  3. DHT sensor for Mysensors V2
10 Posts 4 Posters 6.5k Views 3 Watching
  • mehrdad.silataniM Offline
    mehrdad.silatani
    I was wondering if someone can help me to setup a DHT sensor for mysensors V2. For some reason I dont have it inside my mysensors library ! Also, the video and the example sketch on the website is for the older version.
    Cheers,
    Mehrdad
    S 1 Reply Last reply
    • mehrdad.silataniM mehrdad.silatani
      Cheers,
      Mehrdad
      @mehrdad.silatani - Hi!
      Because it is dependent of an external library it was moved to a seperat folder for 2.0.
      https://github.com/mysensors/MySensorsArduinoExamples/tree/master/examples/DhtTemperatureAndHumiditySensor
      Lib: https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries/DHT
      mehrdad.silataniM 1 Reply Last reply
      • S sundberg84
        mehrdad.silatani
        @sundberg84 Fantastic ! It worked very well ! Thanks for quick response !
          mehrdad.silatani
          Ok, I have one more general question !
          I have experience in working with Arduinos alone, and most of the time I kinda always manage to understand the example sketches, then expand it, modify it or write another one from scratch to my specifications. But when it comes to Mysensors IDEs, I am really struggling to fully understand them and tweak them ... All those "CHILD_ID_... , S_... , V_... , Void presentation (), ......"
          Is there any guide available that I can start reading up ?
          Cheers,
          Mehrdad
            Cheers,
            Mehrdad
            @mehrdad.silatani - well, since we are in the middle of 1.6 and 2.0 it might be a bit messy at the moment. You have the API and all the technial stuff here for all versions: https://www.mysensors.org/download/
            Aslo there is a great tutorial how to combine sketches... but I cant find it :(
            • S sundberg84
              @sundberg84 could https://forum.mysensors.org/topic/115/implementing-multiple-sensors/4 be the one?
                YES! Thank you!
                • Tagore.PDET Offline
                  Tagore.PDET Offline
                  Tagore.PDE
                  Anyone tried that?
                  i m getting error with dht.readSensor.
                  Arduino: 1.6.9 (Windows 7), Board: "Arduino/Genuino Uno"
                  C:\Users\Usuario\Documents\Arduino\GW Serial 2.0\GwSerial.v.0.3\GwSerial.v.0.3.ino: In function 'void loop()':
                  GwSerial.v.0.3:198: error: no matching function for call to 'DHT::readSensor(bool)'
                     dht.readSensor(true);
                  C:\Users\Usuario\Documents\Arduino\GW Serial 2.0\GwSerial.v.0.3\GwSerial.v.0.3.ino:198:22: note: candidate is:
                  In file included from C:\Users\Usuario\Documents\Arduino\GW Serial 2.0\GwSerial.v.0.3\GwSerial.v.0.3.ino:38:0:
                  C:\Program Files (x86)\Arduino\libraries\DHT/DHT.h:83:8: note: void DHT::readSensor()
                     void readSensor();
                  C:\Program Files (x86)\Arduino\libraries\DHT/DHT.h:83:8: note:   candidate expects 0 arguments, 1 provided
                  Multiple libraries were found for "DHT.h"
                   Used: C:\Program Files (x86)\Arduino\libraries\DHT
                   Not used: C:\Users\Usuario\Documents\Arduino\libraries\DHT_sensor_library
                  exit status 1
                  • Tagore.PDET Tagore.PDE
                    Anyone tried that?
                       void readSensor();
                    exit status 1
                    @Tagore.PDE looks similar to https://forum.mysensors.org/topic/4672/dht-sketch-version-2-0-0-error-solved/ - see if using the dht version in the MySensors examples helps.
                      Tagore.PDET Offline
                      Tagore.PDE
                      Yes, thx. same issue.
