  3. [Solved] Does not work after latest update
17 Posts 4 Posters 11.5k Views 3 Watching
  • eBesE
    eBesE
    eBes
    wrote on last edited by eBes
    Hi Tekka!
    Thanks for you reply!
    The sketches I used for the testing in the end was the included ones, which is the esp8266 mqtt gateway and then I tried with the motion sensor sketch, both are from the mysensors library examples.
    The wiring, cap etc. are all identical to how it has always been when it was working with the 2.0.0beta, it's all in place and sturdy, what do you mean by changing/re-seating the radios?
    EDIT: Tried with different radio modules, both usual and the one with antenna for the node etc, but still the same :/
    EDIT2: It worked randomly for like 1 minute but stopped working again, with this ouput from the node:
    TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSF:MSG:READ,0-0-10,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSF:MSG:FPAR RES,ID=0,D=0
    TSF:MSG:FPAR OK,ID=0,D=1
    TSM:FPAR:OK
    TSM:ID
    TSM:ID:OK,ID=10
    TSM:UPL
    TSF:PING:SEND,TO=0
    !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    TSF:CHKUPL:FAIL
    !TSM:UPL:FAIL
    TSM:FPAR```
    tekkaT 1 Reply Last reply
    • eBesE eBes
      Hi Tekka!
      TSM:FPAR:OK
      TSM:ID
      TSM:ID:OK,ID=10
      TSM:UPL
      TSF:PING:SEND,TO=0
      TSF:CHKUPL:FAIL
      !TSM:UPL:FAIL
      TSM:FPAR```
      tekkaT
      tekkaT
      tekka
      @Emil-Besirevic hmm...If it works randomly for a few minutes - this could possibly hint to a power issue. What caps did you connect to the radio modules? Try substituting them for larger ones. 2.0.0 is exchanging more messages during initialisation, and this could cause power instabilities under certain conditions.
      • eBesE
        eBesE
        eBes
        Ok, so you truly rock Tekka!
        I just took entirely new modules, soldered 22uf instead of 10uf caps on them both, just plugged everything in, and it WORKS now!
        I've disconnected it a few times, re-connected, tried back and forth and it communicated and sends everything to Home assistant each time flawlessly, even better than before!
        Super happy guy here! A huge thank you for having patience with me! This new release of mysensors is awesome! :)
        tekkaT JicJ 2 Replies Last reply
        • eBesE eBes
          tekkaT
          tekkaT
          tekka
          @Emil-Besirevic Excellent, have fun 😀
          • eBesE eBes
            JicJ
            JicJ
            Jic
            @Emil-Besirevic I have the same problem, I follow the same steps. I have already soldered a 22uF + 100nF, but I still have the problem.
            Is yours still working? Any other idea?
            eBesE 1 Reply Last reply
            • JicJ Jic
              eBesE
              eBesE
              eBes
              Hi! I have only soldered a 22uF on all, the arduino nano nodes and the esp8266 gate which uses a nrf24l01 antenna version, and it all works great still! Have you tried with different modules?
              JicJ 1 Reply Last reply
              • eBesE eBes
                JicJ
                JicJ
                Jic
                @Emil-Besirevic
                yes, I have tested:
                • with diffetents modules of nrf24l01+,
                • with the NRF24L01+ Socket Adapter Board.
                • with 10uF+100nF capacitor and 22uF+100nF capacitor
                • with diferents Arduino nano, and also with an Arduino One
                And no success, I'm a bit frustrated now. I suppouse that the problem it is with software it's unlikey that all hardware are wrong.
                I don't know if the problem is in Arduino nano + nrf24l01plus or in the rpi gateway connected to the GPIO.
                Somebody know how can I test it?
                • TigroenotT
                  TigroenotT
                  Tigroenot
                  wrote on last edited by Tigroenot
                  Hello everybody!
                  This my first post, but I've been reading for a long while and realy admire the team for the work done :)
                  I have moved to development branch, I have latest MySensors on my gateway (Rpi2 + nrf24l01+plna, caps and reg to solve the power issue), burned the MYSBootloader (8MHz internal) and could upload the binary scetch via serial.
                  Now i have that problem with !TSM:FPAR:NO REPLY on the node side.
                  I can see the FPAR request on the gateway side.
                  653051 TSM:INIT
                  653060 TSM:INIT:TSP OK
                  653062 TSM:FPAR
                  653064 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  655073 !TSM:FPAR:NO REPLY
                  655075 TSM:FPAR
                  655077 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  657088 !TSM:FPAR:NO REPLY
                  657090 TSM:FPAR
                  657092 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  659103 !TSM:FPAR:NO REPLY
                  659105 TSM:FPAR
                  659107 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  661121 !TSM:FPAR:FAIL
                  661123 TSM:FAIL:CNT=7
                  661125 TSM:FAIL:PDT```
                  mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:MSG:FPAR REQ,ID=255
                  mysgw: TSF:PNG:SEND,TO=0
                  mysgw: TSF:CKU:OK
                  mysgw: TSF:MSG:GWL OK
                  mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:CKU:OK,FCTRL
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:MSG:BC
                  Though there is no sign of activity in MYSController (the one included with the MYSBootloader archive)
                  I have tried differen radio modules, different pro minis, modules not jumper wired but soldered with short wires and caps (10, 20, 47 uF). The other 3 nodes are responding (2 x si7021 + motion sensor) but they are on 1.5 version I suppose.
                  EDIT: The interestinf thing is that I tried to update my perfectly working motion sensor and it doesn't work now.
                  TSM:FPAR
                  TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE```
                  • TigroenotT Tigroenot
                    Hello everybody!
                    653051 TSM:INIT
                    653062 TSM:FPAR
                    655075 TSM:FPAR
                    657090 TSM:FPAR
                    659105 TSM:FPAR
                    mysgw: TSF:MSG:BC
                    mysgw: TSF:CKU:OK
                    mysgw: TSF:MSG:BC
                    mysgw: TSF:MSG:BC
                    mysgw: TSF:MSG:BC
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE```
                    JicJ
                    JicJ
                    Jic
                    @Tigroenot I have the same errors until I soldered the nrf24l01 module.
                    Power supply and wired it is very important with this module. I think a have a lot of problems with jumper wires.
                    Be also sure that you are using the last binding
                    https://github.com/tobof/openhab2-addons/blob/MySensors/addons/binding/org.openhab.binding.mysensors/target/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
                    TigroenotT 1 Reply Last reply
                    • JicJ Jic
                      TigroenotT
                      TigroenotT
                      Tigroenot
                      @Jic I have all Nrf24 modules soldered, with caps (tried 20 and 47 uF), I have three versions of Nrf24 modules: from the mysensors shop, smd and plna. On the gateway I have plna, on sensors I have both the others. Those sensors worked fine for almost a year, and stoped after I have updated them to 2.0.0 or development branch. On the gateway side I have latest development version.
                      Maybe all my radio modules are clones that do not work with the versions of mysensors higher than 1.4?
                      And I use domoticz. Maybe I should switch to openhub?
                      • eBesE
                        eBesE
                        eBes
                        I just upgraded all my nodes + gateway to latest dev branch (2.10) and it's working great with home assistant, they communicate without issues. As mentioned earlier my setup is nrf24l01 (with antenna mod) for all nodes (arduino nano) and then the gateway (esp8266) is with a nrf24l01+plna, and they all have a 22uF cap, it's been like 6+ months and it's been working great this far. I ordered all the nrf24l01 from aliexpress.
                        • TigroenotT
                          TigroenotT
                          Tigroenot
                          I will try to move my gateway from raspberry to esp. When I compiled gateway on raspberry it has argued on some parameter in config, I removed the cortex a7 entry and all went fine. Maybe it was the issue.
                            JicJ
                            JicJ
                            Jic
                            @Tigroenot Have you Clean the Eprom before update to mysensors 2.0?
                            https://github.com/mysensors/MySensors/blob/master/examples/ClearEepromConfig/ClearEepromConfig.ino
                            Sometimes it solve me somes issues
                            • JicJ Jic
                              TigroenotT
                              TigroenotT
                              Tigroenot
                              @Jic I sure did, to erase the node id value.
                              • TigroenotT
                                TigroenotT
                                Tigroenot
                                Reporting: I have thrown away the capacitors that I've bought from Ali and replaced them by those bougth here localy (47uF) and everything worked like a charm! So to admit, the promblem IS indeed in the decoupling capacitors! Very happy guy here! :)
