  3. How do I turn a Pin to HIGH from controller?
3 Posts 3 Posters 1.2k Views 3 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I thought it would be really easy but I can't understand how to do this simple task. I have a Led connected so if Pin 9 = High it turns on.
    But how can I write the sketch so that I can control the Led from my controller (domoticz) ?
    I have started with this by modifying the motion-sketch:
    #define LIGHT_PIN 9
    #define SECONDARY_CHILD_ID 4
    // Initialize motion message
    MyMessage msg2(SECONDARY_CHILD_ID, V_LIGHT);
      pinMode(LIGHT_PIN, OUTPUT);
    void presentation()  {
      sendSketchInfo("Motion Sensor ikea", "1.0");
      present(CHILD_ID, S_MOTION);
      present(SECONDARY_CHILD_ID, S_LIGHT);
    But nothing happens when I press the on/off switch that appears in domoticz witch kind of makes sense as I guess I need to add something in the loop. But how do do that? Are there some kind of " if [message-from-controller] then do this - command?
    And why does not the PIR show up in domoticz? I have only added a few lines, does that disable the original PIR code in someway.
    • fetsF
      fetsF
      fets
      @Cliff-Karlsson you need to manage incoming message from gateway/controller : (function void receive(const MyMessage &message) { ...}) and to chage pin state according message .
      See this example.
      I thing that domoticz needs at least 1 data message to show device
      • nielsokkerN
        nielsokkerN
        nielsokker
        There is an example that exactly gives you what you need. The Relay example is the structure of what you need to use.
