  3. Multisensor node using Ceech board
64 Posts 8 Posters 39.6k Views 11 Watching
  • rollercontainerR
    rollercontainerR
    rollercontainer
    like this one?
    http://www.ebay.de/itm/1x-Lipo-Akku-LxBxH-75-x-40-x-5-6-mm-3-7V-2000mAh-1S-JST-Stecker-554475-/371581598136
    • C
      C
      ceech
      Like that one, yes. Or, if you do not mind doing some soldering yourself, you can choose one from this list:
      http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=Li-ion+Replacement+Battery+For+Samsung&_sop=15
      I do it like this:
      • rollercontainerR
        rollercontainerR
        rollercontainer
        I wanted to use it outside for collecting weather data. But the battery which the board is designed for isn't suitable for temperatures below 0°C.
        Is that right so far?
        Or did you successfully used Li-Ion outside below 0°C?
        • C
          C
          ceech
          The capacity of LiPo batteries start to decline below 0 degrees Celsius. But that is a fact in all kinds of batteries. You are not going to notice much change till below -20 degrees. I found this post which describes it perfectly ( scroll down a little ):
          https://backpackinglight.com/forums/topic/84570/
          • rollercontainerR
            rollercontainerR
            rollercontainer
            Ok, now I've got a 12V 50mA solar cell and a 3,7V 2000mAh LiPo. Potentiometer is at 12 o'clock (flat segment at the single solder pad)
            Can you please try to explain what exactly the potentiometer is adjusting?
            Does the charger only charge if the cell voltage is below the adjusted voltage level?
            Your example sketch is not showing any charging current:
            Vcc = 3.32V
            Charge current = 0.00mA
            Solar cell voltage = 0.24V
            Battery voltage = 3.79V
            CHRG = 424
            Vcc = 3.32V
            Solar cell voltage = 7.44V
            CHRG = 409
            Vcc = 3.32V
            Solar cell voltage = 11.72V
            CHRG = 0
            alexsh1A C 2 Replies Last reply
            • rollercontainerR rollercontainer
              Vcc = 3.32V
              CHRG = 424
              Vcc = 3.32V
              CHRG = 409
              Vcc = 3.32V
              CHRG = 0
              alexsh1A
              alexsh1A
              alexsh1
              @rollercontainer I would suggest you scroll up and see a few posts above concerning your question. The setting for potentiometer- for you it should be around 6 o'clock (or 12 o'clock where the cut-off mark is).
              Basically what it does is adjusting when your battery is being charged. For example, I have a 5V solar panel and I'd like the LiPO to start being charged at 4.75V therefore I put the potentiometer at the minimum (around 2pm or 8pm cut-off mark). This threshold (in my case 4.75V) can be adjusted by this potentiometer.
                Vcc = 3.32V
                CHRG = 424
                Vcc = 3.32V
                CHRG = 409
                Vcc = 3.32V
                CHRG = 0
                C
                C
                ceech
                @rollercontainer The potentiometer is adjusting the voltage at which the solar panel is operating at its maximum power. It is so called MPPT. Just set it to the solar panel's nominal voltage.
                When the voltage on the solar panel is reduced (is in shade or we want to extract too much from it), the charger reduces the charging current in order to prevent the solar panel from collapsing entirely.
                • rollercontainerR
                  rollercontainerR
                  rollercontainer
                  D'oh! I thought, the wiper of the trimmer is at the flat side, but its opposite to the flat, got it finally. Now pimatic is showing a current (0.74A).
                  • FraidF
                    FraidF
                    Fraid
                    Hi everyone, I'm new to arduino, and I bougth Ceech board.
                    Can someone please let me know how to upload sketch on this board? I read it's compatible with arduino but I can't find any wiring schema.
                    Also where is A7/CHRG ? Because my board go from analog A0 to A5.
                    And I bought the following one :
                    http://www.ebay.com/itm/331838940273?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                    I just want a solar/battery powered sensor. And I have anduino nano.
                    Thank
                    alexsh1A 1 Reply Last reply
                    • FraidF Fraid
                      Thank
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @Fraid-DIRON welcome to the forum! This is beginners question and I would suggest you browse www.arduino.cc
                      You will find tons of international on that web-site concerning programming Arduino in general. This is how I was learning it.
                      Concerning Ceech's board, it is programmed the same way as any Arduino Pro or Arduino Pro Mini - with a help of FTDI USB to TTL converter (there are many on eBay) connected to the 6 angled pins on the board.
                      This link is for Pro Mini, but Pro (Ceech's board) is programmed in exactly the same way:
                      https://www.arduino.cc/en/Guide/ArduinoProMini
                      • FraidF
                        FraidF
                        Fraid
                        @alexsh1 said:
                        FTDI
                        Ohh thank you @alexsh1 , and my bad, you made me realize that Ceech's board as the ATMega. Now that make more sense the A7 is the analog pin 7 that is linked with the CHRG of LTC4067. Anyway Thanks :D !
                        • FraidF Fraid
                          @alexsh1 said:
                          FTDI
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @Fraid-DIRON No worries
                          • rollercontainerR
                            rollercontainerR
                            rollercontainer
                            Can someone explain, why the charger isnt charging all the time or at least earlier? BattVoltage is 3.96V on the right end. Is the cell considered full?
                            C 1 Reply Last reply
                              C
                              C
                              ceech
                              wrote on last edited by ceech
                              #60
                              @rollercontainer For some reason current started to drop. Once it reached C/10 (around 10mA), charger stopped charging. This is a programmed function.
                              I can see two reasons why the current started to drop. Voltage readings might be off for one. Or the battery doesn't accept charge above 4V. Its internal resistance might risen.
                              Late charge start might indicate wrong voltage readings. If we assume that in the morning the voltage is 4.2V, then at 11 o'clock the voltage dropped just enough for the charger to start charging (also a programmed feature).
                                MikeF
                                I've built nodes using two versions of the Ceech board intended for solar cells - one with the LTC4079 charger, the other with the earlier LTC4067 charger.
                                I now want to use one of these as a pulse power sensor without sleep (as per MySensors example sketch), so it needs to be on non-battery power, i.e., from a 5V USB charger. If I remove the battery, which input should I connect the 5V to: the battery input or the solar input?
                                • M MikeF
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @MikeF Definitely the solar input. (Battery max voltage is 4.2V fully charged)
                                  • C
                                    C
                                    ceech
                                    #63
                                    On the board with the LTC4079 there is a voltage regulator behind the input, so you can use battery connector. On the board with the LTC4067 use the VIN pin on the bottom connector.
                                    • jumpingJ
                                      jumpingJ
                                      jumping
                                      wrote on last edited by jumping
                                      #64
                                      I use a My Sensors 2.0 version of "Multisensor node using @ceech board" but I have this error:
                                      TSP:MSG:SEND 5-5-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=1,st=ok:JMP-LightLux
                                      TSP:MSG:SEND 5-5-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                                      TSP:MSG:SEND 5-5-0-0 s=10,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=ok:
                                      TSP:MSG:SEND 5-5-0-0 s=11,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=ok:
                                      TSP:MSG:SEND 5-5-0-0 s=1,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=ok:
                                      Request registration...
                                      TSP:MSG:SEND 5-5-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                      TSP:MSG:READ 0-0-5 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      Node registration=1
                                      Init complete, id=5, parent=0, distance=1, registration=1
                                      BH1750 lux: 387TSP:MSG:SEND 5-5-0-0 s=1,c=1,t=37,pt=3,l=2,sg=0,ft=0,st=ok:387
                                      Batt: 3.74V ; 414.08mA
                                      Solar: 0.00V ; 0.00 mA; charge: Yes
                                      BattPct: 61%
                                      TSP:MSG:SEND 5-5-0-0 s=10,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=ok:3.738
                                      TSP:MSG:SEND 5-5-0-0 s=10,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=ok:0.414
                                      TSP:MSG:SEND 5-5-0-0 s=11,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=ok:0.000
                                      TSP:MSG:SEND 5-5-0-0 s=11,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=ok:0.000
                                      !TSP:MSG:SEND 5-5-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=fail:61
                                      after that the node doesn't send data to gateway.
                                      Do you have some ideas to solve the problem?
                                      thanks
                                      Raspberrry PI3 - Domoticz
                                      ESP8266 GW - MySensors 2.1.1
