  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
    @toddsantoro see post 2 and 3 in this thread or read the instructions on the build page, just under the "Example" heading.
    toddsantoroT
    toddsantoroT
    toddsantoro
    wrote on last edited by toddsantoro
    @mfalkvidd OK. I have it compiling and uploaded to the nano. My config file looks like this now:
    sensor 6:
      -platform: onewire
        names:
          some_id: outside
          mount_dir: "/mnt/1wire"
    I get an error when I restart HASS on the Pi.
    ERROR (Thread-6) [homeassistant.components.sensor.onewire] No onewire sensor found. Check if dtoverlay=w1-gpio is in your /boot/config.txt. Check the mount_dir parameter if it's defined.
    I guess my question is do I need to define the mount_dir variable and if so is the one I have correct? And if it is correct do I need to create that directory on my Pi?
    I also do not get any output in the Arduino Serial Monitor window. Not sure if I even should...
    Thanks in advance for any help...
    • toddsantoroT toddsantoro
      sensor 6:
        -platform: onewire
          names:
            some_id: outside
      @toddsantoro I am not familiar with homeassistant so I have no clue unfortunately.
      About debug output on the serial monitor: Debug needs to be enabled first. See instructions at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help and https://www.mysensors.org/build/debug
      Debug output is often essential when troubleshooting.
      toddsantoroT 1 Reply Last reply
        toddsantoroT
        toddsantoroT
        toddsantoro
        @mfalkvidd Thank you!!! I get this output in the serial monitor
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:OK (ID=2)
        TSM:FPAR
        TSP:MSG:SEND 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
        TSM:FPAR
        TSP:MSG:READ 0-0-2 s=255,c=3,t=8,pt=1,l=1,sg=0:0
        TSP:MSG:PAR OK (ID=0, dist=1)
        TSM:FPAR:OK
        TSM:ID
        TSM:CHKID:OK (ID=2)
        TSM:UPL
        TSP:PING:SEND (dest=0)
        TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
        TSP:MSG:READ 0-0-2 s=255,c=3,t=25,pt=1,l=1,sg=0:1
        TSP:MSG:PONG RECV (hops=1)
        TSP:CHKUPL:OK
        TSM:UPL:OK
        TSM:READY
        TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
        TSP:MSG:SEND 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
        TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
        TSP:MSG:READ 0-0-2 s=255,c=3,t=6,pt=0,l=1,sg=0:I
        TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=ok:Temperature Sensor
        TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
        Request registration...
        TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
        TSP:MSG:READ 0-0-2 s=255,c=3,t=27,pt=1,l=1,sg=0:1
        Node registration=1
        Init complete, id=2, parent=0, distance=1, registration=1
        Does this look OK? If so I will ask my previous question on the Home Assistant forum. You have been a great help and once I get one of these things down I will be able to help others:)
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR:OK
          TSM:ID
          TSM:CHKID:OK (ID=2)
          TSM:UPL
          TSP:CHKUPL:OK
          TSM:UPL:OK
          TSM:READY
          Node registration=1
          @toddsantoro yes that looks good.
          The "st=ok:xyz" means message xyz was acknowledged by the destination node (in your case by the gateway)
            stingone
            No compile error but i cant see anything on the serial monitor. also the temp sensor burend out with a 4k7 resistor :S
            remisR 1 Reply Last reply
            • S stingone
              remisR
              remisR
              remis
              @stingone
              Hi. The same issue for me . I solve it with : 38400 bauds configuration serial port ( instead of 115200 default value)
              and i lowering the RF power output with low_pa enable: it confirms that I have some issues with power suppply.
              good luck
              • bentrikB
                bentrikB
                bentrik
                wrote on last edited by bentrik
                #22
                It seems the DallasTempereture library is not a part of the default Library setup from Mysensors as of version 2.0? I tried to compile the above code, but I had to manually download DallasTemperature from GitHub first. Then OneWire was also missing. Adding these two libraries brought me a bit further, but I get a long list of errors connected to OneWire. What libraries should be used?
                • bentrikB bentrik
                  @bentrik the library is part of the MySensorsArduinoExamples, which can be downloaded at https://github.com/mysensors/MySensorsArduinoExamples/archive/master.zip
                  bentrikB 1 Reply Last reply
                  • SealanderS
                    SealanderS
                    Sealander
                    wrote on last edited by Sealander
                    #24
                    Hi All, i'm also new here and into this. Like others i also ran into problems compiling this sketch, i tried al libraries mentioned in the posts in this thread, but no go. keep getting this error message:
                    In file included from C:\Users\Gebruiker\Desktop\My Sensors\MySensors-master\MySensorsArduinoExamples-master\examples\DallasTemperatureSensor\DallasTemperatureSensor.ino:37:0:
                    C:\Users\Gebruiker\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h: In function 'void loop()':
                    C:\Users\Gebruiker\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:252:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
                     int16_t millisToWaitForConversion(uint8_t);
                    DallasTemperatureSensor:85: error: within this context
                          exit status 1
                    within this context
                    Can someone help me with this problem? i have no clue at all and woud really like to build me a working sensor so i can hook it up to my Domoticz setup. thanks
                    hin this context
                    S 1 Reply Last reply
                    • SealanderS Sealander
                            exit status 1
                      within this context
                      hin this context
                      stingone
                      @Sealander
                      see solution above. Delete your dallas library and replace with the one above in the master zip file. That was the solution for me.
                        bentrikB
                        bentrikB
                        bentrik
                        #26
                        @mfalkvidd Thanks for the feedback, It got me a bit further.
                        I have a fresh Windows Arduino 1.6.12 install, and I have download the MySensors Library 2.0 through the Library manager, and I've found MySensors.h and MyConfig.h under \Documents\Arduino\libraries\MySensors
                        I'm able to compile and upload the RelayActuator but quite a few of the library files seem to be missing in 2.0. DallasTemperature seem to be one of them.-But I struggled with DallasTemperature and some others.
                        I copied all the whole MySensors-1.5.4.zip library files to to C:\Program Files (x86)\Arduino\libraries, and I managed to compile, but I got an error message saying Invalid version found: 1.04
                        Then I tried to only copy the DallasTemperature and OneWire folder, and I had no errors.
                        -So I assume all library files the entire MySensors Examples catalouge are not ready in Libraries 2.0.
                        Anyways: The solution to get this sensor to work with Arduino 1.6.12, following the Download and API guide, adding MySensors 2.0 through the Library Manager, is to manually add:
                        \Arduino\libraries\OneWire\
                        -from https://github.com/mysensors/MySensorsArduinoExamples/archive/master.zip
                        -And not adding the whole structure.
                        Now I just have to find out how to make it speak to my serial gateway :satisfied:
                        • wendanW
                          wendanW
                          wendan
                          I get the feeling it is possible to use more then one sensor parallel on port 3. I wonder if each sensor is being monitored? Am I right and do I need to alter or change something?
                          • wendanW
                            wendanW
                            wendan
                            my feeling was right.... i just connected 5 temp censors it is working great
                            • J
                              J
                              Joseph Absher
                              wrote on last edited by Joseph Absher
                              #29
                              I am getting the error:
                              DallasTemperatureSensor.ino: In function 'void loop()':
                              DallasTemperatureSensor:93: error: 'getConfig' was not declared in this scope
                                   float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                              Does anyone have any suggestions?
                              • J Joseph Absher
                                @Joseph-Absher https://forum.mysensors.org/topic/5841/getconfig-was-not-declared-in-this-scope-v2-1-1-fixed
                                • J
                                  J
                                  Joseph Absher
                                  @mfalkvidd That worked. Thanks.
                                  • Vincent LgrdV
                                    Vincent LgrdV
                                    Vincent Lgrd
                                    I'm a beginner in home automation and I'm trying MySensor for the first time. My acctual configaration is a Domoticz on a Raspberry Pi 2B and a RFLink GW with a NRF24L01 module to try to measure with a MySensor probe.
                                    I've building a temperature sensor with a DS18B20 sensor on a Official Arduino nano board and I can not run the sensor correctly.
                                    The arduino serial monitor show these:
                                    3 TSM:INIT
                                    4 TSF:WUR:MS=0
                                    11 TSM:INIT:TSP OK
                                    12 TSM:FPAR
                                    15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    2022 !TSM:FPAR:NO REPLY
                                    2024 TSM:FPAR
                                    2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    4034 !TSM:FPAR:NO REPLY
                                    4036 TSM:FPAR
                                    4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    6046 !TSM:FPAR:NO REPLY
                                    6048 TSM:FPAR
                                    6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    8058 !TSM:FPAR:FAIL
                                    8059 TSM:FAIL:CNT=1
                                    8061 TSM:FAIL:PDT
                                    Someone could help me?
                                      Did you set node ID?
                                      • Vincent LgrdV
                                        Vincent LgrdV
                                        Vincent Lgrd
                                        Where should I put it? In arduino sensor code?
                                          Yes, it's like #define MY_NODE_ID 2 and put it at beginning of the code
