  3. Problem with multiple relays and delays
16 Posts 6 Posters 5.9k Views 6 Watching
  • zrom69Z
    zrom69Z
    zrom69
    hi friends which works for 3 motorized shutters and how Arduino thank you
    parachutesjP 1 Reply Last reply
    • zrom69Z zrom69
      parachutesjP
      parachutesjP
      parachutesj
      @zrom69 is this a question or statement?
      • zrom69Z
        zrom69Z
        zrom69
        I'm sorry for my English, I'm French
        I try to control node 3 and motorized shutters which card must be used aduino thank you
        :smiley:
        • zrom69Z zrom69
          :smiley:
          parachutesjP
          parachutesjP
          parachutesj
          @zrom69 no worries.
          I am using arduino Nano but others will work too. The Nano is small enough and easy to program (it has USB). The Pro Mini is also a good option, but needs extra programer (it has only serial connectors).
          I am using those and all work very well:
          http://www.banggood.com/5Pcs-ATmega328P-Nano-V3-Controller-Board-For-Arduino-Improved-Version-p-951797.html
          In addition you need the relays - you either could build that yourself or use ready to use ones:
          http://www.banggood.com/5V-4-Channel-Relay-Module-For-Arduino-PIC-ARM-DSP-AVR-MSP430-Blue-p-87987.html
          If you want to control shutters, you usually need 1 relay per direction. so for your 3 shutters it would be 6 relays. I am not sure if there are products out there, you could take one with 8 relays if you do have the space or make them yourself.
          The code I posted above is "ready" for 3 shutters (up/down each) and manual control buttons on an Arduino Nano.
          you need to connect the relays on digital pins 3/4 & 5/6 & 7/8 and the manual inputs on analog A0/A1, A2/A3, A4/A5 (note: pin 14 makes out of Analog A0, a digital D14)
          Besides this, connect the radio and power and you should be ready to go.
          • zrom69Z
            zrom69Z
            zrom69
            Hi friends
            thank you for your help I have try the code on Arduino pro mini touts the relay they work or even monument must change something in the code Arduino
            I am newbie in Arduino
            there is detection of door opening
            thanks for the help
            • ihtgtwtdI
              ihtgtwtdI
              ihtgtwtd
              hi @parachutesj hi @all
              i tried the sketch posted above. it works but my relay board is active low and the relays are on when they should be off. #define RELAY_ON 0 and #define RELAY_OFF 1 do not change the behavior. the relays stay on. do you have an idea what is happening? thx
              • ihtgtwtdI ihtgtwtd
                parachutesjP
                parachutesjP
                parachutesj
                @ihtgtwtd
                change in the code in the routines shutters UP/DOWN/STOP
                the parts
                digitalWrite(RELAYxxx, HIGH);
                HIGH to LOW and vice versa
                SJ
                ihtgtwtdI 1 Reply Last reply
                • parachutesjP parachutesj
                  @ihtgtwtd
                  the parts
                  SJ
                  ihtgtwtdI
                  ihtgtwtdI
                  ihtgtwtd
                  thanks for the quick reply. I did what you suggested and the switches work the right way but when I reset the arduino all relay contacts turn on and stay on until I give a command. this is a major problem, it will destroy the shutter motor. i think there is no defined case when the arduino powers on.
                    parachutesjP
                    parachutesjP
                    parachutesj
                    @ihtgtwtd
                    put this into the setup routine within the "for"
                    digitalWrite (pin, HIGH);
                    e.g. like this:
                     for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
                        gw.present(sensor, S_COVER);
                        pinMode(pin, OUTPUT);
                      @ihtgtwtd
                      e.g. like this:
                      ihtgtwtdI
                      ihtgtwtdI
                      ihtgtwtd
                      @parachutesj
                      thank you very much. looks good now.
                      12.5k
