  3. pir combination with working 4-relay and 4 buttons
13 Posts 3 Posters 4.0k Views 5 Watching
  • DickD
    DickD
    Dick
    Can anybody help me to get this combi sensor to work?
    This is the script at this moment and during compilation I get an error:
    expected initializer before 'MyMessage'bolded text
    #include "Bounce2.h"
    unsigned long SLEEP_TIME = 90000; // Sleep time between reports (in milliseconds)
    boolean lastmotionstate
    #define RELAY_ON 0                      // switch around for realy HIGH/LOW state
    #define RELAY_OFF 1
    // Initialize motion message
    MyMessage motionmsg(CHILD_ID, V_TRIPPED);
    #define RADIO_ID 11                    // radio Id, whatever channel you assigned to
    #define noRelays 4
    const int relayPin[] = {A1, A2, A3, A0}; //  switch around pins to your desire
    const int buttonPin[] = {A5, 6, 7, 8}; //  switch around pins to your desire
    class Relay             // relay class, store all relevant data (equivalent to struct)
    public:
     int buttonPin;                    // physical pin number of button
     int relayPin;                     // physical pin number of relay
     byte oldValue;                    // last Values for key (debounce)
     boolean relayState;               // relay status (also stored in EEPROM)
    Relay Relays[noRelays];
    Bounce debouncer[noRelays];
    MyMessage msg[noRelays];
     gw.begin();
    lastmotionstate =0;
     gw.sendSketchInfo("Motion Sensor", "gordijn");
     gw.present(CHILD_ID, S_MOTION);
     gw.begin(incomingMessage, RADIO_ID, true);
     delay(250);
     gw.sendSketchInfo("Multy-Relay", "gordijn");
     delay(250);
     for (int i = 0; i < noRelays; i++)
       Relays[i].buttonPin = buttonPin[i];              // assign physical pins
       msg[i].type = V_LIGHT;
       debouncer[i].interval(5);
       Relays[i].relayState = gw.loadState(i);                               // retrieve last values from EEPROM
       digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
       gw.send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
       gw.present(i, S_LIGHT);                               // present sensor to gateway
       delay(250);
     // Read digital motion value
     Serial.println(tripped);
       if (lastmotionstate != tripped)
    gw.send(motionmsg.set(tripped?"1":"0"));  // Send tripped value to gw
    lastmotionstate =tripped;
    //  gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
     for (byte i = 0; i < noRelays; i++)
       debouncer[i].update();
       byte value = debouncer[i].read();
       if (value != Relays[i].oldValue && value == 0)
         gw.saveState( i, Relays[i].relayState );
       }                 // save sensor state in EEPROM (location == sensor number)
       Relays[i].oldValue = value;
    // process incoming message
    void incomingMessage(const MyMessage &message)
     if (message.type == V_LIGHT)
       if (message.sensor < noRelays)            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
         digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
         gw.saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
    • DickD Dick
      #define RELAY_OFF 1
      #define noRelays 4
      public:
       gw.begin();
      lastmotionstate =0;
       delay(250);
       delay(250);
         delay(250);
      @Dick looks like you are missing a ; after
      • DickD
        DickD
        Dick
        Thanks for the tip, I added the Boolean, so that is one step. No I thought it is in place but now I got a warning
        'Sleep' was not declarered in this scope
        that is strange because I declared it. Pleas advise me
        In#include <SPI.h>
        #define CHILD_ID_PIR 1
        #define RELAY_OFF 1
        #define RADIO_ID 11                // Radio Id, whatever channel you assigned to
        #define PIR_SENSOR_DIGITAL_INPUT 3     // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
        #define noRelays 4
        const int relayPin[] = {A1, A2, A3, A4}; //  switch around pins to your desire
        const int buttonPin[] = {5, 6, 7, 8}; //  switch around pins to your desire
        //unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
        public:
        boolean metric = true;
        boolean prevPIRstatus = false;
        int lastLightLevel;
        MyMessage msgPIR(CHILD_ID_PIR, V_TRIPPED);
        MyMessage msgRelays[noRelays];
          gw.begin();
          gw.sendSketchInfo("Combi PIR, Temp, Hum, 4 Relay and Switch, LDR sensor", "1.0");
          // Initialize and present Relays with corresponding buttons
            msgRelays[i].sensor = i;                                   // initialize messages
            msgRelays[i].type = V_LIGHT;
            gw.send(msgRelays[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
            delay(250);
          gw.present(CHILD_ID_PIR, S_MOTION);
          // Deal with incoming messages and when enabled repeat
          // Deal with PIR
          boolean tripped = digitalRead(PIR_SENSOR_DIGITAL_INPUT) == HIGH;
          // Check if PIR Changed
          if (prevPIRstatus |= tripped) {
            gw.send(msgPIR.set(tripped?"1":"0"));  // Send tripped value to gw
           // prevPIRstatus = tripped; // store new value to PIR status to run update on next loop when changed
          sleep(digitalPinToInterrupt(PIR_SENSOR_DIGITAL_INPUT), CHANGE, SLEEP_TIME);
          // Deal with relays and buttons
              gw.saveState(message.sensor, Relays[message.sensor].relayState); // save sensor state in EEPROM (location == sensor number)
        • DickD Dick
          In#include <SPI.h>
          #define RELAY_OFF 1
          #define noRelays 4
          public:
          int lastLightLevel;
            gw.begin();
              delay(250);
            // Deal with PIR
          @Dick the IDE normally says which line the error occurred on. Knowing that helps a lot when troubleshooting.
          This line
          should probably be
          gw.sleep(digitalPinToInterrupt(PIR_SENSOR_DIGITAL_INPUT), CHANGE, SLEEP_TIME);
          DickD 1 Reply Last reply
          • DickD
            DickD
            Dick
            thats logic, I hoped that I learned something in the last cople of days but trouble shooting is something else. Thank you for your advise and go on with testing and adding other devises.
              This line
              should probably be
              DickD
              DickD
              Dick
              still strugling. it must beeasy but it isn't, mij working 4 button and 4 relais
              #define RELAY_OFF 1
              #define noRelays 4
              public:
                delay(250);
                gw.sendSketchInfo("Multy-Relay&Pulsanti", "0.2");
                delay(250);
                  delay(250);
              Combined with a pir like this where the pir is working perfect but the buttons in combi with the relay are not working anymore. What is wrong in this comnined script?
              NO ERRORS DURING COMPILATION!
              unsigned long SLEEP_TIME = 60000; // Sleep time between reports (in milliseconds)
              #define RELAY_OFF 1
              #define noRelays 4
              public:
                //gw.begin();
                //gw.sendSketchInfo("Combi PIR, Temp, Hum, 4 Relay and Switch, LDR sensor", "1.0");
                delay(250);
                delay(250);
                  delay(250);
                // Deal with PIR
              • DickD Dick
                #define RELAY_OFF 1
                #define noRelays 4
                public:
                  delay(250);
                  delay(250);
                    delay(250);
                #define RELAY_OFF 1
                #define noRelays 4
                public:
                  //gw.begin();
                  delay(250);
                  delay(250);
                    delay(250);
                  // Deal with PIR
                @Dick the code is using child id 0, 1, 2 and 3 for the relays, and then 1 again for the pir. That will confuse the system. I would change
                to
                #define CHILD_ID_PIR noRelays  // relays use child id 0...noRelays-1 so let the pir use the next number
                and move this definition after #define noRelays.
                • DickD
                  DickD
                  Dick
                  I finaly made it 4 buttons, 4 relay and a pir and here the script for sharing
                  #define USE_MOTION_SENSOR
                  #define MOTION_SENSOR_PIN    3
                  #define RELAY_OFF 1
                  Bounce motionsDebouncer = Bounce();
                  #define noRelays 4
                  public:
                    delay(250);
                    delay(250);
                    pinMode( MOTION_SENSOR_PIN, INPUT_PULLUP );
                    motionsDebouncer.attach(MOTION_SENSOR_PIN);
                    motionsDebouncer.interval(50);
                      delay(250);
                    if ( motionsDebouncer.update()) {
                      int value = motionsDebouncer.read();
                      Serial.println( "Motion sensor is " + (String)value );
                    delay( 50 ); // give the input pins some rest. Incomming messages are still being processed.
                  • DickD Dick
                    #define RELAY_OFF 1
                    #define noRelays 4
                    public:
                      delay(250);
                      delay(250);
                        delay(250);
                    Great work @Dick !
                    You might want to change
                    to
                    gw.wait( 50 ); // give the input pins some rest. Incoming messages are still being processed.
                    Delay will prevent incoming messages from being processed while gw.wait handles incoming messages.
                    • DickD
                      DickD
                      Dick
                      thanks for this change. I read about it. I change it right away.
