  2. Announcements
  3. 💬 Connecting the Radio
162 Posts 49 Posters 109.3k Views 40 Watching
    @ZsoltZombori what does the serial debug output of the nodes say?
    A Former User
    @mfalkvidd I put the node on serial for the night and everything works fine now. No errors occured, I'm still waiting.
    @palande-vaibhav The GNDs are always connected in my circuits to prevent GND problems. Thanks for the tip.
    palande.vaibhavP 1 Reply Last reply
    • ? A Former User
      palande.vaibhavP
      palande.vaibhavP
      palande.vaibhav
      wrote on last edited by palande.vaibhav
      #36
      @ZsoltZombori
      Exactly that was a problem with my system too. When I had it connected to the computer using the serial cable everything would just run fine but as soon as I removed the serial cable from computer and let it run on its own with the power supply connected with a DC jack, everything would just fall apart the LED's would go dim and that's when I discovered the problem of the ground but you already have all the grounds connected so I'm out of clues here.
      I would suggest you to check the power supply connections again with a multimeter to make sure that everything is connected properly.
      ? 1 Reply Last reply
      • palande.vaibhavP palande.vaibhav
        @ZsoltZombori
        A Former User
        wrote on last edited by [[global:former-user]]
        #37
        @palande.vaibhav I double checked everything and the PCB is perfect. Still waiting for a failure, but it's working now. I'm wondering what was the problem for weeks with the NRFs. The RFMs are working like a charm. Anyway, thank you for the ideas :)
        Edit: there were two fails in ~21hrs, I attach the debug code:
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:OK (ID=3)
        TSM:FPAR
        TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
        TSP:MSG:READ 0-0-3 s=255,c=3,t=8,pt=1,l=1,sg=0:0
        TSP:MSG:PAR OK (ID=0, dist=1)
        TSM:FPAR:OK
        TSM:ID
        TSM:CHKID:OK (ID=3)
        TSM:UPL
        TSP:PING:SEND (dest=0)
        TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
        TSP:MSG:READ 0-0-3 s=255,c=3,t=25,pt=1,l=1,sg=0:1
        TSP:MSG:PONG RECV (hops=1)
        TSP:CHKUPL:OK
        TSM:UPL:OK
        TSM:READY
        TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
        TSP:MSG:SEND 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
        TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
        TSP:MSG:READ 0-0-3 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        TSP:MSG:READ 0-0-3 s=255,c=3,t=6,pt=0,l=1,sg=0:M
        TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=ok:Temperature Sensor
        TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
        TSP:MSG:SEND 3-3-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
        Request registration...
        TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
        TSP:MSG:READ 0-0-3 s=255,c=3,t=27,pt=1,l=1,sg=0:1
        Node registration=1
        Init complete, id=3, parent=0, distance=1, registration=1
        TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.6
        !TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:22.6
        TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=1,st=ok:22.6
        TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.5
        !TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:22.5
        TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=1,st=ok:22.5
        TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.4
        • pepsonP
          pepsonP
          pepson
          How i must change sketch Gateway and node to use radio RFM69HW ? In sketch i see only for simple RFM69 not RFM69HW.
            for using RFM69HW, you just need to use the common rfm69 defines and add this
            #define MY_IS_RFM69HW
            rmtuckerR korttomaK 2 Replies Last reply
            • scalzS scalz
              rmtuckerR
              rmtuckerR
              rmtucker
              @scalz
              Do you add the rfm69hw def to the gateway sketch or to the myconfig.h?
              • scalzS scalz
                korttomaK
                korttomaK
                korttoma
                #41
                @rmtucker
                You add the #define to your sketch
                Hi @scalz ,
                Will a RFM69HW work without the "#define MY_IS_RFM69HW" ?
                What exactly does this #define do for the HW version?
                Have only used RFM69W so far but have ordered some HW now also.
                • Tomas
                  #42
                  to your GW sketch.
                  Also, for using RFM69H you need this define,else the radio can't work properly. This allow us to set the right Radio power level registers in lib.
                  @korttoma just curious :) Have you tried my rfm69 repo?
                  korttomaK 1 Reply Last reply
                  • scalzS scalz
                    to your GW sketch.
                    korttomaK
                    korttomaK
                    korttoma
                    @scalz
                    So does a H version radio work if you do not set the high power registers?
                    @scalz said:
                    @korttoma just curious Have you tried my rfm69 repo?
                    Sorry, I have not yet had the opportunity to test your repo. There is so much non MySensors activities now when Christmas is approaching.
                    • Tomas
                    • pepsonP
                      pepsonP
                      pepson
                      With radio RFM69HW for gateway sketch should looks as:
                      • The MySensors Arduino library handles the wireless radio link and protocol
                      • between your home built sensors/actuators and HA controller of choice.
                      • The sensors forms a self healing radio network with optional repeaters. Each
                      • repeater and gateway builds a routing tables in EEPROM which keeps track of the
                      • network topology allowing messages to be routed to nodes.
                      • Created by Henrik Ekblad henrik.ekblad@mysensors.org
                      • Copyright (C) 2013-2015 Sensnology AB
                      • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
                      • Documentation: http://www.mysensors.org
                      • Support Forum: http://forum.mysensors.org
                      • This program is free software; you can redistribute it and/or
                      • modify it under the terms of the GNU General Public License
                      • version 2 as published by the Free Software Foundation.
                      • DESCRIPTION
                      • The ArduinoGateway prints data received from sensors on the serial link.
                      • The gateway accepts input on seral which will be sent out on radio network.
                      • The GW code is designed for Arduino Nano 328p / 16MHz
                      • Wire connections (OPTIONAL):
                        • Inclusion button should be connected between digital pin 3 and GND
                        • RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
                      • LEDs (OPTIONAL):
                        • To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
                        • RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
                        • TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
                        • ERR (red) - fast blink on error during transmission error or recieve crc error
                      //#define MY_RADIO_NRF24
                      #define MY_RADIO_RFM69
                      // Enable serial gateway
                      #define MY_GATEWAY_SERIAL
                      #if F_CPU == 8000000L
                      #define MY_BAUD_RATE 38400
                      // Enable inclusion mode
                      //#define MY_INCLUSION_MODE_BUTTON_PIN 3
                      // Set blinking period
                      // Flash leds on rx/tx/err
                      //#define MY_DEFAULT_ERR_LED_PIN 4 // Error led pin
                      //#define MY_DEFAULT_RX_LED_PIN 6 // Receive led pin
                      //#define MY_DEFAULT_TX_LED_PIN 5 // the PCB, on board LED
                      sendSketchInfo("MySensors Serial Gateway", "2.0.0");
                        #45
                        @pepson if you're using an Arduino Mini pro or equivalent, and follow the recommanded wiring for the radio (CS and INT), looks ok to me.
                        @korttoma oki. no it won't work if the define is not set for HW version, and vice versa. Because the W and HW use different registers for setting power levels
                        rmtuckerR 1 Reply Last reply
                        • pepsonP
                          pepsonP
                          pepson
                          Now i test it on Arduino nano byt finally i want use it on Arduino Mini Pro. Wirering i use as show on this page.
                            @pepson oki. But you've not explained what's your problem, without logs etc..
                            • pepsonP
                              pepsonP
                              pepson
                              Now any problem. I only need info how write sketch to use radio RFM69HW.
                              G 1 Reply Last reply
                              • scalzS scalz
                                rmtuckerR
                                rmtuckerR
                                rmtucker
                                wrote on last edited by rmtucker
                                #49
                                @scalz
                                Is there an instruction to alter the power level on the RFM69?
                                From inside a mysensors sketch like the NRF24_PA_level?
                                  #50
                                  @rmtucker no not yet (not sure, i need to check). But yes, in the next release ;)
                                  • pepsonP pepson
                                    G
                                    G
                                    gvorster
                                    Try the MockMySensors.ino sketch and enable a few sensors.
                                    • pepsonP
                                      pepsonP
                                      pepson
                                      Good will be add manual how in sketch change level for RFM69HW when new version released. I know that should be released on chrismass
                                        #53
                                        @pepson if you have been kind this year, perhaps :laughing:
                                        • martinsM
                                          martinsM
                                          martins
                                          I'm having trouble with the distance between my 2 RFM69 radios. If I use this tutorial and change the frequency to 433 mhz I get distances of up to 10 meters - https://learn.adafruit.com/adafruit-rfm69hcw-and-rfm96-rfm95-rfm98-lora-packet-padio-breakouts/rfm69-test
                                          However if I use the Mysensor libraries for the SerialGateway and the door sensor I don't even get 1 meter.
                                          I tried to declare these variables as well but no success.
                                          #define RFM69_FREQUENCY RF69_433MHZ
                                          #define IS_RFM69HW
                                          Any suggestions I might try out?
                                          Martin
                                          martinsM 1 Reply Last reply
