  3. Home Assistant
  4. Struggling with configure.yaml
21 Posts 2 Posters 12.0k Views 2 Watching
  • el tigroE
    el tigroE
    el tigro
    • el tigroE el tigro
      [[topic:post-is-deleted]]
      el tigroE
      el tigroE
      el tigro
      @el-tigro said:
       mysensors:
         gateways:
           - device: mqtt
             persistence_file: 'home/homeassistant/.homeassistant/mysensors4.json'
             topic_in_prefix: 'mygateway1-out'
             topic_out_prefix: 'mygateway1-in'
         debug: true
         optimistic: false
         persistence: true
         retain: true
         version: 2.0
      Good morning from blighty. I retained your format and indentations, I think. Sorry for typo's, it was 1am and a few southern comforts. The hidden .homeassistant folder, was part of install and is where my config file lives, is that not good.
      You are exposing my dumb ass here lol, i thought we just configured the '-device :mqtt'.
      This is from HA website for mysensors but all I can see to configure is the boker IP. I tried it along with the previous code.... same error.
      Where I come from, it's rude not to accept a drink between men and I don't mean a virtual drink. Your service and assistance is invaluable to me and the least I could do is slide you a bottle of Southern Comfort. So stop being humble, stop being rude and email me an paypal addy.
       mqtt:
         broker: IP_ADDRESS_BROKER
         port: 1883
         client_id: home-assistant-1
         keepalive: 60
         username: USERNAME
         password: PASSWORD
         certificate: /home/paulus/dev/addtrustexternalcaroot.crt
         protocol: 3.1
         birth_message:
           topic: 'hass/status'
           payload: 'online'
           qos: 1
           retain: true
         will_message:
           payload: 'offline'
           qos: 1
           retain: true
      looked for a path to certificate...... no idea there. Tried leaving in and without
      my mosquitto mqtt has no username or pw at the moment. Tried leaving in and without.
      Once again I am at your mercy lol
      • martinhjelmareM
        martinhjelmareM
        martinhjelmare
        You are missing a leading slash for the path to the persistence file, ie before home.
        Try a minimal config for the mqtt component:
        mqtt:
        Of course, replace IP_ADDRESS_BROKER with your real mqtt broker ip address.
        Sorry I don't wish to be rude, but I don't want to accept any money. If you want to donate, mysensors.org has a donate with paypal button. This will help keep the site hosting alive etc and support the community.
        el tigroE 1 Reply Last reply
          mqtt:
          el tigroE
          el tigroE
          el tigro
          wrote on last edited by el tigro
          mysensors:
            gateways:
              - device: mqtt
                persistence_file: '/home/homeassistant/.homeassistant/mysensors4.json'
            debug: true
            optimistic: false
            persistence: true
            retain: true
            version: 2.0
          mqtt:
            broker: 192.168.1.115
          is giving the same
          Invalid config
          The following components and platforms could not be set up:
              mysensors
              mqtt
          Please check your config
          To clarify in my head, everything that is connected to HA needs a block in config with minimum set of data but can be finely tuned with further commands if need be.
          If this is the case, how is the gateway identified in the first block of code.
          To make sure I am not mis-reading debug, this is my arduino nano node
          Starting repeater (RNNRA-, 2.0.0)
          TSM:INIT
          TSM:RADIO:OK
          TSP:ASSIGNID:OK (ID=1)
          TSM:FPAR
          TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
          TSP:MSG:PAR OK (ID=0, dist=1)
          TSM:FPAR:OK
          TSM:ID
          TSM:CHKID:OK (ID=1)
          TSM:UPL
          TSP:PING:SEND (dest=0)
          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
          TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
          TSP:MSG:PONG RECV (hops=1)
          TSP:CHKUPL:OK
          TSM:UPL:OK
          TSM:READY
          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
          TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
          TSP:MSG:READ 0-0-1 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:Relay+button
          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
          TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
          Request registration...
          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
          TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
          Node registration=1
          Init complete, id=1, parent=0, distance=1, registration=1
          Sending initial value
          TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
          Requesting initial value from controller
          This is My gateway
          0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGE--,VER=2.1.0
          0;255;3;0;9;TSF:LRT:OK
          0;255;3;0;9;TSM:INIT
          0;255;3;0;9;TSF:WUR:MS=0
          scandone
          no BTHub5-C2FC found, reconnect after 1s
          0;255;3;0;9;TSM:INIT:TSP OK
          0;255;3;0;9;TSM:INIT:GW MODE
          reconnect
          f 0, 0;255;3;0;9;TSM:READY:ID=0,PAR=0,DIS=0
          scandone
          f -180, ....scandone
          reconnect
          f r0, ....scandone
          reconnect
          f 0, .....scandone
          state: 0 -> 2 (b0)
          state: 2 -> 3 (0)
          state: 3 -> 5 (10)
          add 0
          aid 1
          cnt
          .0;255;3;0;9;TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
          0;255;3;0;9;TSF:MSG:BC
          0;255;3;0;9;TSF:MSG:FPAR REQ,ID=1
          0;255;3;0;9;TSF:PNG:SEND,TO=0
          0;255;3;0;9;TSF:CKU:OK
          0;255;3;0;9;TSF:MSG:GWL OK
          connected with BTHub5-C2FC, channel 6
          dhcp client start...
          0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
          ..ip:192.168.1.117,mask:255.255.255.0,gw:192.168.1.254
          .IP: 192.168.1.117
          0;255;3;0;9;MCO:BGN:STP
          IP: 192.168.1.117
          0;255;3;0;9;MQTT connected
          0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
          0;255;3;0;9;TSF:MSG:PINGED,ID=1,HP=1
          0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
          0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          0;255;3;0;9;TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=0,t=18,pt=0,l=5,sg=0:2.0.0
          0;255;3;0;9;Sending message on topic: mygateway1-out/1/255/0/0/18
          0;255;3;0;9;TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
          0;255;3;0;9;Sending message on topic: mygateway1-out/1/255/3/0/6
          And here is broker
          login as: pi
          pi@192.168.1.115's password:
          The programs included with the Debian GNU/Linux system are free software;
          the exact distribution terms for each program are described in the
          individual files in /usr/share/doc/*/copyright.
          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
          permitted by applicable law.
          Last login: Thu Jan 19 22:04:56 2017
          pi@raspberrypi:~ $ mosquitto -v
          1484863517: mosquitto version 1.3.4 (build date 2014-08-22 06:10:51+0000) starting
          1484863517: Using default config.
          1484863517: Opening ipv4 listen socket on port 1883.
          1484863517: Opening ipv6 listen socket on port 1883.
          1484863518: New connection from 192.168.1.117 on port 1883.
          1484863518: New client connected from 192.168.1.117 as mysensors-1 (c1, k15).
          1484863518: Sending CONNACK to mysensors-1 (0)
          1484863518: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/0/255/0/0/18', ... (5 bytes))
          1484863518: Received SUBSCRIBE from mysensors-1
          1484863518:     mygateway1-in/+/+/+/+/+ (QoS 0)
          1484863518: mysensors-1 0 mygateway1-in/+/+/+/+/+
          1484863518: Sending SUBACK to mysensors-1
          1484863518: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
          1484863519: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
          1484863520: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
          1484863520: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
          1484863522: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
          1484863522: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
          1484863524: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
          1484863524: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
          1484863526: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
          1484863526: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
          1484863528: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
          1484863528: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
          1484863530: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
          1484863530: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
          1484863532: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/1/0/2', ... (1 bytes))
          1484863532: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/1/1/2/0/2', ... (0 bytes))
          1484863534: Received PINGREQ from mysensors-1
          1484863534: Sending PINGRESP to mysensors-1
          It won't matter that my broker and HA are on the smae pi will it.
          Your a rare breed fella, don't let the wifey know ya refusing $$ lol. Will make a donation.... if ya sort me out.
          • el tigroE
            el tigroE
            el tigro
            Should my gate gateway sketch have presentation details in it, coz it doesn't. I removed comments to reduce size.
             * The ESP8266 MQTT
            #include <EEPROM.h>
            #define MY_BAUD_RATE 9600
            #define MY_GATEWAY_ESP8266
            #define MY_ESP8266_SSID "BTHub5-C2FC"
            #define MY_ESP8266_PASSWORD "xxxxxxxxx"
             #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway" ///
            #define MY_CONTROLLER_IP_ADDRESS 192,168,1,115
            #define MY_PORT 1883
            // Flash leds on rx/tx/err
            // Set blinking period
            // Enable inclusion mode
            #include <ESP8266WiFi.h>
            • martinhjelmareM
              martinhjelmareM
              martinhjelmare
              Since your mqtt broker and home assistant is on the same host, you should use localhost or "127.0.0.1" as broker address when setting up the mqtt component in home assistant. Home assistant and mosquitto (MQTT) use different ports so there shouldn't be a conflict.
              mqtt:
                broker: localhost
              The gateway is identified by home assistant via the prefix topics, in the case of the mqtt gateway.
              Arduino + ESP sketches and logs look ok.
              • el tigroE
                el tigroE
                el tigro
                Same same, no different i'm affraid. It's pissing me off now, more because I don't understand enough to do more for myself. I think this is going to be shelved for a while.
                I am talking about the wifi gateway,
                I am gonna stick with HA and mysensors but rehash my hardware. I have PI's , Nano's, Yun, Mini's and ESP8266's. What combination / configuration would you recommend for ease of setup.
                Gonna try running mosquiito on a seperate Pi to HA first off.
                • martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  Do you get any other errors in the log? It would be interesting to see a log after start of home assistant.
                  An RPi for controller, a Nano as serial gateway and Pro Minis as sensors, I'd say should be the most easy and "mainstream".
                  But easy is a relative term. Remember that we're building our own wireless IoT devices and home automation setup. Most people might not call that easy at all. Although I think mysensors lowers the difficulty bar considerably in this context.
                    el tigroE
                    el tigroE
                    el tigro
                    Hi again.
                    here is my home-assistant.log
                    fingers double crossed
                    pi@raspberrypi:/home/homeassistant/.homeassistant $ less home-assistant.log
                    17-01-23 19:36:57 homeassistant.components.mqtt: Can't connect to the broker. Please check your settings and the broker itself
                      File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/mqtt/__init__.py", line 262, in setup
                        birth_message)
                      File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/mqtt/__init__.py", line 351, in __init__
                        self._mqttc.connect(broker, port, keepalive)
                      File "/home/homeassistant/.homeassistant/deps/paho/mqtt/client.py", line 686, in connect
                        return self.reconnect()
                      File "/home/homeassistant/.homeassistant/deps/paho/mqtt/client.py", line 808, in reconnect
                        sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0))
                      File "/usr/lib/python3.4/socket.py", line 509, in create_connection
                        raise err
                      File "/usr/lib/python3.4/socket.py", line 500, in create_connection
                        sock.connect(sa)
                    ConnectionRefusedError: [Errno 111] Connection refused
                    17-01-23 19:36:57 homeassistant.bootstrap: component mqtt failed to initialize
                    17-01-23 19:36:57 homeassistant.bootstrap: Component mqtt failed to setup
                    17-01-23 19:36:57 homeassistant.components.mysensors: No devices could be setup as gateways, check your configuration
                    17-01-23 19:36:57 homeassistant.bootstrap: component mysensors failed to initialize
                        birth_message)
                        raise err
                        sock.connect(sa)
                    • el tigroE
                      el tigroE
                      el tigro
                      OK. we are in, no errors in HA but have this in HA log.
                      17-01-23 22:19:55 mysensors.mysensors: File does not exist or is not readable: /home/homeassistant/mysensors4.json
                      17-01-23 22:19:55 mysensors.mysensors: Trying backup file: /home/homeassistant/mysensors4.json.bak
                      17-01-23 22:19:55 mysensors.mysensors: File does not exist or is not readable: /home/homeassistant/mysensors4.json.bak
                      17-01-23 22:19:55 mysensors.mysensors: Failed to load sensors from file: /home/homeassistant/mysensors4.json
                      I have tried a few file path but always the same.
                      • el tigroE
                        el tigroE
                        el tigro
                        #21
                        Well, the sun shines on a dogs arse some days.
                        We've only gone and done it, HA dash with relay sw. can controll led from dash. I honestly have sticky stuff running down my leg. You have no idea how happy I am.
                        For future reference.
                        I was flicking the power to reset pi in between config changes. My mosquitto was not starting from boot, so nothing to connect to, hence the errors when the code was right.
                        Also reset your nodes after a change.
                        This my yaml for the following setup
                        nodes are arduino nanos with nrf2401+ radio. (mysensors 2.0)
                        gateway is esp8266 NodeMCU 1.09. Wifi with NRF2401+
                        Pi 3 hosts Home Assistant and Mosquitto broker. Installed with All in one image.
                        mysensors:
                          gateways:
                            - device: mqtt
                              persistence_file: '/home/homeassistant/mysensors4.json'
                          debug: true
                          optimistic: false
                          persistence: true
                          retain: true
                          version: 2.0
                        mqtt:
                          broker: localhost
                          port: 1883
                          keepalive: 60
                        Righty. I'm off to play. Be back very soon when i get stuck.
                        Cheers for now fella, thank you for all your help.
