  3. Need help due wireing Lan - GW RMF69 & W5500
8 Posts 3 Posters 3.2k Views 4 Watching
  • SnobsS Offline
    SnobsS Offline
    Snobs
    wrote on last edited by Snobs
    my name is Sascha and I try to setup an ethnet gateway. My first sensor with DHT22 and an serial GW is working well, but now i need a ethernet gw. But it won`t be working. Did some have a connetion plan and a sketch for those hardware.
    Adrunino Nano
    RFM69CW
    and W5500 Modul.
    I hope some have this and can share/send it to/with me.
    BR from germany
    Sascha
    • S Offline
      I don't know for W5500 (i've only w5100 and i don't use it for the moment but it works, i've tested it )
      Maybe this can help : https://forum.mysensors.org/topic/2901/my-ethernet-gateway-board-w5500
      • SnobsS Offline
        SnobsS Offline
        Snobs
        Thank you for your reply, but this is my problem. There are always howtos for 2,4Ghz devices. How do I connect the w5500 und an rfm69 modul?
        K 1 Reply Last reply
        • SnobsS Snobs
          K Offline
          K Offline
          korttoma
          @Snobs according to @jpaulin in this post the W5500 should be used in the same way as the W5100.
          I actually copied his setup and managed to get it to work. All the info you need should be available in the linked thread.
          • Tomas
          • SnobsS Offline
            SnobsS Offline
            Snobs
            Ok I`ll try following setup :
            RFM69W:
            SCK = 13
            MISO = 12
            MOSI = 11
            CS = 10
            IRQ = 2
            IRQ is which Pin in RFM69 ? Perhaps DI00 ?
            Normaly I use the DI00 and the NSS Pin... but which is which
            W5500:
            SCK = 13
            MISO = 12
            MOSI = 11
            CS = 7
            Is the last question what sketch I use to complie ? The default from mysensors site with the ehternet gw sketch ? only switch from NRF to RFM.
            • SnobsS Snobs
              RFM69W:
              SCK = 13
              MISO = 12
              MOSI = 11
              CS = 10
              IRQ = 2
              W5500:
              SCK = 13
              MISO = 12
              MOSI = 11
              CS = 7
              K Offline
              K Offline
              korttoma
              @Snobs the same thread contains some example sketches but you allso need to modify the w5100.h acording to the instruktions in the thread. How you modify it depends on the pins you use.
              • Tomas
              • SnobsS Offline
                SnobsS Offline
                Snobs
                Thank you fpr ypur Support @korttoma but i cant get it to work. I have tried the W5500 with Ethernet2 Lib und an example. This works, m RFM69 is also working as serial gateway. I`ve tried to change the Ethernet2.h looks like this :
                EthernetClass() { _dhcp = NULL; w5500_cspin = 7; }
                  void init(uint8_t _cspin = 7) { w5500_cspin = _cspin; }
                5;3;0;9;MCO:BGN:INIT OK,TSP=1
                But still not working. I think I'm too stupid :( That makes me sad.
                BR
                Sascha
                • SnobsS Offline
                  SnobsS Offline
                  Snobs
                  Actually I try this and it won`t be working :(
                   * Version 1.0 - Henrik EKblad
                   * LED purposes:
                  //#define MY_RADIO_NRF24
                  #define MY_RADIO_RFM69
                  #define MY_RF69_SPI_CS 3
                  #define MY_GATEWAY_W5100
                  //#define MY_W5100_SPI_EN 4
                  // radio on the same spi bus.
                  #define MY_SOFTSPI
                  #ifndef MY_RF24_CE_PIN
                  #define MY_RF24_CE_PIN 5
                  #ifndef MY_RF24_CS_PIN
                  #define MY_RF24_CS_PIN 6
                  // Enable to UDP
                  //#define MY_USE_UDP
                  #define MY_IP_ADDRESS 192,168,100,254   // If this is disabled, DHCP is used to retrieve address
                  #define MY_PORT 5003
                  // Enable inclusion mode
                  // Set blinking period
                  // Flash leds on rx/tx/err
                  #if defined(MY_USE_UDP)
                  #include <EthernetUdp.h>
                  #include <Ethernet.h>
                  PINs are :
                  NANO  W5100  RFM69
                  GND   GND    GND
                  3.3V         VCC
                  5V    VCC
                  13    SCK    SCK
                  6            NSS
                  12    MISO   MISO
                  11    MOSI   MOSI
                  10    SS/CS
                  and the startup like this
                  0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.0
                  0;255;3;0;9;TSM:INIT
                  0;255;3;0;9;TSF:WUR:MS=0
                  0;255;3;0;9;TSM:INIT:TSP OK
                  0;255;3;0;9;TSM:INIT:GW MODE
                  IP: 192.168.100.254
                  0;255;3;0;9;MCO:BGN:STP
                  0;25
                  Did somebody see my fault ?
                  BR
                  Sascha
                  12.2k
