  3. Could use a bid help to get started
24 Posts 3 Posters 7.5k Views 2 Watching
  • R Rene046
    All those samples seems to work and compile perfect,
    But there is no sample with an DHT sensor temp. and hum included. or do i overlook ?
    @Rene046 in the MySensorsArduinoExamples zip file is examples/DhtTemperatureAndHumiditySensor and libraries/DHT
    You'll need both those folders.
    • R
      R
      Rene046
      should i unzip those inside the mysensor map or arduino ?
      • R Rene046
        @Rene046 I am not sure, but try putting DhtTemperatureAndHumiditySensor in the Arduino sketch folder (My Documents\Arduino on my computer) and DHT in the libraries folder (My Documents\Arduino\libraries on my computer)
        • R
          R
          Rene046
          ok done that, opened the sketch sample for dht.
          compile and i get :
          H:\WINDOW~1\Temp\arduino_modified_sketch_660970\DhtTemperatureAndHumiditySensor.ino: In function 'void presentation()':
          DhtTemperatureAndHumiditySensor:85: error: 'getConfig' was not declared in this scope
          Multiple libraries were found for "DHT.h"
           Used: H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT
           Not used: H:\WINDOWS GEBRUIKERS\MIJN_DOCUMENTEN\Arduino\libraries\DHT-sensor-library-master
          exit status 1
          • R Rene046
            compile and i get :
            exit status 1
            @Rene046 There are two DHT folders. Delete the DHT folder that didn't come from the MySensorsArduinoExamples zip file.
            • R
              R
              Rene046
              ok now im left with this
              H:\WINDOW~1\Temp\arduino_modified_sketch_225110\DhtTemperatureAndHumiditySensor.ino: In function 'void presentation()':
              exit status 1
              • R Rene046
                exit status 1
                @Rene046 see https://forum.mysensors.org/topic/5841/getconfig-was-not-declared-in-this-scope-v2-1-1-fixed/2
                (change getConfig to getControllerConfig)
                • R
                  R
                  Rene046
                  thanks it works... i love you ..lol
                  why do they change basic commands.... this make it hard to use.......
                  Like this command and why make from mysensor.h mysensors.h.
                  i also looked inside domoticz and i got data
                  thank you very very much
                  • R Rene046
                    @Rene046 the change from MySensor to MySensors is because the Arduino IDE requires the .h file to have exactly the same name as the library. That was not the case when MySensors was created, but happened some time in 2015 I think. So to comply with Arduino IDE rules, it had to be changed.
                    The reason for changing getConfig is logged at https://github.com/mysensors/MySensors/issues/736 but I am not sure why and the fix (https://github.com/mysensors/MySensors/pull/737 ) does not explain why either, but seems to be due to a mistake in https://github.com/mysensors/MySensors/commit/92cbd2ac8f49fe2f8cb25726e08aac9ecd597b84
                    • R
                      R
                      Rene046
                      ok,
                      At least i can now experiment with other sensors for my weather station project.
                      i now all electronics are working, i saved this sketch and commented those changes.
                      Again thank you for getting me started.
                      • R Rene046
                        ok,
                        @Rene046 you're welcome. Great that you got it working.
                        • R
                          R
                          Rene046
                          can i ask another question....
                          Im trying to add a battery sense pin to the sketch. they use gw. commands, are those also changed in the new version ?they are not recognized....
                          They serail monitor shows me the voltage but how do i send it as and child to domoticz.
                          • R Rene046
                            @Rene046 most commands were simplified in MySensors 2.0. If the example you found uses gw.send(), remove gw. and just use send().
                            • R
                              R
                              Rene046
                              Thanks Mikael,
                              could i find those new commands somewhere
                              • R Rene046
                                Thanks Mikael,
                                @Rene046 yes they are all documented in the api. https://www.mysensors.org/download/sensor_api_20
