  3. Best or any way to get battery before regulator
12 Posts 3 Posters 3.0k Views 3 Watching
  • Martin TellblomM
    Martin TellblomM
    Martin Tellblom
    If I use this code:
      analogReference(INTERNAL1V1);
      analogReference(INTERNAL);
    And try to use the analog pins for this soil moisture sensor the values I get from the other analog pins goes all crazy with its values
    MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
    AWIA 1 Reply Last reply
    • Martin TellblomM Martin Tellblom
      If I use this code:
      AWIA
      AWIA
      AWI
      @Martin-Tellblom don't use the internal reference, stick to the external (default)
      • Martin TellblomM
        Martin TellblomM
        Martin Tellblom
        @AWI How do I do that? This is my first battery node tryout :)
          AWIA
          AWIA
          AWI
          @Martin-Tellblom Try to comment out the
          //analogReference(INTERNAL1V1);
          • Martin TellblomM
            Martin TellblomM
            Martin Tellblom
            @AWI So that should be enought? I'll try that
              AWIA
              AWIA
              AWI
              analogReference(DEFAULT); is the alternative for using a 5v (vcc) reference.
              Martin TellblomM 1 Reply Last reply
              • AWIA AWI
                Martin TellblomM
                Martin TellblomM
                Martin Tellblom
                @AWI But that is always 5V until the end of the battery since I use a step-up or am I thinking completely wrong here
                • clio75C
                  clio75C
                  clio75
                  If you are using the internal ref 1.1 you need to divide the voltage on the pin down to this level.
                  If you like in the example using a 1M and 470K you will have a approx 1Volt in the point.
                    AWIA
                    AWIA
                    AWI
                    @Martin-Tellblom The 5 volt is the reference... the analog pin is where you measure with respect to the reference. Try reading this article
                    • AWIA AWI
                      Martin TellblomM
                      Martin TellblomM
                      Martin Tellblom
                      Once again. Big thank you @AWI . As you understand I'm new to this battery thing and it's kind of driving me crazy :)
