  3. Mosquitto
Mosquitto
11 Posts 3 Posters 5.7k Views 3 Watching
    moskovskiy82
    In the logs i notice
    1465234765: New connection from ::1 on port 1883.
    1465234765: New client connected from ::1 as mosqsub/1701-homepi (c1, k60).
    1465234774: Socket error on client mosqsub/1701-homepi, disconnecting.
    1465234789: mosquitto version 1.3.4 terminating
    1465234789: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
    • M moskovskiy82
      @moskovskiy82 Maybe different Mosquitto versions?
      Caused me headaches in the past...
        moskovskiy82
        Touche... Will try to install a new one. Wonder if it is worth going MQTT path after this...
        Ubuntu
        libmosquitto0:amd64/trusty 0.15-2ubuntu1 uptodate
        libmosquitto1:amd64/trusty 1.4.9-0mosquitto1 uptodate
        mosquitto:amd64/trusty 1.4.9-0mosquitto1 uptodate
        mosquitto-clients:amd64/trusty 1.4.9-0mosquitto1 uptodate
        Raspbian
        libmosquitto1:armhf/jessie 1.3.4-2 uptodate
        mosquitto:armhf/jessie 1.3.4-2 uptodate
        mosquitto-clients:armhf/jessie 1.3.4-2 uptodate
        python-mosquitto:all/jessie 1.3.4-2 uptodate
        python3-mosquitto:all/jessie 1.3.4-2 uptodate
          moskovskiy82
          Well now i have a hedache as well..
          Updated to 1.4.8 freom http://repo.mosquitto.org/debian/mosquitto-jessie.list (as it seems the latest avail)
          Upgraded mosquitto and mosquitto clients
           $ apt-show-versions | grep mosquitto
          libmosquitto1:armhf/jessie 1.4.8-0mosquitto2 uptodate
          mosquitto:armhf/jessie 1.4.8-0mosquitto2 uptodate
          mosquitto-clients:armhf/jessie 1.4.8-0mosquitto2 uptodate
          And still i get
           1465238048: Config loaded from /etc/mosquitto/mosquitto.conf.
           1465238048: Opening ipv4 listen socket on port 1883.
           1465238048: Opening ipv6 listen socket on port 1883.
           1465238066: New connection from 127.0.0.1 on port 1883.
           1465238066: New client connected from 127.0.0.1 as mosqsub/1282-homepi (c1, k60).
           1465238078: Socket error on client mosqsub/1282-homepi, disconnecting.
          • M moskovskiy82
            And still i get
            @moskovskiy82 Did you try google'ing for the error?
            When I do, I get e.g. http://jpmens.net/2014/07/03/the-mosquitto-mqtt-broker-gets-websockets-support/#comment-1907704831
            Maybe that helps?
              moskovskiy82
              I tried. But i don't have any username/password
              Strange thing is that this is a fresh raspbian install (downloaded yesterday)
              persistence true
              • Harry van der WolfH
                Harry van der WolfH
                Harry van der Wolf
                wrote on last edited by Harry van der Wolf
                I had some issues as well and read somewhere that there was an issue with the mosquitto packages for raspberri, so I installed from git.
                wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
                sudo apt-key add mosquitto-repo.gpg.key
                cd /etc/apt/sources.list.d/
                for wheezy: sudo wget http://repo.mosquitto.org/debian/mosquitto-wheezy.list
                for jessie: sudo wget http://repo.mosquitto.org/debian/mosquitto-jessie.list
                apt-get update
                apt-get install mosquitto
                sudo /etc/init.d/mosquitto start
                All working flawless for months now.
                  moskovskiy82
                  This i what i did above to solve the old version problem
                  Installed from http://repo.mosquitto.org/debian/mosquitto-jessie.list
                  With no luck.
                  Turning debug i see the following only
                  1465240376: mosquitto version 1.4.8 terminating
                  1465240386: New connection from 127.0.0.1 on port 1883.
                  1465240386: New client connected from 127.0.0.1 as mosqsub/1948-homepi (c1, k60).
                  1465240386: Sending CONNACK to mosqsub/1948-homepi (0, 0)
                  1465240386: Received SUBSCRIBE from mosqsub/1948-homepi
                  1465240386:     mygateway1-out/# (QoS 0)
                  1465240386: Sending SUBACK to mosqsub/1948-homepi
                  1465240419: Socket error on client mosqsub/1948-homepi, disconnecting.
                  Not that much of a help...
                    moskovskiy82
                    What is also strange i tried to start mosquitto with
                    sudo mosquitto -c /etc/mosquitto/mosquitto.conf -v
                    Than on the second console i tried
                    mosquitto_sub -v -t 'mygateway1-out/#'
                    and also
                    Strange thing is that id didn't see any messages in cosole. In the log file
                    1465242491: mosquitto version 1.4.8 (build date Tue, 17 May 2016 11:26:59 +0100) starting
                    1465242491: Config loaded from /etc/mosquitto/mosquitto.conf.
                    1465242491: Opening ipv4 listen socket on port 1883.
                    1465242491: Opening ipv6 listen socket on port 1883.
                    1465242495: New connection from ::1 on port 1883.
                    1465242495: New client connected from ::1 as mosqsub/1848-homepi (c1, k60).
                    1465242495: Sending CONNACK to mosqsub/1848-homepi (0, 0)
                    1465242495: Received SUBSCRIBE from mosqsub/1848-homepi
                    1465242495:     mygateway1-out/# (QoS 0)
                    1465242495: mosqsub/1848-homepi 0 mygateway1-out/#
                    1465242495: Sending SUBACK to mosqsub/1848-homepi
                    1465242527: Socket error on client mosqsub/1848-homepi, disconnecting.
                    1465242530: New connection from ::1 on port 1883.
                    1465242530: New client connected from ::1 as mosqpub/1850-homepi (c1, k60).
                    1465242530: Sending CONNACK to mosqpub/1850-homepi (0, 0)
                    1465242530: Received PUBLISH from mosqpub/1850-homepi (d0, q0, r0, m0,     'mygateway1-in/99/0/1/0/40', ... (6 bytes))
                    1465242530: Received DISCONNECT from mosqpub/1850-homepi
                    1465242530: Client mosqpub/1850-homepi disconnected.
                    1465242536: mosquitto version 1.4.8 terminating
                    • M moskovskiy82
                      and also
                      @moskovskiy82 can you subscribe and publish something on the pc? Then do the same on the rpi. At least that should work...
