  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • A
    Alex B Goode
    Why don't we use an internal pull-up resistor available within an arduino board? Why additional external one?
    pinMode(pin, INPUT); // set pin to input
    digitalWrite(pin, HIGH); // turn on pullup resistors
    • A Alex B Goode
      @Alex-B-Goode the datasheet says "The 1-Wire bus requires an external pullup resistor of approximately 5kΩ"
      The internal pull-up of most Arduinos are 20-50kΩ
      So my guess is that the reason is that the person who created the instructions read the datasheet and chose to follow its recommendation. But accounding to http://electronics.stackexchange.com/a/62096/107155 the exact size might not be important, so it might be possible to use the internal pull up. Try it and let us know if it works.
      • toddsantoroT
        toddsantoroT
        toddsantoro
        Does this example compile for anyone??? I get this error:
        In file included from /Users/Documents/Arduino/tas_temp/tas_temp.ino:37:0:
        /Users/Documents/Arduino/libraries/DallasTemperature/DallasTemperature.h: In function 'void loop()':
        /Users/Documents/Arduino/libraries/DallasTemperature/DallasTemperature.h:252:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
        int16_t millisToWaitForConversion(uint8_t);
        tas_temp:85: error: within this context
        exit status 1
        within this context
        • toddsantoroT toddsantoro
          exit status 1
          within this context
          @toddsantoro see post 2 and 3 in this thread or read the instructions on the build page, just under the "Example" heading.
          mrwombleM toddsantoroT 2 Replies Last reply
            mrwombleM
            mrwombleM
            mrwomble
            ^ What he said 😁
              toddsantoroT
              toddsantoroT
              toddsantoro
              wrote on last edited by toddsantoro
              @mfalkvidd OK. I have it compiling and uploaded to the nano. My config file looks like this now:
              sensor 6:
                -platform: onewire
                  names:
                    some_id: outside
                    mount_dir: "/mnt/1wire"
              I get an error when I restart HASS on the Pi.
              ERROR (Thread-6) [homeassistant.components.sensor.onewire] No onewire sensor found. Check if dtoverlay=w1-gpio is in your /boot/config.txt. Check the mount_dir parameter if it's defined.
              I guess my question is do I need to define the mount_dir variable and if so is the one I have correct? And if it is correct do I need to create that directory on my Pi?
              I also do not get any output in the Arduino Serial Monitor window. Not sure if I even should...
              Thanks in advance for any help...
                sensor 6:
                  -platform: onewire
                    names:
                      some_id: outside
                @toddsantoro I am not familiar with homeassistant so I have no clue unfortunately.
                About debug output on the serial monitor: Debug needs to be enabled first. See instructions at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help and https://www.mysensors.org/build/debug
                Debug output is often essential when troubleshooting.
                toddsantoroT 1 Reply Last reply
                  toddsantoroT
                  toddsantoroT
                  toddsantoro
                  @mfalkvidd Thank you!!! I get this output in the serial monitor
                  TSM:INIT
                  TSM:RADIO:OK
                  TSP:ASSIGNID:OK (ID=2)
                  TSM:FPAR
                  TSP:MSG:SEND 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSM:FPAR
                  TSP:MSG:READ 0-0-2 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  TSP:MSG:PAR OK (ID=0, dist=1)
                  TSM:FPAR:OK
                  TSM:ID
                  TSM:CHKID:OK (ID=2)
                  TSM:UPL
                  TSP:PING:SEND (dest=0)
                  TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                  TSP:MSG:READ 0-0-2 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  TSP:MSG:PONG RECV (hops=1)
                  TSP:CHKUPL:OK
                  TSM:UPL:OK
                  TSM:READY
                  TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                  TSP:MSG:SEND 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                  TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                  TSP:MSG:READ 0-0-2 s=255,c=3,t=6,pt=0,l=1,sg=0:I
                  TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=ok:Temperature Sensor
                  TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
                  Request registration...
                  TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                  TSP:MSG:READ 0-0-2 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  Node registration=1
                  Init complete, id=2, parent=0, distance=1, registration=1
                  Does this look OK? If so I will ask my previous question on the Home Assistant forum. You have been a great help and once I get one of these things down I will be able to help others:)
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:CHKID:OK (ID=2)
                    TSM:UPL
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    Node registration=1
                    @toddsantoro yes that looks good.
                    The "st=ok:xyz" means message xyz was acknowledged by the destination node (in your case by the gateway)
                      stingone
                      No compile error but i cant see anything on the serial monitor. also the temp sensor burend out with a 4k7 resistor :S
                      remisR 1 Reply Last reply
                      • S stingone
                        remisR
                        remisR
                        remis
                        @stingone
                        Hi. The same issue for me . I solve it with : 38400 bauds configuration serial port ( instead of 115200 default value)
                        and i lowering the RF power output with low_pa enable: it confirms that I have some issues with power suppply.
                        good luck
                        • bentrikB
                          bentrikB
                          bentrik
                          wrote on last edited by bentrik
                          #22
                          It seems the DallasTempereture library is not a part of the default Library setup from Mysensors as of version 2.0? I tried to compile the above code, but I had to manually download DallasTemperature from GitHub first. Then OneWire was also missing. Adding these two libraries brought me a bit further, but I get a long list of errors connected to OneWire. What libraries should be used?
                          • bentrikB bentrik
                            @bentrik the library is part of the MySensorsArduinoExamples, which can be downloaded at https://github.com/mysensors/MySensorsArduinoExamples/archive/master.zip
                            bentrikB 1 Reply Last reply
                            • SealanderS
                              SealanderS
                              Sealander
                              wrote on last edited by Sealander
                              #24
                              Hi All, i'm also new here and into this. Like others i also ran into problems compiling this sketch, i tried al libraries mentioned in the posts in this thread, but no go. keep getting this error message:
                              In file included from C:\Users\Gebruiker\Desktop\My Sensors\MySensors-master\MySensorsArduinoExamples-master\examples\DallasTemperatureSensor\DallasTemperatureSensor.ino:37:0:
                              C:\Users\Gebruiker\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h: In function 'void loop()':
                              C:\Users\Gebruiker\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:252:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
                              DallasTemperatureSensor:85: error: within this context
                                    exit status 1
                              within this context
                              Can someone help me with this problem? i have no clue at all and woud really like to build me a working sensor so i can hook it up to my Domoticz setup. thanks
                              hin this context
                              S 1 Reply Last reply
                              • SealanderS Sealander
                                      exit status 1
                                within this context
                                hin this context
                                stingone
                                @Sealander
                                see solution above. Delete your dallas library and replace with the one above in the master zip file. That was the solution for me.
                                  bentrikB
                                  bentrikB
                                  bentrik
                                  #26
                                  @mfalkvidd Thanks for the feedback, It got me a bit further.
                                  I have a fresh Windows Arduino 1.6.12 install, and I have download the MySensors Library 2.0 through the Library manager, and I've found MySensors.h and MyConfig.h under \Documents\Arduino\libraries\MySensors
                                  I'm able to compile and upload the RelayActuator but quite a few of the library files seem to be missing in 2.0. DallasTemperature seem to be one of them.-But I struggled with DallasTemperature and some others.
                                  I copied all the whole MySensors-1.5.4.zip library files to to C:\Program Files (x86)\Arduino\libraries, and I managed to compile, but I got an error message saying Invalid version found: 1.04
                                  Then I tried to only copy the DallasTemperature and OneWire folder, and I had no errors.
                                  -So I assume all library files the entire MySensors Examples catalouge are not ready in Libraries 2.0.
                                  Anyways: The solution to get this sensor to work with Arduino 1.6.12, following the Download and API guide, adding MySensors 2.0 through the Library Manager, is to manually add:
                                  \Arduino\libraries\OneWire\
                                  -from https://github.com/mysensors/MySensorsArduinoExamples/archive/master.zip
                                  -And not adding the whole structure.
                                  Now I just have to find out how to make it speak to my serial gateway :satisfied:
                                  • wendanW
                                    wendanW
                                    wendan
                                    I get the feeling it is possible to use more then one sensor parallel on port 3. I wonder if each sensor is being monitored? Am I right and do I need to alter or change something?
                                    • wendanW
                                      wendanW
                                      wendan
                                      my feeling was right.... i just connected 5 temp censors it is working great
                                      • J
                                        J
                                        Joseph Absher
                                        wrote on last edited by Joseph Absher
                                        #29
                                        I am getting the error:
                                        DallasTemperatureSensor.ino: In function 'void loop()':
                                        DallasTemperatureSensor:93: error: 'getConfig' was not declared in this scope
                                             float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                                        Does anyone have any suggestions?
                                        • J Joseph Absher
                                          @Joseph-Absher https://forum.mysensors.org/topic/5841/getconfig-was-not-declared-in-this-scope-v2-1-1-fixed
