  3. Invert the relay in the sketch
18 Posts 3 Posters 5.1k Views 2 Watching
  • derksuhD derksuh
    @blacey
    I reversed the lines and changed the values of relay off and relay on but that did not do the trick.
    This sketch i copied from a other project so i don't really know why debouncing is implemented.
    The example you scribed is exactly how it should work.
    blaceyB
    blaceyB
    blacey
    @derksuh Ok, I took a shot at refactoring your sketch. I didn't have much time and I only ensured that it compiles so your MMV... This could probably be simplified even more but you know the old saying, "If I had more time, I would write less code" ;)
    #define MY_REPEATER_FEATURE
    #define MY_NODE_ID 1
    #define DHT_DATA_PIN 6
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_RLAY 2
    #define RELAY_PIN  3
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define TEMP 0
    #define HUMI 1
    byte state = 0;
    bool metric = true;
    MyMessage msgRlay(CHILD_ID_RLAY, V_STATUS);
    typedef struct {
      float last;
      uint8_t nNoUpdates;
    } sensorState_t;
    sensorState_t dhtState[2];
    DHT dht;
      sendSketchInfo("TempHumidRelay", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_RLAY, S_BINARY);
      // Ask the gateway for the units of measure to use
      pinMode(RELAY_PIN, OUTPUT);
      // Initialize the Temperature & Humidity sensor, first reading will be sent from loop()
      if (UPDATE_INTERVAL >= dht.getMinimumSamplingPeriod()) {
        dht.setup(DHT_DATA_PIN); // set data pin of DHT sensor and model (e.g. DHT_22, DHT_11)
        Serial.println("Increase UPDATE_INTERVAL and re-upload sketch...");
      // Request the latest relay status from the gateway
      Serial.println("Requesting initial value from controller");
      request(CHILD_ID_RLAY, V_STATUS);
      // Sleep until next valid interal to read temperature and humidity
      wait(UPDATE_INTERVAL);
      // Read current temperature & humidity from DHT22
      dht.readSensor(true);
      // Only send temperature if it has changed since the last measurement or if we didn't send an update for n times
      if (temperature != dhtState[TEMP].last || dhtState[TEMP].nNoUpdates >= FORCE_UPDATE_N_READS) {
        dhtState[TEMP].last = temperature;
        temperature = metric ? temperature : dht.toFahrenheit(temperature);
        #ifdef MY_DEBUG
          Serial.print("T: ");
        dhtState[TEMP].nNoUpdates = 0;
      else if (isnan(temperature)) {
        dhtState[TEMP].nNoUpdates++;
      // Retrieve the current humidity
      if (humidity != dhtState[HUMI].last || dhtState[HUMI].nNoUpdates >= FORCE_UPDATE_N_READS) {
        dhtState[HUMI].last = humidity;
        #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
        dhtState[HUMI].nNoUpdates = 0;
      } else if (isnan(humidity)) {
        dhtState[HUMI].nNoUpdates++;
      Serial.println("Received message...");
        // Change relay state
        state = message.getByte();
        digitalWrite(RELAY_PIN, state);
        send(msgRlay.set(state));
    • derksuhD
      derksuhD
      derksuh
      @blacey
      The sketch works, but i still need the relay output inverted.
      Changing the values from relay_on and relay_off does not do the trick
      blaceyB 1 Reply Last reply
      • derksuhD derksuh
        @blacey
        blaceyB
        blaceyB
        blacey
        @derksuh Is the relay working the way you want it to and you just want to invert the display in PiMatic? If so, you can do the following in the receive() method:
            send( msgRlay.set(state == 0 ? 1 : 0) );
        • derksuhD
          derksuhD
          derksuh
          @blacey
          The node is working. The problem
          Is that when it is connected to the gateway then the relay gets turned on but The status in pimatic does say it is turned off.
          • derksuhD
            derksuhD
            derksuh
            @blacey where should i put the code in your post?
            • derksuhD derksuh
              blaceyB
              blaceyB
              blacey
              wrote on last edited by blacey
              As I said in my last post, you can put it in the receive() method of your node sketch. Basically, this will invert the relay state sent to PiMac only...
              • derksuhD
                derksuhD
                derksuh
                @blacey
                I did not get it working the way i would like. I now used a different sketch.
                here i had the same problem but i just set the relay_OFF from 0 to 1, and the Relay_ON from 1 to 0
                And with this sketch it worked fine.
                // Enable debug prints
                #define CHILD_ID_HUM 1
                #define CHILD_ID_TEMP 2
                #define HUMIDITY_SENSOR_DIGITAL_PIN 6
                unsigned long lastRefreshTime = 0; // Use this to implement a non-blocking delay function
                DHT dht;
                float lastTemp;
                float lastHum;
                boolean metric = true;
                    pinMode(pin, OUTPUT);
                  sendSketchInfo("Badkamer", "1.3");
                    present(sensor, S_LIGHT);
                  boolean needRefresh = (millis() - lastRefreshTime) > SLEEP_TIME;
                  if (needRefresh)
                      lastRefreshTime = millis();
                        lastTemp = temperature;
                        if (!metric) {
                          lastHum = humidity;
                  if (message.type==V_LIGHT) {
                     // Store state in eeprom
                • derksuhD derksuh
                  @blacey
                  DHT dht;
                  float lastTemp;
                  float lastHum;
                    if (needRefresh)
                          if (!metric) {
                            lastHum = humidity;
                  blaceyB
                  blaceyB
                  blacey
                  Your new sketch looks much better, glad you figured it out! :+1: You might want to remove the saveState() from your receive() method because the "saved -state" is not being used and this will prevent unnecessary writes to EEPROM which has a limited lifespan. Also, you might want to request the relay status from the gateway in setup() so the node will set the relay status to that of they gateway (i.e. the response to a request() sent in setup() will be handled by your existing receive() method).
                  • derksuhD
                    derksuhD
                    derksuh
                    @blacey You mean like this?
                     * Version 1.0 - Henrik EKblad
                     * This sketch provides an example how to implement a humidity/temperature
                     * sensor using DHT11/DHT-22
                    DHT dht;
                    float lastTemp;
                    float lastHum;
                      request(RELAY_1, V_STATUS);
                      if (needRefresh)
                            if (!metric) {
                              lastHum = humidity;
                    • derksuhD derksuh
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                        if (needRefresh)
                              if (!metric) {
                                lastHum = humidity;
                      blaceyB
                      blaceyB
                      blacey
                      @derksuh Exactly - good job! So, is it working as expected? For example, if you turn the relay on and then reboot the node, does the node come up, ask for the relay status, receive relay on and then try to turn the relay on? You should be able to see this in the messaging sequence on the node.
                      • derksuhD
                        derksuhD
                        derksuh
                        No it doesn't do that. If i switch on the relay in pimatic then it goes on.
                        if i then rebot the node the relay stays off but the status in pimatic also changes to off.
                        • derksuhD derksuh
                          blaceyB
                          blaceyB
                          blacey
                          @derksuh Sorry to hear but your sketch looks good. Are you using the MySensors development branch? If not, doing so will probably fix the behavior because there was a bug in the 2.0 release that prevented messages from being sent (i.e. the request()) in the setup() method of a sketch.
                          Once you upgrade to the MySensors development branch, if it still doesn't behave properly, please post the messages logged by the node, with #MY_DEBUG enabled.
                          12.5k
