  3. USB gateway for 433MHz
3 Posts 3 Posters 2.3k Views 3 Watching
  • fhenrycoF
    fhenrycoF
    fhenryco
    Hello
    i have ordered the 2.4 GHz RF transmitters and waiting for them but for the time being i only have those 433 MHz
    http://www.ebay.com/itm/380717845396?rmvSB=true
    and would like to try them with the USBgateway sketch on my nano arduino (mini pro sensor side) and domoticZ . How should i modify the sketch for those simple 433 MHz RF ?
    Thanks in advance
    • fhenrycoF fhenryco
      Hello
      Thanks in advance
      @fhenryco sorry, but 433mhz senders & receivers are not supported by the mysensors network.
      For these to work you would need low-level drivers etc and these are not part of mysensors.
      Once you get the 2.4ghz modules, you can build a bridge using 433mhz to mysensors.
      • janvier123J
        janvier123J
        janvier123
        Take a look at this, works pretty good for me
        //#define MY_REPEATER_FEATURE
        #include <RCSwitch.h>
        RCSwitch mySwitch = RCSwitch();
        #define RELAY_1  1  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        #define NUMBER_OF_RELAYS 18 // Total number of attached relays
        #define SLEEP_BETWEEN_ALL_ON 100
        #define SLEEP_BETWEEN_ALL_OFF 100
        void before()
            //-----------pinMode(pin, OUTPUT);
            //-----------digitalWrite(pin, loadState(sensor)?RELAY_ON:RELAY_OFF);
          // Transmitter is connected to Arduino Pin #10
          mySwitch.enableTransmit(8);
          // Optional set pulse length.
          // mySwitch.setPulseLength(320);
          sendSketchInfo("RF 433Mhz", "1.0");
            present(sensor, S_BINARY);
          if (message.type==V_STATUS)
            // Switch on:
            // The first parameter represents the setting of the first rotary switch.
            // In this example it's switched to "1" or "A" or "I".
            // The second parameter represents the setting of the second rotary switch.
            // In this example it's switched to "4" or "D" or "IV".
            // 1 = channel A
            // 2 = channel B
            // 3 = channel C
            // 4 = channel D
            switch (message.sensor-1+RELAY_1)
                case 1:
                  if(message.getBool() == 1){mySwitch.switchOn(1, 1);}else{mySwitch.switchOff(1, 1);}
                case 2:
                  if(message.getBool() == 1){mySwitch.switchOn(1, 2);}else{mySwitch.switchOff(1, 2);}
                case 3:
                  if(message.getBool() == 1){mySwitch.switchOn(1, 3);}else{mySwitch.switchOff(1, 3);}
                case 4:
                  if(message.getBool() == 1){mySwitch.switchOn(1, 4);}else{mySwitch.switchOff(1, 4);}
                case 5:
                  if(message.getBool() == 1){mySwitch.switchOn(2, 1);}else{mySwitch.switchOff(2, 1);}
                case 6:
                  if(message.getBool() == 1){mySwitch.switchOn(2, 2);}else{mySwitch.switchOff(2, 2);}
                case 7:
                  if(message.getBool() == 1){mySwitch.switchOn(2, 3);}else{mySwitch.switchOff(2, 3);}
                case 8:
                  if(message.getBool() == 1){mySwitch.switchOn(2, 4);}else{mySwitch.switchOff(2, 4);}
                case 9:
                  if(message.getBool() == 1){mySwitch.switchOn(3, 1);}else{mySwitch.switchOff(3, 1);}
                case 10:
                  if(message.getBool() == 1){mySwitch.switchOn(3, 2);}else{mySwitch.switchOff(3, 2);}
                case 11:
                  if(message.getBool() == 1){mySwitch.switchOn(3, 3);}else{mySwitch.switchOff(3, 3);}
                case 12:
                  if(message.getBool() == 1){mySwitch.switchOn(3, 4);}else{mySwitch.switchOff(3, 4);}
                case 13:
                  if(message.getBool() == 1){mySwitch.switchOn(4, 1);}else{mySwitch.switchOff(4, 1);}
                case 14:
                  if(message.getBool() == 1){mySwitch.switchOn(4, 2);}else{mySwitch.switchOff(4, 2);}
                case 15:
                  if(message.getBool() == 1){mySwitch.switchOn(4, 3);}else{mySwitch.switchOff(4, 3);}
                case 16:
                  if(message.getBool() == 1){mySwitch.switchOn(4, 4);}else{mySwitch.switchOff(4, 4);}
                // ALL ON
                case 17:
                    delay(SLEEP_BETWEEN_ALL_OFF);
                // ALL OFF
                case 18:
                    delay(SLEEP_BETWEEN_ALL_ON);
                default:
                  Serial.println("Unknown Status");
             Serial.print("Incoming change for binary switch: ");
        12.5k
