  2. Announcements
  3. 💬 Light Level Sensor - LM393
19 Posts 6 Posters 8.8k Views 6 Watching
  • A
    AndreD
    Use the other analog pins (A1 to A7)
    It's clear. I do not know what variables need to assign additional.
      This thread contains comments for the article "Light Level Sensor - LM393" posted on MySensors.org.
      ramoncarranzaR
      ramoncarranzaR
      ramoncarranza
      @hek hi, I've been searching to see if I can find anything on th LM393 Sound sensor, I know I saw one but can't find it, looking to build a simple soundsensor with the LM393 unit.
        @ramoncarranza said:
        LM393
        google on "LM393 datasheet"
        ramoncarranzaR 2 Replies Last reply
          LM393
          ramoncarranzaR
          ramoncarranzaR
          ramoncarranza
          @hek I found this sketch, but how do I incorporate it to my sensors library and serial gateway?
            LM393
            ramoncarranzaR
            ramoncarranzaR
            ramoncarranza
            @hek
            int soundDetectedPin = 10; // Use Pin 10 as our Input
            int soundDetectedVal = HIGH; // This is where we record our Sound Measurement
            boolean bAlarm = false;
            unsigned long lastSoundDetectTime; // Record the time that we measured a sound
            int soundAlarmTime = 500; // Number of milli seconds to keep the sound alarm high
            void setup ()
            Serial.begin(9600);
            pinMode (soundDetectedPin, INPUT) ; // input from the Sound Detection Module
            void loop ()
            soundDetectedVal = digitalRead (soundDetectedPin) ; // read the sound alarm time
            if (soundDetectedVal == LOW) // If we hear a sound
            lastSoundDetectTime = millis(); // record the time of the sound alarm
            // The following is so you don't scroll on the output screen
            if (!bAlarm){
              Serial.println("LOUD, LOUD");
              bAlarm = true;
            if( (millis()-lastSoundDetectTime) > soundAlarmTime && bAlarm){
            Serial.println("quiet");
            bAlarm = false;
              Not sure I understand what you mean by "incorporate".
              Suggerst sending a TRIPPED value 1 when sound is detected for the a SOUND child sensor.
              ramoncarranzaR 1 Reply Last reply
                ramoncarranzaR
                ramoncarranzaR
                ramoncarranza
                @hek what extra code do I need to add to the sketch so tha it sends the tripped value to my gateway?
                  Look at the motion sensor as an example.
                    ramoncarranzaR
                    ramoncarranzaR
                    ramoncarranza
                    @hek will do thanks
                    • pgregg88P
                      pgregg88P
                      pgregg88
                      Hello. I need a sensor that can sense the green status led on an audio amplifier and report state via MQTT. The goal is an accurate source of Power State (ON/OFF) for the audio amp. The light is a fairly dim led. The sensor could mount directly on it. Is the LM393 appropriate for this type of requirement?
                      Here is the problem... Home theater setup. TV and sound app both start at the same time. However, the audio amp has a "feature" where it cuts it's power off if it doesn't sense audio for more than two minutes. As soon as you mute the TV for an advertisement, the audio amp shuts down (while the remote control thinks the audio amps state is ON). Then, everything is out of sync and my wife and kids start calling me names. Bad ones.
                        Oh, what a crappy thing. 2 minutes is nothing. You can't fix this by bypassing the circuitry that shuts the thing down?
                        The only way of knowing is to mount a photo resistor over the led and see if you get any reading when it is on. Use the trimpot to adjust the binary output.
