  2. Announcements
  3. 💬 Connecting the Radio
162 Posts 49 Posters 110.6k Views 40 Watching
  • pepsonP pepson
    When uusing RFM69HW i must also use Capacitor as for NRF24L01 ?
    korttomaK
    korttomaK
    korttoma
    @pepson
    I do not think that the RFM69HW is as sensitive as the NRF24L01 but adding a Capacitor will not hurt.
    It also depends on how clean your power source is. If the power is clean you do not need to filter it using Capacitor.
    • Tomas
      A Former User
      Hi guys!
      I'd like to ask you about a problem. When I use RFM69 radios on my nodes, they are working fine, but when I try to use the NRFs everything is falling apart and that's driving me crazy. I can't find the solution to use NRFs (I've got 20 of them). I tried everything, read the forum a hundred times, but can't find the solution. Poer sources are perfect, every NRF has it's own 3.3v source and after a few hours or a few days perfect working, the nodes disappear (not all and not in the same time). I'm using Domoticz as controller on a RPI 2. I saw the node's L13 led's blinking is much lighter after the node disappears. When it's working okay, the led is blinking on full.
      Thank you for the suggestions, and have a nice day
      mfalkviddM palande.vaibhavP 2 Replies Last reply
      • ? A Former User
        Hi guys!
        @ZsoltZombori what does the serial debug output of the nodes say?
        ? 1 Reply Last reply
        • ? A Former User
          Hi guys!
          palande.vaibhavP
          palande.vaibhavP
          palande.vaibhav
          @ZsoltZombori
          I had a problem of the LED on pin 13 glowing dim after some time of system running fine when I had 2 sensors connected to the Arduino and sensors had their own separate 5V power supply. So, I had a 5V power supply separate from the Arduino's 5V and that was supplying current to those sensors.
          I had the sensor's data pins connected to Arduino but I didn't have GND of power supply and Arduino connected. I solved the problem by connecting the GND of power supply to the GND of the Arduino.
          See if that is the case with you.
          Hope this helps.
            A Former User
            @mfalkvidd I put the node on serial for the night and everything works fine now. No errors occured, I'm still waiting.
            @palande-vaibhav The GNDs are always connected in my circuits to prevent GND problems. Thanks for the tip.
            palande.vaibhavP 1 Reply Last reply
            • ? A Former User
              palande.vaibhavP
              palande.vaibhavP
              palande.vaibhav
              wrote on last edited by palande.vaibhav
              #36
              @ZsoltZombori
              Exactly that was a problem with my system too. When I had it connected to the computer using the serial cable everything would just run fine but as soon as I removed the serial cable from computer and let it run on its own with the power supply connected with a DC jack, everything would just fall apart the LED's would go dim and that's when I discovered the problem of the ground but you already have all the grounds connected so I'm out of clues here.
              I would suggest you to check the power supply connections again with a multimeter to make sure that everything is connected properly.
              • palande.vaibhavP palande.vaibhav
                @ZsoltZombori
                A Former User
                wrote on last edited by [[global:former-user]]
                #37
                @palande.vaibhav I double checked everything and the PCB is perfect. Still waiting for a failure, but it's working now. I'm wondering what was the problem for weeks with the NRFs. The RFMs are working like a charm. Anyway, thank you for the ideas :)
                Edit: there were two fails in ~21hrs, I attach the debug code:
                TSM:INIT
                TSM:RADIO:OK
                TSP:ASSIGNID:OK (ID=3)
                TSM:FPAR
                TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSP:MSG:READ 0-0-3 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                TSP:MSG:PAR OK (ID=0, dist=1)
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=3)
                TSM:UPL
                TSP:PING:SEND (dest=0)
                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                TSP:MSG:READ 0-0-3 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                TSP:MSG:PONG RECV (hops=1)
                TSP:CHKUPL:OK
                TSM:UPL:OK
                TSM:READY
                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                TSP:MSG:SEND 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                TSP:MSG:READ 0-0-3 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                TSP:MSG:READ 0-0-3 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=ok:Temperature Sensor
                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
                TSP:MSG:SEND 3-3-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                Request registration...
                TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                TSP:MSG:READ 0-0-3 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                Node registration=1
                Init complete, id=3, parent=0, distance=1, registration=1
                TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.6
                !TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:22.6
                TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=1,st=ok:22.6
                TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.5
                !TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:22.5
                TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=1,st=ok:22.5
                TSP:MSG:SEND 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.4
                • pepsonP
                  pepsonP
                  pepson
                  How i must change sketch Gateway and node to use radio RFM69HW ? In sketch i see only for simple RFM69 not RFM69HW.
                    for using RFM69HW, you just need to use the common rfm69 defines and add this
                    #define MY_IS_RFM69HW
                    rmtuckerR korttomaK 2 Replies Last reply
                    • scalzS scalz
                      rmtuckerR
                      rmtuckerR
                      rmtucker
                      @scalz
                      Do you add the rfm69hw def to the gateway sketch or to the myconfig.h?
                      • scalzS scalz
                        korttomaK
                        korttomaK
                        korttoma
                        #41
                        @rmtucker
                        You add the #define to your sketch
                        Hi @scalz ,
                        Will a RFM69HW work without the "#define MY_IS_RFM69HW" ?
                        What exactly does this #define do for the HW version?
                        Have only used RFM69W so far but have ordered some HW now also.
                        • Tomas
                          #42
                          to your GW sketch.
                          Also, for using RFM69H you need this define,else the radio can't work properly. This allow us to set the right Radio power level registers in lib.
                          @korttoma just curious :) Have you tried my rfm69 repo?
                          korttomaK 1 Reply Last reply
                          • scalzS scalz
                            to your GW sketch.
                            korttomaK
                            korttomaK
                            korttoma
                            @scalz
                            So does a H version radio work if you do not set the high power registers?
                            @scalz said:
                            @korttoma just curious Have you tried my rfm69 repo?
                            Sorry, I have not yet had the opportunity to test your repo. There is so much non MySensors activities now when Christmas is approaching.
                            • Tomas
                            • pepsonP
                              pepsonP
                              pepson
                              With radio RFM69HW for gateway sketch should looks as:
                              • The MySensors Arduino library handles the wireless radio link and protocol
                              • between your home built sensors/actuators and HA controller of choice.
                              • The sensors forms a self healing radio network with optional repeaters. Each
                              • repeater and gateway builds a routing tables in EEPROM which keeps track of the
                              • network topology allowing messages to be routed to nodes.
                              • Created by Henrik Ekblad henrik.ekblad@mysensors.org
                              • Copyright (C) 2013-2015 Sensnology AB
                              • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
                              • Documentation: http://www.mysensors.org
                              • Support Forum: http://forum.mysensors.org
                              • This program is free software; you can redistribute it and/or
                              • modify it under the terms of the GNU General Public License
                              • version 2 as published by the Free Software Foundation.
                              • DESCRIPTION
                              • The ArduinoGateway prints data received from sensors on the serial link.
                              • The gateway accepts input on seral which will be sent out on radio network.
                              • The GW code is designed for Arduino Nano 328p / 16MHz
                              • Wire connections (OPTIONAL):
                                • Inclusion button should be connected between digital pin 3 and GND
                                • RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
                              • LEDs (OPTIONAL):
                                • To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
                                • RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
                                • TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
                                • ERR (red) - fast blink on error during transmission error or recieve crc error
                              //#define MY_RADIO_NRF24
                              #define MY_RADIO_RFM69
                              // Enable serial gateway
                              #define MY_GATEWAY_SERIAL
                              #if F_CPU == 8000000L
                              #define MY_BAUD_RATE 38400
                              // Enable inclusion mode
                              //#define MY_INCLUSION_MODE_BUTTON_PIN 3
                              // Set blinking period
                              // Flash leds on rx/tx/err
                              //#define MY_DEFAULT_ERR_LED_PIN 4 // Error led pin
                              //#define MY_DEFAULT_RX_LED_PIN 6 // Receive led pin
                              //#define MY_DEFAULT_TX_LED_PIN 5 // the PCB, on board LED
                              sendSketchInfo("MySensors Serial Gateway", "2.0.0");
                                #45
                                @pepson if you're using an Arduino Mini pro or equivalent, and follow the recommanded wiring for the radio (CS and INT), looks ok to me.
                                @korttoma oki. no it won't work if the define is not set for HW version, and vice versa. Because the W and HW use different registers for setting power levels
                                rmtuckerR 1 Reply Last reply
                                • pepsonP
                                  pepsonP
                                  pepson
                                  Now i test it on Arduino nano byt finally i want use it on Arduino Mini Pro. Wirering i use as show on this page.
                                    @pepson oki. But you've not explained what's your problem, without logs etc..
                                    • pepsonP
                                      pepsonP
                                      pepson
                                      Now any problem. I only need info how write sketch to use radio RFM69HW.
                                      G 1 Reply Last reply
                                      • scalzS scalz
                                        rmtuckerR
                                        rmtuckerR
                                        rmtucker
                                        wrote on last edited by rmtucker
                                        #49
                                        @scalz
                                        Is there an instruction to alter the power level on the RFM69?
                                        From inside a mysensors sketch like the NRF24_PA_level?
                                          #50
                                          @rmtucker no not yet (not sure, i need to check). But yes, in the next release ;)
                                          12.5k
