  3. Help with hacking a wireless outdoor weather station
24 Posts 7 Posters 18.2k Views 6 Watching
  • P
    P
    pjr
    wrote on last edited by pjr
    For me it looks like its Ambient Weather WS-5305.
    As I know the WS1080 is using Fine Offset protocol so it could be easily received if this is using the same. There is many blog posts about it.
    breimannB 1 Reply Last reply
    • mrwombleM
      mrwombleM
      mrwomble
      Have you considered creating / buying an RFlink to connect into your Domoticz system? You'd have to look into whether that model is supported by RFlink, but that approach would be a lot quicker and easier.
      • P pjr
        breimannB
        breimannB
        breimann
        @pjr ok, can you explain Fine Offset protocol a little more please?
        Boots33B 1 Reply Last reply
        • breimannB breimann
          Boots33B
          Boots33B
          Boots33
          @breimann Fine Offset is a popular Chinese brand of weather station that is also re-branded and sold under other names. As it is very common the protocol it uses to transmit the data has been decoded so this would make it easier to use in MySensors. It would still I think be an ambitious project if you do not have a good understanding of how the protocol works and in general Arduino coding as well as MySensors.
          As @pjr has said you need only to google Fine Offset protocol and you will be swamped with information.
          @mrwomble has suggested rflink as another way to get access to your weather data and if your controller supports it that could be an easier way to go. As a bonus RFlink will also allow you to interact with a wide array of other wireless devices and as of R44 now has some limited support of MySensors as well.
          I use RFlink to bring weather data from my Oregon station into my Domoticz controller.
          • Boots33B Boots33
            breimannB
            breimannB
            breimann
            @Boots33 Thankyou. That's all very helpful info. I've learnt more about RFlink now, finding their website and online shop.
            I've got a Mega i'm using for my GW currently but will put a nano or pro mini in for the gw, and free up the mega, and i have some 433mhz RX/TX pair coming, so looks like i'll be making an RFlink for my Domoticz install.
            Hoping and praying RFlink can talk to my weather station and 7 or 8 wireless 240v switch sockets!!
              Boots33B
              Boots33B
              Boots33
              @breimann Yes I think you will be in luck as this post seems to indicate that your station does use the Fine Offset WH1080 protocol which is supported by rflink. RFlink also lists Digitech XC0348 Weather Station as supported so it may be the same protocol as the XC0400.
              As far as power sockets Rflink has pretty good coverage as well it works with my Watts Clever sockets and my Belkin power board and even my old X10 sockets. I think you will be amazed how many of your neighbours weather stations and devices you will also pick up.
              breimannB 2 Replies Last reply
              • Boots33B Boots33
                breimannB
                breimannB
                breimann
                @Boots33 Thanks heaps! That's really encouraging. Yes i saw that Digitech brand listed. I've also contacted Stuntteam via email to check. Best way probably is to build it and test!
                Thanks again!
                • Boots33B Boots33
                  breimannB
                  breimannB
                  breimann
                  @Boots33 Oh I have a question though. You're using RFLink with Domoticz is that right?. How do you actually connect your RFLink Arduino to Domoticz? It might be a silly question, but I'm already running Domoticz on a RPi3, and a MYS serial gateway plugged into one of the 4 USB ports on my RPi. DO I just plug the RFLink into one of the USB ports too??
                  Is it that simple??
                    Is it that simple??
                    Boots33B
                    Boots33B
                    Boots33
                    @breimann yes pretty much just plug it in to a free USB slot and in Domoticz select rflink USB from the drop down box on the hardware page. You may need to type in the serial port it is using and then you should be good to go
                    • Boots33B Boots33
                      breimannB
                      breimannB
                      breimann
                      @Boots33 awesome!!
                      Did you make one from scratch or buy the RFLink board? Any tips in terms of choosing the 433mhz Rx Tx pair?
                        @Boots33 awesome!!
                        Boots33B
                        Boots33B
                        Boots33
                        @breimann Yes I built one from scratch, if you are already building MySensors nodes you will have no trouble with it. It is a great way to expand your connected devices. I have a cheap Chinese floating thermometer in our pool and it even picked that up.
                        As to the 433mhz devices, of the cheap sets on ebay the fs1000 transmitters seem ok but i have found you may need to supply them 9v or more if you want to get decent range. The receivers that are bundled with them are not very good at all. You would be best to search on ebay for "arduino 433mhz superheterodyne" for a more reliable receiver.
                        As you are in OZ you can also buy the Dorji units from Willtronics, I have had good results with them and the transmitter reaches full power at 5v so is easier to use with arduino.
                        Dorji TXR
                        Dorji RX
                        They are a bit more expensive though
                        The antenna is also very important, I usually just use a length of wire around 170 to 175mm seems to work best for me. You will find lots of info about antennas if you google it.
                        korttomaK breimannB 2 Replies Last reply
                        • Boots33B Boots33
                          Dorji TXR
                          Dorji RX
                          korttomaK
                          korttomaK
                          korttoma
                          I noticed this also when working on this project. I had rally bad range, like 4m or so changing to the RBX6 superheterdyne gave me the range I needed.
                          • Tomas
                          • Boots33B Boots33
                            Dorji TXR
                            Dorji RX
                            breimannB
                            breimannB
                            breimann
                            @Boots33 thanks for sharing this info. Really helpful.
                            I have another question if you don't mind. What's the process once RFlink is connected and running in domoticz to program wireless power points like Cleve and Watts etc? Is there a learning process when you press the on/off buttons on your remote?
                              Boots33B
                              Boots33B
                              Boots33
                              @breimann once RFlink is running and you have "Accept new Hardware Devices" turned on in Domoticz settings, it will start adding anything it recognises to the devices list.
                              You can then give the device a name and add it to your used devices. if it is a power socket then as you said just press the remote and watch for it to turn up in the device list. If you live in a heavily populated area you will likely get lots of devices showing up .
                              You will have to make sure you get the right device or you will be turning on and off the neighbours lights as well.
                              For your weather station you will see the data also shown as separate devices like temp, pressure etc. Remember it will probably be listed as fine offset.
                              • Boots33B Boots33
                                breimannB
                                breimannB
                                breimann
                                @Boots33 thanks that's really helpful info much appreciated. Now i need to decommission my Mega as my GW ready for RFlink and setup a new gateway.
                                12.5k
