  3. Multisensor node using Ceech board
64 Posts 8 Posters 39.6k Views 11 Watching
  • rollercontainerR
    rollercontainerR
    rollercontainer
    As I understood, there is a buck boost converter that lifts the battery voltage to 3,3V. So I thought, two 1,5V batteries would be sufficient. Am I wrong?
    I've got a 5V solar panel and turned the trimmer clockwise to the end. Correct? (tried counterclockwise also, nothing changed.)
    Vcc = 2.96V
    Charge current = 0.00mA
    Solar cell voltage = 4.89V
    Battery voltage = 2.79V
    CHRG = 0
    • rollercontainerR
      rollercontainerR
      rollercontainer
      I've got light a bit closer and a current showed up:
      Vcc = 3.01V
      Charge current = 2.23mA
      Battery voltage = 2.85V
      CHRG = 0
      Is Vcc messuring the voltage comming from the usb device?
      • C
        C
        ceech
        wrote on last edited by ceech
        #40
        There are two versions of the board. One with a voltage regulator and one with a buck-boost converter. The first one does not step-up the voltage and the other does.
        Here is how the trimmer potentiometer work:
        The viper is on the red line. Turn it counterclockwise till it reaches the 5V mark. This is a 5V setting.
        5V solar cell is fine, just remember that the minimum voltage for the charger to operate is 4.75V. You are already on the minimum, so the solar cell needs to be well lit in order for system to operate.
        Vcc is a voltage rail that powers the microcontroller. It measures its own voltage.
        If you already have the solar cell and the battery connected than the USB voltage must not be applied!
        • rollercontainerR
          rollercontainerR
          rollercontainer
          In the ebay auction I bought it your text says buck boost converter. On the chip there is a number gnq 666 601, but I cant find him. Board says: 77534K_Y471
          • C
            C
            ceech
            The first number from IC is the LTC4079. Board number means that you have one with a voltage regulator. You somehow ended with one. You can send it back and I'll send you replacement if you wish.
            • rollercontainerR
              rollercontainerR
              rollercontainer
              I am not amused...
              I will buy additonal batteries and a second solar cell.
              • C
                C
                ceech
                There are also the appropriate charging voltage and current settings to be made to accommodate for the NiCd batteries. Are you sure you don't want for me to do it for you?
                • rollercontainerR
                  rollercontainerR
                  rollercontainer
                  I thought, sunset will be enough to terminate charging on NiCd?
                  So its easier to take 3,2V LiFePo4, right? And because my board only regulates down, I have to take 2 in series to provide enough voltage to regulate, right?
                  All these flat LiPo types provide ~3,7V. Is that enough to feed the regulator (+dropout)?
                  • C
                    C
                    ceech
                    #46
                    Proper voltage and current also take effect in charging NiCd batteries.
                    And LiFePO4 would also require different charge voltage (3.6V).
                    The best option is a single cell LiPo battery with a capacity between 1000mAh and 2500mAh.
                    Charge voltage matches (4.2V) and the current as well. Voltage regulator on the board is extremely efficient with just 2uA of consumption and 180mV dropout voltage. At 3V with the battery you still get 2.82V for the microcontroller. That's plenty. And quiescent current is the same in dropout. You'll be well off.
                    • rollercontainerR
                      rollercontainerR
                      rollercontainer
                      like this one?
                      http://www.ebay.de/itm/1x-Lipo-Akku-LxBxH-75-x-40-x-5-6-mm-3-7V-2000mAh-1S-JST-Stecker-554475-/371581598136
                      • C
                        C
                        ceech
                        Like that one, yes. Or, if you do not mind doing some soldering yourself, you can choose one from this list:
                        http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=Li-ion+Replacement+Battery+For+Samsung&_sop=15
                        I do it like this:
                        • rollercontainerR
                          rollercontainerR
                          rollercontainer
                          I wanted to use it outside for collecting weather data. But the battery which the board is designed for isn't suitable for temperatures below 0°C.
                          Is that right so far?
                          Or did you successfully used Li-Ion outside below 0°C?
                          • C
                            C
                            ceech
                            The capacity of LiPo batteries start to decline below 0 degrees Celsius. But that is a fact in all kinds of batteries. You are not going to notice much change till below -20 degrees. I found this post which describes it perfectly ( scroll down a little ):
                            https://backpackinglight.com/forums/topic/84570/
                            • rollercontainerR
                              rollercontainerR
                              rollercontainer
                              Ok, now I've got a 12V 50mA solar cell and a 3,7V 2000mAh LiPo. Potentiometer is at 12 o'clock (flat segment at the single solder pad)
                              Can you please try to explain what exactly the potentiometer is adjusting?
                              Does the charger only charge if the cell voltage is below the adjusted voltage level?
                              Your example sketch is not showing any charging current:
                              Vcc = 3.32V
                              Solar cell voltage = 0.24V
                              Battery voltage = 3.79V
                              CHRG = 424
                              Vcc = 3.32V
                              Solar cell voltage = 7.44V
                              CHRG = 409
                              Vcc = 3.32V
                              Solar cell voltage = 11.72V
                              CHRG = 0
                              alexsh1A C 2 Replies Last reply
                              • rollercontainerR rollercontainer
                                Vcc = 3.32V
                                CHRG = 424
                                Vcc = 3.32V
                                CHRG = 409
                                Vcc = 3.32V
                                CHRG = 0
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @rollercontainer I would suggest you scroll up and see a few posts above concerning your question. The setting for potentiometer- for you it should be around 6 o'clock (or 12 o'clock where the cut-off mark is).
                                Basically what it does is adjusting when your battery is being charged. For example, I have a 5V solar panel and I'd like the LiPO to start being charged at 4.75V therefore I put the potentiometer at the minimum (around 2pm or 8pm cut-off mark). This threshold (in my case 4.75V) can be adjusted by this potentiometer.
                                  Vcc = 3.32V
                                  CHRG = 424
                                  Vcc = 3.32V
                                  CHRG = 409
                                  Vcc = 3.32V
                                  CHRG = 0
                                  C
                                  C
                                  ceech
                                  @rollercontainer The potentiometer is adjusting the voltage at which the solar panel is operating at its maximum power. It is so called MPPT. Just set it to the solar panel's nominal voltage.
                                  When the voltage on the solar panel is reduced (is in shade or we want to extract too much from it), the charger reduces the charging current in order to prevent the solar panel from collapsing entirely.
                                  • rollercontainerR
                                    rollercontainerR
                                    rollercontainer
                                    D'oh! I thought, the wiper of the trimmer is at the flat side, but its opposite to the flat, got it finally. Now pimatic is showing a current (0.74A).
                                    • FraidF
                                      FraidF
                                      Fraid
                                      Hi everyone, I'm new to arduino, and I bougth Ceech board.
                                      Can someone please let me know how to upload sketch on this board? I read it's compatible with arduino but I can't find any wiring schema.
                                      Also where is A7/CHRG ? Because my board go from analog A0 to A5.
                                      And I bought the following one :
                                      http://www.ebay.com/itm/331838940273?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                                      I just want a solar/battery powered sensor. And I have anduino nano.
                                      Thank
                                      alexsh1A 1 Reply Last reply
                                      • FraidF Fraid
                                        Thank
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @Fraid-DIRON welcome to the forum! This is beginners question and I would suggest you browse www.arduino.cc
                                        You will find tons of international on that web-site concerning programming Arduino in general. This is how I was learning it.
                                        Concerning Ceech's board, it is programmed the same way as any Arduino Pro or Arduino Pro Mini - with a help of FTDI USB to TTL converter (there are many on eBay) connected to the 6 angled pins on the board.
                                        This link is for Pro Mini, but Pro (Ceech's board) is programmed in exactly the same way:
                                        https://www.arduino.cc/en/Guide/ArduinoProMini
                                        • FraidF
                                          FraidF
                                          Fraid
                                          @alexsh1 said:
                                          FTDI
                                          Ohh thank you @alexsh1 , and my bad, you made me realize that Ceech's board as the ATMega. Now that make more sense the A7 is the analog pin 7 that is linked with the CHRG of LTC4067. Anyway Thanks :D !
