=ok:10.23
                                      CO2: 970 ppm
                                      send: 13-13-0-0 s=0,c=1,t=37,pt=4,l=4,sg=0,st=ok:970
                                      I still have not connected the BMP280 to get the pressure and temp readings into the equation.
                                      What do you think?
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        I think https://github.com/empierre/arduino/blob/master/AirQuality-MQ135.ino#L25
                                        is identical to
                                        https://github.com/GeorgK/MQ135/blob/master/MQ135.h#L27 multiplied by a factor is 1000
                                        Maybe @epierre can clarify it?
                                        • rollercontainerR
                                          rollercontainerR
                                          rollercontainer
                                          wrote on last edited by rollercontainer
                                          #218
                                          Hm, in the loop, mq135_ro will be read and used. As written in line 78, the MQ135_DEFAULTRO can be overwritten by the messured mq135_ro. Ok, but where is the 10kOhm voltage divider in this calculation? Included in the measurement of mq135_ro?
                                          https://github.com/empierre/arduino/blob/master/AirQuality-MQ135.ino#L78
                                          12.5k
