  3. Best or any way to get battery before regulator
12 Posts 3 Posters 2.9k Views 3 Watching
  • M Offline
    M Offline
    Martin Tellblom
    As I understand after some failed attempt to do a soil moisture sensor with battery check included I can't use any analog pins when using this method described in Battery Powered sensors.
    My sensor looks like this:
    And this does it impossible to use the VCC library since I have a regulator.
    Any other way to get the batterylevel in my setup?
    MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
    A 1 Reply Last reply
    • M Martin Tellblom
      A Offline
      A Offline
      AWI
      @Martin-Tellblom why can't you use analog pins? You need one of these to measure. As your battery voltage is lower than the Arduino vcc you do not need a voltage divider. Just connect the battery (+) to an analog pin.
      • M Offline
        M Offline
        Martin Tellblom
        If I use this code:
          analogReference(INTERNAL1V1);
          analogReference(INTERNAL);
        And try to use the analog pins for this soil moisture sensor the values I get from the other analog pins goes all crazy with its values
        • M Martin Tellblom
          If I use this code:
          A Offline
          A Offline
          AWI
          @Martin-Tellblom don't use the internal reference, stick to the external (default)
          • M Offline
            M Offline
            Martin Tellblom
            @AWI How do I do that? This is my first battery node tryout :)
            • M Martin Tellblom
              A Offline
              A Offline
              AWI
              @Martin-Tellblom Try to comment out the
              //analogReference(INTERNAL1V1);
              • M Offline
                M Offline
                Martin Tellblom
                @AWI So that should be enought? I'll try that
                • M Martin Tellblom
                  A Offline
                  A Offline
                  AWI
                  analogReference(DEFAULT); is the alternative for using a 5v (vcc) reference.
                  • A AWI
                    M Offline
                    M Offline
                    Martin Tellblom
                    @AWI But that is always 5V until the end of the battery since I use a step-up or am I thinking completely wrong here
                    • C Offline
                      C Offline
                      clio75
                      If you are using the internal ref 1.1 you need to divide the voltage on the pin down to this level.
                      If you like in the example using a 1M and 470K you will have a approx 1Volt in the point.
                      • M Martin Tellblom
                        A Offline
                        A Offline
                        AWI
                        @Martin-Tellblom The 5 volt is the reference... the analog pin is where you measure with respect to the reference. Try reading this article
                        • A AWI
                          M Offline
                          M Offline
                          Martin Tellblom
                          Once again. Big thank you @AWI . As you understand I'm new to this battery thing and it's kind of driving me crazy :)
