  3. MyNodes.NET
  4. Remote Configuration
Scheduled Pinned Locked Moved MyNodes.NET
12 Posts 2 Posters 3.8k Views 3 Watching
  • TakeroT
    TakeroT
    Takero
    wrote on last edited by Takero
    I found this information in your Link before, but it needs to run it first local too! I want to do it remote from the begining. It is hard to get local Access to my rPi. That's my Problem.
    derwishD 1 Reply Last reply
    • TakeroT Takero
      derwishD
      derwishD
      derwish
      wrote on last edited by derwish
      @Takero Then, just edit WebController\project.json:
      "web": "Microsoft.AspNet.Server.Kestrel --server.urls http://localhost:1312"
      replace " http://localhost:1312" to your IP.
      Then start dnx web
      This line:
      https://github.com/derwish-pro/MyNodes.NET/blob/master/WebController/project.json#L31
      • TakeroT
        TakeroT
        Takero
        Thanks a lot! I will try that tomorow.
        • TakeroT
          TakeroT
          Takero
          It works!! Thanks!
          • TakeroT
            TakeroT
            Takero
            Now i have the Problem with the SerialGateway, what you described in your Troubleshoot . . . . I will try the last Beta ob Mono . . .
            I am using a Pi2+
            Edit: It does not work . . .
            GATEWAY: Gateway is not responding.
            • TakeroT Takero
              I am using a Pi2+
              derwishD
              derwishD
              derwish
              @Takero Really sad. I contacted Microsoft and they told that the problem must be sought in mono. Need to wait for mono to fix it. At the moment, you can only use Ethernet gateway.
              • TakeroT
                TakeroT
                Takero
                Yah thats realy sad . . i dont have Ethernet Gateway ;-) I still wait for a fix
                • TakeroT
                  TakeroT
                  Takero
                  Any news between mono Update?
                  • TakeroT Takero
                    derwishD
                    derwishD
                    derwish
                    @Takero Microsoft has updated the ASP.NET framework. I will soon make a port on it. I hope they fixed this bug.
                    TakeroT 1 Reply Last reply
                    • derwishD derwish
                      TakeroT
                      TakeroT
                      Takero
                      reply
                      Then is soon?
                      Alternativ i will try an other OS for my RPi
