  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 676.6k Views 99 Watching
  • meju25M meju25
    @Denke
    If I understand correctly, you are suggesting to combine different sensor types in one thing.
    IMHO this would jeopardize the concept of the binding. The binding provides one thing per message type (see https://www.mysensors.org/download/serial_api_15). the thing has one channel per supported sub type.
    I also do not see the advantage of combining different sensor/message types in one thing as you need one item per channel anyhow.
    => this would not reduce the number of items needed.
    Grouping the items in the site map - as you already did - is the best way here.
    Does anybody see this differently?
    Denke
    @meju25 I saw this from a management perspective.
    I have one device, my pool controller, that has multiple sensors and also channels per sensor just as HVAC that has a sum of channels. In my case i implemented a number of sensors in different types of channels "S_HVAC, S_LIGHT,...." what i see that it gets messy when you try to see if the channels are active or the pool control is active it has multiple sensors.
    So maybe a suggestion is to maybe implement this in the mysensors instead of in the openhab binding.
    In that case i would like to add something that allows me to tell what channels are in a "sensor" by combining differnt channels and sensor types.
    I don't know if i got my message through.
    But all this is mainly for management of my devices so that this gets less messy
    RaspberryPi-Openhab
    • dakkyD
      dakkyD
      dakky
      @TimO do you plan to implement the reconnect thing? I often have to struggle with that and the only solution is the restart the openhab service :S Is there a problem with the reconnect or is it just "another task on the todo list"?
      Greetings
      Dakky
      Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
      Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
      Software: MySensors 2.0development
      • D
        Denke
        Hi
        Is there anybody that have had a problem with the S_BARO and the V_PRESSURE channel?
        I try to send a value on this channel as 1.2 I can see that the serial gateway receives it
        23:10:51.808 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 0;0;3;0;9;read: 163-163-0 s=10,c=1,t=4,pt=7,l=5,sg=0:1.2
        I set up the channel as i have done for alot of other channels through the paper ui. where i link the channel to an item.
        The item file looks like this
        String Pool_Pressure "Pressure [%s]" <pressure> (gPool)
        the sitemap file looks like this
        Text item=Pool_Pressure
        result is this
        0_1466111768156_upload-9d8b8d90-c258-4979-b27f-0162a9ffcdc5
        The field never gets updated.
        any suggestions?
        RaspberryPi-Openhab
        D 1 Reply Last reply
        • D Denke
          Hi
          result is this
          any suggestions?
          Denke
          @Denke
          I cant find V_PRESSURE connected to CHANNEL_BARO below, can that be the reason?
          0_1466112268981_upload-f457bebe-d1b9-41d0-9f82-a7c55307e5d5
          RaspberryPi-Openhab
          • T
            TimO
            @Denke : You're right, the pressure channel was missing in the thing definition. This is fixed in the current version!
            @dakky : Which gateway type keeps disconnecting and why? I've a serial and ethernet gateway running side by side in OH2 and both didn't get disconnected so far. The hardest part is to recognize if the connection gets down.
            G dakkyD 2 Replies Last reply
            • T TimO
              G
              G
              gonzalonal
              Hi @TimO . Are you having both gateways connected to same the OH simultaneously?
              Any troubles with that? I imagine you should have different radio channels for each gateway, right? like two separate sensors networks.
              • G gonzalonal
                TimO
                Hi @gonzalonal !
                Only the ethernet gateway has an attached radio.
                Here is my current (MySensors) setup:
                Bridge mysensors:bridge-eth:MySGW [ ipAddress="192.168.2.99", tcpPort=5003, sendDelay=100, skipStartupCheck=true  ] {
                	humidity        bathHum01   			[ nodeId="101", childId="0" ]
                    temperature     bathTemp01  			[ nodeId="101", childId="1" ]
                    humidity		bathBat01				[ nodeId="101", childId="255" ]
                    humidity        bedHum01   				[ nodeId="103", childId="2" ]
                    temperature     bedTemp01  				[ nodeId="103", childId="1" ]
                    humidity		bedBat01				[ nodeId="103", childId="255" ]
                    humidity        workHum01  				[ nodeId="104", childId="2" ]
                    temperature     workTemp01 				[ nodeId="104", childId="1" ]
                    humidity		workBat01				[ nodeId="104", childId="255" ]
                    humidity        kitchenHum01			[ nodeId="105", childId="2" ]
                    temperature     kitchenTemp01			[ nodeId="105", childId="1" ]
                	humidity		kitchenBat01			[ nodeId="105", childId="255" ]
                    humidity        childHum01 				[ nodeId="107", childId="3" ]
                    temperature     childTemp01				[ nodeId="107", childId="4" ]
                    light			childLight01			[ nodeId="107", childId="0" ]
                    light			childLight02			[ nodeId="107", childId="1" ]
                    light			childLight03			[ nodeId="107", childId="2" ]
                    humidity        guestHum01				[ nodeId="106", childId="0" ]
                    temperature     guestTemp01				[ nodeId="106", childId="1" ]
                	light			guestPresence01			[ nodeId="106", childId="3" ]
                    light			livingLight01			[ nodeId="106", childId="4" ]
                    light			livingLight02			[ nodeId="106", childId="5" ]
                    light			livingLight03			[ nodeId="106", childId="6" ]
                    light			livingLight04			[ nodeId="106", childId="7" ]
                    light			corridorLight03			[ nodeId="106", childId="8" ]
                    light			livingLight06			[ nodeId="106", childId="9" ]
                    humidity        livingHum01				[ nodeId="108", childId="2" ]
                    temperature     livingTemp01			[ nodeId="108", childId="1" ]
                	humidity		livingBat01				[ nodeId="108", childId="255" ]
                	humidity        gardenHum01				[ nodeId="110", childId="2" ]
                    temperature     gardenTemp01			[ nodeId="110", childId="1" ]
                	humidity		gardenBat01				[ nodeId="110", childId="255" ]
                	motion			gardenMotion01			[ nodeId="110", childId="3" ]
                Bridge mysensors:bridge-ser:MySGWKeller [ serialPort="/dev/ttyUSB0", sendDelay=100, skipStartupCheck=true ] {
                    cover			kitchenShutter02 	[ nodeId="0", childId="0" ]
                    cover			kitchenShutter03	[ nodeId="0", childId="1" ]
                    cover			livingShutter01 	[ nodeId="0", childId="2" ]
                    cover			livingShutter02 	[ nodeId="0", childId="3" ]
                    cover			kitchenShutter01 	[ nodeId="0", childId="4" ]
                    light			corridorLight01		[ nodeId="0", childId="5" ]
                    light			corridorLight02		[ nodeId="0", childId="6" ]
                    power			corridorLight01watt	[ nodeId="0", childId="7" ]
                G 1 Reply Last reply
                • T TimO
                  dakkyD
                  dakkyD
                  dakky
                  @TimO
                  I'm using a ethernet gateway.
                  the problem is: if the sensors gateway gets restarted/disconnected/updated/whatever the binding does not reconnect. The only way to fix that, is to restart openhab in order to force the binding to connect again.
                  Detecting an disconnect is really that hard? in the worst case, what about simply reconnecting timebased? not as cute as only reconnect when nessecary but a dirty quickfix.
                  • T TimO
                    Hi @gonzalonal !
                    G
                    G
                    gonzalonal
                    Thanks @TimO. Now I get it.
                    What do you think about having two gateways, one with NRF radio and the other one with RFM69 radio?
                    Will the binding support both gateways simultaneusly with no issues?
                    Another question..Will you support HearbeatRequest for the development branch?
                    Thanks, regards.
                    • G
                      G
                      gonzalonal
                      wrote on last edited by gonzalonal
                      #239
                      Hello againg.
                      I have updated my OH2 to latest nightbuild from cloudbees, and also updated to lastest realease of OH2 MyS Binding.
                      Now, I am facing an issue, that everytime that OH2 starts, it sends out all the items status to its respective node. This is causing, for example, to open my gates, or lowering my rollershutters, even disabling/enabling my alarm system. So I have shutdown OH2 for time being.
                      Have anyone faced this behavior before?
                      This is some of the log:
                      15:41:40.241 [WARN ] [ome.core.thing.internal.ThingManager] - Initializing handler for thing 'mysensors:bridge-ser:gateway' takes more than 5000ms.
                      15:41:40.272 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.295 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.322 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.335 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.348 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.362 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.375 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.388 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.402 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.545 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Home.items'
                      15:41:40.671 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.685 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.697 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.710 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.724 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.738 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.755 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.768 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.783 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.806 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 0;255;3;0;14;Gateway startup complete.
                      15:41:40.811 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.856 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.871 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.885 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.898 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.914 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.928 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:40.941 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:41.029 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 2;3;1;0;0;
                      15:41:41.110 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                      15:41:41.288 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 3;253;1;0;2;
                      15:41:41.546 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 1;6;1;0;2;
                      15:41:41.799 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 3;252;1;0;24;REFRESH
                      15:41:42.052 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 3;254;1;0;2;
                      15:41:42.307 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 1;254;1;0;2;
                      15:41:42.562 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 3;3;1;0;2;
                      15:41:42.817 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 1;253;1;0;2;
                      15:41:43.073 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 2;252;1;0;24;REFRESH
                      I would really appreciate your help.
                      • G gonzalonal
                        Hello againg.
                        TimO
                        @gonzalonal I have no idea why this should happen. The binding isn't that smart to do something like that. I've done a complete fresh installation on 21.06. with the nightly build from cloudbees and don't see this issue.
                        @dakky Do you see disconnection messages in the log? The binding already tries to detect a disconnect and tries to reestablish the connection when an ethernet gateway is used. Currently the time within a reconnect would be successful is very small due to sleep limitations of threads in OH2 bindings.
                        • T TimO
                          G
                          G
                          gonzalonal
                          Thanks @TimO . I will try to make a progressive installation and try to figure out what is causing this behavior.
                          I'll let you know if I find out.
                          Have you read my previous message?
                          Regards
                          Thanks, regards.
                          • G gonzalonal
                            Regards
                            Thanks, regards.
                            TimO
                            @gonzalonal : I just downloaded the recent version of the binding again and I don't see this behaviour.
                            I hope both gateways will work together! This is was the idea. I've not tested it in combination with RFM69 but I don't see a reason why this should not work! :-)
                            • T TimO
                              G
                              G
                              gonzalonal
                              @TimO I have solved my probles using OH2 Beta3 and the last release of the MyS binding.
                              It seems that the problem is only reproduced with the last release of OH2 from Cloudbees. At least withe the release 372.
                              Have you tryed it?
                              • K
                                K
                                kolaf
                                After a full computer crash (overheated CPU, CPU fan stopped working) I'm trying to set everything up on a new computer. Using the latest openhab2 beta 3 I'm having issues with using this binding. Specifically, whenever I add my standard thing configuration I get a buffer overflow in openhab which results in a core dump.
                                I have downloaded latest binding from the link at github, but that did not affect it. In addition to this binding I am using the zwave binding and rfxcom binding. All three connect to devices through serial ports, although I I'm not sure if they do it in the same way.
                                You may recall that I have had trouble using these three bindings together earlier, but for some reason things worked out and it has worked quite reliably since then.
                                I'm not sure which information from the system crash is useful, but if there is anything I can send you to help you figure out what happens, let me know. Also, I realise that this problem might not be related directly with mysensors, but maybe with the serial library used (I saw a reference to NVJavaSeria in the stack trace after the crash.
                                • K
                                  K
                                  kolaf
                                  Hello again.
                                  As a temporary fix I found a simple TCP/serial Gateway Python snippet that handles the connection to the serial mysensors device and provides a TCP interface to openhab. Switching the binding of aggression from serial to socket and having it connected to this software gateway removes the core dump issue. This confirms my suspicions that the issues are with the serial port library.
                                  It works okay as a workaround until someone figure something out :-)
                                  If anyone else is having issues with the serial connection, this is the by then snippet I found and used:
                                  https://github.com/pyserial/pyserial/blob/master/examples/tcp_serial_redirect.py
                                  • T
                                    TimO
                                    @kolaf I'm only using one serial gw and that is running rock stable within OH2. My last update was 22 days ago, so maybe it is time for an update again. :-)
                                    I recently changed my job, so I'm a little low in time at the moment. :-(
                                    • Fredrik JönssonF
                                      Fredrik JönssonF
                                      Fredrik Jönsson
                                      From what i can see this binding is not part of the official bindings for openHAB. Are there any plans to try to get this as a official binding for openhab?
                                      /Fredrik
                                      • Fredrik JönssonF Fredrik Jönsson
                                        /Fredrik
                                        TimO
                                        @Fredrik-Jönsson : Yes, this is on my to do list with high priority. I've done some preparations but need to contact the OH2 developers before creating a PR.
                                        Fredrik JönssonF 1 Reply Last reply
                                        • G gonzalonal
                                          Have you tryed it?
                                          TimO
                                          @gonzalonal :
                                          I've found the time to sync my repository with upstream master OH2. Now I do see the behaviour you described above. The status of every item is send out at startup.
                                          Using the current package of the MySensors binding from today with an older version of OH2 does work fine. But my development environment now throws out the status of all things.
                                          Are you using any other bindings? Are they working fine?At first I need to find out if this problem only occures with the MySensors binding or if there is a bug. ;-)
