  3. Chicken house door controller (beta)
1 Posts 1 Posters 1.1k Views 1 Watching
    Matt
    wrote on last edited by Matt
    Hi guys. I have just finished a chickenhouse and am in the throes of automating the door. It will be controlled by domoticz and I plan to open 1/2 hour after sunrise and close 1/2 hour after sunset. The door will be driven by an electric antenna from the car wreckers, 12V battery and solar panel/controller.
    There are two reed switches to tell position of the door plus a button to manually open/close or reset a jam (for increased WAF).
    I have included in the sketch a bit to jiggle the door if it gets stuck, and turn off the actuator and send an alert to domoticz if the jam cannot be freed.
    I have yet to try it out as am waiting on the usual final component I only realised I would need once I started building (buck converter).
    Anyway code is below. mfalkvidd has kindly looked at it for me already. I believe it should work but am open to critiquing on any part of my coding including conventions.
    Matt
     * Chicken door controller
    #define MOTORSW     3  // Motor activation pin
    #define MOTORPWR    4  // Motor power lead pin
    #define REED_OPEN   5  // Reed switch pin, pulled low when door is open
    #define REED_CLOSED 6  // Reed switch pin, pulled low when door is closed
    #define MANUALSW    7  // Momentary switch to control door
    bool DoorState;        // 0 closed, 1 open
    bool PrevState;        // Used to check for stated change
    byte jammed=0;
    unsigned long timer;   // Counter to check door closes in time ie isn't jammed.
    Bounce debouncer = Bounce();
    MyMessage msg(2,V_TRIPPED);
        pinMode(MOTORSW,     OUTPUT);
        pinMode(MOTORPWR,    OUTPUT);
        pinMode(REED_OPEN,   INPUT_PULLUP);   // Using internal pullup. When read switch is closed, will pull this pin to ground.
        pinMode(REED_CLOSED, INPUT_PULLUP);   // Ditto
        pinMode(MANUALSW, INPUT_PULLUP);      // Turn on pullup for switch, will be pulled low when pushed
        DoorState = loadState(1);
        PrevState = DoorState;
        debouncer.attach(MANUALSW);
        debouncer.interval(50);
      sendSketchInfo("ChickenDoor", "1.0");  // Send the sketch version information to the gateway and Controller
      present(1, S_BINARY);  // Register door actuator to Gateway
      present(2, S_DOOR); // This will go on if door is jammed
      debouncer.update();
      int value = debouncer.read();
      if (value == LOW) {
        DoorState = !DoorState;
        jammed==0;   // Reset the jam
        send(msg.set(LOW));
      if ((DoorState != PrevState) && (jammed < 2)) {       //Something has changed and door isn't jammed
        switch(DoorState) {
           case 0: // Close Door
            timer = millis();
            while( digitalRead(REED_CLOSED)==HIGH) {  //Drive actuator until door closes then stop
               digitalWrite(MOTORPWR, HIGH);   //Turn on the actuator
               wait(50);   // Actuator wakes up
               digitalWrite(MOTORSW, HIGH);  //Close the door
               if (millis() - timer > 5000) {   //door is jammed
                jammed++;
                jiggle(); //open and close again
               digitalWrite(MOTORSW, LOW); //Door is closed, turn off actuator switch
               digitalWrite(MOTORPWR, LOW); //Door is closed, turn off actuator
               jammed=0;
           case 1: // Open Door
            timer = millis();
            while( digitalRead(REED_OPEN)==HIGH) {  //Drive actuator until door opens then stop
               digitalWrite(MOTORSW, HIGH); //Wake up the actuator
               wait(100);
               digitalWrite(MOTORSW, LOW); //Close the door
                jammed++;
                jiggle();
               jammed=0;
        else if (jammed >= 2) {
          send(msg.set(HIGH));
      if (message.type==V_STATUS) {                     // We only expect one type of message from controller. But we better check anyway.
         DoorState = message.getBool();
         saveState(1, message.getBool());               // Store state in eeprom
         Serial.print("Incoming change for sensor:");   // Write some debug info
    void jiggle()  //J j j jiggle it a bit (4 times)
    { for(int x = 0; x < 4 ; x++) {
      wait(500);
