  3. FHEM
  4. FHEM
FHEM
Scheduled Pinned Locked Moved FHEM
19 Posts 10 Posters 18.9k Views 9 Watching
  • A
    Aloha
    Cool, it seems to work now! Thanks! Now I'm receiving some warning messages in fhem log (even if it seems to be working).
    2014.12.02 00:03:02 1: PERL WARNING: Subroutine Define redefined at ./FHEM/10_MYSENSORS_DEVICE.pm line 162.
    2014.12.02 00:03:02 1: PERL WARNING: Subroutine UnDefine redefined at ./FHEM/10_MYSENSORS_DEVICE.pm line 179.
    2014.12.02 00:03:02 1: PERL WARNING: Subroutine Set redefined at ./FHEM/10_MYSENSORS_DEVICE.pm line 185.
    2014.12.02 00:03:02 1: PERL WARNING: Subroutine Attr redefined at ./FHEM/10_MYSENSORS_DEVICE.pm line 230.
    2014.12.02 00:03:02 1: PERL WARNING: Subroutine onGatewayStarted redefined at ./FHEM/10_MYSENSORS_DEVICE.pm line 352.
    2014.12.02 00:03:02 1: PERL WARNING: Subroutine onPresentationMessage redefined at ./FHEM/10_MYSENSORS_DEVICE.pm line 356.
    2014.12.02 00:03:02 1: PERL WARNING: Subroutine onSetMessage redefined at ./FHEM/10_MYSENSORS_DEVICE.pm line 413.
    2014.12.02 00:03:02 1: PERL WARNING: Subroutine onRequestMessage redefined at ./FHEM/10_MYSENSORS_DEVICE.pm line 426.
    2014.12.02 00:03:02 1: PERL WARNING: Subroutine onInternalMessage redefined at ./FHEM/10_MYSENSORS_DEVICE.pm line 441.
    2014.12.02 00:03:02 1: PERL WARNING: Subroutine sendClientMessage redefined at ./FHEM/10_MYSENSORS_DEVICE.pm line 518.
    2014.12.02 00:03:02 1: PERL WARNING: Subroutine rawToMappedReading redefined at ./FHEM/10_MYSENSORS_DEVICE.pm line 525.
    2014.12.02 00:03:02 1: PERL WARNING: Subroutine mappedReadingToRaw redefined at ./FHEM/10_MYSENSORS_DEVICE.pm line 536.
    I only downloaded the new module and did a reload.
    N 1 Reply Last reply
    • A Aloha
      N
      N
      ntruchsess
      @Aloha
      fhem (or better 'perl') is unable to do a clean reload of a single module without restart of the perl-process. Hence the warnings. Just do a 'shutdown restart' on the web-console.
      • A
        Aloha
        Is it possible to use 2 gateways at the same time with Fhem? For instance multiple ethernet gateways or one ethernet gateway and one serial gateway?
        • A Aloha
          N
          N
          ntruchsess
          @Aloha
          sure. You may use as many gateways in a single instance of fhem as the machine is capable to service in terms of cpu, ram and filehandles. What does not work is to use multiple gateways for the very same sensors to archive higher avaiability (or redundancy), so it would be beneficial to use different channels for each gateway to lessen cpu-load on the gateways ans save bandwith on the connection to fhem. If all sensors and gateways share the same channel you will have to assign each sensor to the gateway that suits best (e.g. is positioned with the least distance to the sensor) - fhem will just ignore messages for a gateway a sensor is not assigned to (if not in inclusion-mode).
          • Norbert
          • raditvR
            raditvR
            raditv
            @ntruchsess how do I update my dummy switch value? my german language is not so good to understand everything on fhem. I've created fhem.cfg for my 4 buttons. and create 4 dummy switch for that. but when I press the real button, dummy switch doesn't change the state. but when I press dummy switch on web. the button status is changed.
            below is my fhem.cfg
            attr global userattr devStateIcon devStateStyle icon sortby webCmd widgetOverride
            attr global autoload_undefined_devices 1
            attr global logfile ./log/fhem-%Y-%m.log
            attr global modpath .
            attr global motd SecurityCheck:\
            WEB,WEBphone,WEBtablet has no basicAuth attribute.\
            telnetPort has no password/globalpassword attribute.\
            Restart FHEM for a new check if the problem is fixed,\
            or set the global attribute motd to none to supress this message.\
            attr global statefile ./log/fhem.save
            attr global updateInBackground 1
            attr global verbose 3
            define telnetPort telnet 7072 global
            define WEB FHEMWEB 8083 global
            define WEBphone FHEMWEB 8084 global
            attr WEBphone stylesheetPrefix smallscreen
            define WEBtablet FHEMWEB 8085 global
            attr WEBtablet stylesheetPrefix touchpad
            # Fake FileLog entry, to access the fhem log from FHEMWEB
            define Logfile FileLog ./log/fhem-%Y-%m.log fakelog
            define autocreate autocreate
            attr autocreate filelog ./log/%NAME-%Y.log
            define eventTypes eventTypes ./log/eventTypes.txt
            # Disable this to avoid looking for new USB devices on startup
            define initialUsbCheck notify global:INITIALIZED usb create
            define gateway MYSENSORS /dev/tty.wchusbserial14120@115200
            attr gateway autocreate 1
            attr gateway first-sensorid 10
            attr gateway stateFormat connection
            define MySwitch MYSENSORS_DEVICE 10
            attr MySwitch IODev gateway
            attr MySwitch mapReading_switch 0 switch
            attr MySwitch mapReading_switch1 1 switch
            attr MySwitch mapReading_switch2 2 switch
            attr MySwitch mapReading_switch3 3 switch
            attr MySwitch mode node
            attr MySwitch setCommands on0:switch:on off0:switch:off on1:switch1:on off1:switch1:off on2:switch2:on off2:switch2:off on3:switch3:on off3:switch3:off
            attr MySwitch setReading_switch off,on
            attr MySwitch setReading_switch1 off,on
            attr MySwitch setReading_switch2 off,on
            attr MySwitch setReading_switch3 off,on
            attr MySwitch version 1.4.1
            #Switch Config
            # Blue LED
            define BlueLED dummy
             attr BlueLED group TestGroup
             attr BlueLED room MySensorLED
             attr BlueLED setList on off
             attr BlueLED webCmd on:off
             # normal Switch on
             define BlueLED1 notify BlueLED:on set MySwitch on0
             define BlueLED2 notify BlueLED:off set MySwitch off0
            # Orange LED
            define OrangeLED dummy
             attr OrangeLED group TestGroup
             attr OrangeLED room MySensorsLED
             attr OrangeLED setList on off
             attr OrangeLED webCmd on:off
             # normal Switch on
             define OrangeLED1 notify OrangeLED:on set MySwitch on1
             define OrangeLED2 notify OrangeLED:off set MySwitch off1
            # Red LED
            define RedLED dummy
             attr RedLED group TestGroup
             attr RedLED room MySensorsLED
             attr RedLED setList on off
             attr RedLED webCmd on:off
             # normal Switch on
             define RedLED1 notify RedLED:on set MySwitch on2
             define RedLED2 notify RedLED:off set MySwitch off2
            # Green LED
            define GreenLED dummy
             attr GreenLED group TestGroup
             attr GreenLED room MySensorsLED
             attr GreenLED setList on off
             attr GreenLED webCmd on:off
             # normal Switch on
             define GreenLED1 notify GreenLED:on set MySwitch on3
             define GreenLED2 notify GreenLED:off set MySwitch off3
            m26872M 1 Reply Last reply
            • raditvR raditv
              #Switch Config
              # Blue LED
               # normal Switch on
              # Orange LED
               # normal Switch on
              # Red LED
              define RedLED dummy
               # normal Switch on
              # Green LED
               # normal Switch on
              m26872M
              m26872M
              m26872
              @raditv
              A little late, but just to avoid an unanswered post... Did you try adding something like:
              define BlueLED1reverse notify MySwitch:switch setstate BlueLED $EVTPART1
              • J
                J
                Jarnsen
                I installed the water Meter. I use Version 1.5.1, the volume and flow aren't count. I use FHEM 5.7. please can anyone help me. What do you need for analyzing the problem?
                Sorry for my english.
                Thx for Help
                Jarnsen
                • R
                  R
                  Rasenheizung
                  Could you link your sketch and post your FHEM entries?
                    mcjoin
                    wrote on last edited by mcjoin
                    Hi @all,
                    i tried to translate the original post on FHEM Forum into english for people, who does not speek german.
                    btw. I'm sorry for my english, so feel free to make corrections ;)
                    The new MYSENSORS Module ...
                    ... integrates the Arduino- an nRF24L01 based MySensors wireless sensors and -actors in FHEM.
                    It supports MySensors serial and ethernet gateways.
                    You can configure FHEM with
                    define gateway MYSENSORS /dev/ttyUSB0@115200
                    for serial, or with
                    define gateway <IP>:<PORT>
                    for ethernet gateway.
                    After start, press the "Inclusion-mode" Button on gateway, or fire 'set gateway inclusion-mode on' command in FHEM.
                    Then restart your sensors in the radio range. (the "inclusion-mode will be turned off automaticly after one minute)
                    You can add new devices in FHEM with the define command:
                    define temperaturesensor MYSENSORS_DEVICE 21
                    attr temperaturesensor IODev gateway
                    For controlling Actors (f.e. the 'RelayWithButtonActuator') you have to teach your MYSENSORS_DEVICE the relevant set-commands:
                    define relay MYSENSORS_DEVICE <nodeid>
                    attr relay setCommands on:switch_1:on off:switch_1:off
                    attr relay stateFormat switch_1
                    Now you can toggle the actor in the web ui.
                    you can teach the gateway or single nodes to response every set-messagewith an individual acknowledge-packet with the following attribute:
                    attr <gateway|node> requestAck 1
                    With activated acknowledge the gateway will sending the command untill it received the acknowledge response. (If the actor is absent or off, it will receive the command as soon as it is accessible again. Warning: FHEM will lose these queued messages on a restart)
                      The newly supported FHEM controller should also have its own separate thread.
                      Big thanks to @ntruchsess for all the effort you've put into this.
                      I can't seem to find any install instructions in english at the moment.
                      http://forum.fhem.de/index.php/topic,28198.msg210752.html#msg210752
                      HonkH
                      HonkH
                      Honk
                      @ntruchsess Will the Module in FHEM be updated for Version 2.0.0?
                      If there are only new Constants I could try to do it and make it available to be published in the FHEM SVN.
                      Daniel LienhardD 1 Reply Last reply
                      • HonkH Honk
                        Daniel LienhardD
                        Daniel LienhardD
                        Daniel Lienhard
                        @Hermann-Kaiser That would be very nice! ......waiting for the new constants to use them in FHEM...
                        HonkH 1 Reply Last reply
                        • Daniel LienhardD Daniel Lienhard
                          HonkH
                          HonkH
                          Honk
                          @Daniel-Lienhard @ntruchsess
                          i have updated MY_SENSOR_DEVICE.pm and Constants.pm
                          would be nice if these files can be cheked and then submitted to the FHEM SVN.
                          I've only added constants.
                          1_1471334476177_Constants.pm 0_1471334476176_10_MYSENSORS_DEVICE.pm
                          • HonkH Honk
                            Daniel LienhardD
                            Daniel LienhardD
                            Daniel Lienhard
                            @Hermann-Kaiser thx, will check it today and get back to you.
