  2. Announcements
    macvictor
    Hi :) Does anybody know how to use MY_SIGNING_NODE_WHITELISTING in gateway raspbery pi? Where I must create/edit white list with my nodes?
    • OliverDogO
      OliverDogO
      OliverDog
      first sorry about the basics question but I think many people have the same questions and can't find the answers:
      After connecting the radio (including IRQ on 15pin) and the info LEDs to the GPIO, how to config it?
      1. Do I need to configure all the info on the same command, or can I send the command "./configure --" many times for different configs?
      2. Do I need to configure it as a MQTT gateway?
      3. Where did the 127.0.0.1 IP come from?
      4. Does MQTT use internet connection?
      5. Why do you talk about Serial Gateway here, once we have a specific type for it? this type is about using GPIO only, isn't it? That is confusing!!!
      • OliverDogO
        OliverDogO
        OliverDog
        trying to config on a Home Assistant Rpi.
        Sorry again for the newbie questions...!!!
        • Erik TammingaE
          Erik TammingaE
          Erik Tamminga
          Can I use pin 18 (GPIO 24) on my RPi3 for IRQ usage? Should I?
          If I compile with --my-rf24-irq-pin=18, no date is received when the gateway starts.
          I Cannot use pin 15 because that pin is covered by my Z-wave.me board.
          Regards,
          Erik
          • Roberto Mo CaR Roberto Mo Ca
            what means "5VReg -> 3.3V" in raspberry? can connect directly to 3.3V or if requied connecto to 5V with regulator to obtain 3.3v?
            marceloaqno
            Code Contributor
            S 1 Reply Last reply
            • M macvictor
              marceloaqno
              Code Contributor
              wrote on last edited by marceloaqno
              #338
              @macvictor For the MY_SIGNING_NODE_WHITELISTING, you can uncomment and edit it in MyConfig.h or add it to the examples/mysgw.cpp.
              • OliverDogO OliverDog
                marceloaqno
                Code Contributor
                @OliverDog
                You execute ./configure once with all your options to set your gateway.
                You need to decide what type of gateway you want to build: ethernet, serial or mqtt:
                https://www.mysensors.org/build/select_gateway
                Take a look at the link and let me know if you still have any questions.
                • OliverDogO
                  OliverDogO
                  OliverDog
                  thaks @marceloaqno but I was wondering there was a new type of gateway named Raspberry Gateway, were we could connect the radio directly on the GPIO and config it locally, without internet, because of that I also would like to know if MQTT uses internet connection.
                  I actually use a serial gateway connected to Pi USG and it works without internet...
                  I just want to have only one device...
                    marceloaqno
                    Code Contributor
                    @OliverDog You can configure the RPi to be any of the 3 types: ethernet, serial or mqtt, with the nrf24 attached to it.
                    OliverDogO 1 Reply Last reply
                    • M marceloaqno
                      OliverDogO
                      OliverDogO
                      OliverDog
                      @marceloaqno WOWWW
                      now I understood... but I think this is not clear on the build steps...
                      I choose a Serial Gateway, but on that lines, they say:
                      "If for some reason you can't use the GPIO pins of the Raspberry Pi, you could connect the radio to a arduino with the GatewaySerial sketch and feed the pi through a serial port:"
                      So I assumed the serial gateway is the same I already use...
                      So, where do I get directions to config a serial gateway with the radio attached to the GPIO?
                        @marceloaqno WOWWW
                        marceloaqno
                        Code Contributor
                        @OliverDog Which controller are you using(or are planning to use)?
                        • Erik TammingaE Erik Tamminga
                          Regards,
                          Erik
                          marceloaqno
                          Code Contributor
                          @Erik-Tamminga Some pins may have some restrictions, I couldn't find any good info about that. Try using another pin (GPIO 25).
                          • M marceloaqno
                            OliverDogO
                            OliverDogO
                            OliverDog
                            @marceloaqno I already use Home Assistant with a Serial Gateway connected on pi USB.
                              marceloaqno
                              Code Contributor
                              @OliverDog Home Assistant supports ethernet gateways, I recommend you go with that.
                              ./configure --my-gateway=ethernet --my-transport=nrf24
                              (The default settings is to use ethernet and nrf24, so you could omit them)
                              and add to it any of your custom options.
                              • MadhiasM
                                MadhiasM
                                Madhias
                                wrote on last edited by Madhias
                                #347
                                I have a question regarding the --my-serial-groupname option: since I start the gateway under an user account with sudo, the gateway device ([EDIT] symlink) will be created with ownership root:root. Shouldn't it be created with root:dialout (as I chose dialout as group in my case)?
                                [DELETED]
                                • MadhiasM Madhias
                                  [DELETED]
                                  marceloaqno
                                  Code Contributor
                                  @Madhias /dev/pts/2 it's the one who holds the specified group ownership
                                  MadhiasM 1 Reply Last reply
                                  • M marceloaqno
                                    MadhiasM
                                    MadhiasM
                                    Madhias
                                    @marceloaqno OK, many thanks for that hint!
                                    I was wrong from the beginning on, since I thought my configuration for the gateway was correct because of --my-serial-groupname=dialout - but that was not compiled. I edited now the mysgw.cpp manually (there was tty instead of dialout; and of course there was all the time the warning when compiling...). Now it works! Without chmod, or chowning anything later!
                                      macvictor
                                      @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
                                      Gateway:
                                      2. make
                                      3. sudo make install
                                      10. sudo mysgw --gen-aes-key
                                      Node:
                                      #define USE_SOFT_SIGNING
                                      #define STORE_SOFT_KEY
                                      #define USER_SOFT_KEY
                                      #define STORE_SOFT_SERIAL
                                      #define STORE_AES_KEY
                                      #define USER_AES_KEY
                                      EEPROM configuration:
                                      // Enable NRF24L01 radio type
                                      // Select soft signing
                                      #define MY_SIGNING_SOFT
                                      // Enable node whitelisting
                                      #define MY_REPEATER_FEATURE
                                      #define BUTTON_PIN  3   // Arduino Digital I/O pin number for button
                                      #define CHILD_ID 1      // Id of the sensor child
                                      #define RELAY_ON 1
                                      #define RELAY_OFF 0
                                      Bounce debouncer = Bounce();
                                      int oldValue = 0;
                                      bool state;
                                        // Setup the button
                                        pinMode(BUTTON_PIN, INPUT);
                                        // Activate internal pull-up
                                        debouncer.attach(BUTTON_PIN);
                                        debouncer.interval(5);
                                        pinMode(RELAY_PIN, OUTPUT);
                                        state = loadState(CHILD_ID);
                                        digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
                                      void presentation()  {
                                        debouncer.update();
                                        // Get the update value
                                        int value = debouncer.read();
                                      //  oldValue = value;
                                        delay(5000);
                                        if (message.isAck()) {
                                          // Change relay state
                                          state = message.getBool();
                                          // Store state in eeprom
                                      4 TSM:INIT
                                      5 TSF:WUR:MS=0
                                      11 TSM:INIT:TSP OK
                                      13 TSF:SID:OK,ID=105
                                      15 TSM:FPAR
                                      2065 !TSM:FPAR:NO REPLY
                                      2067 TSM:FPAR
                                      4117 !TSM:FPAR:NO REPLY
                                      4119 TSM:FPAR
                                      6169 !TSM:FPAR:NO REPLY
                                      6171 TSM:FPAR
                                      8221 !TSM:FPAR:FAIL
                                      8222 TSM:FAIL:CNT=1
                                      8224 TSM:FAIL:PDT
                                      and in gateway i see:
                                      sudo mysgw -d
                                      mysgw: Starting gateway...
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: TSM:INIT:TSP OK
                                      mysgw: TSM:INIT:GW MODE
                                      mysgw: MCO:REG:NOT NEEDED
                                      mysgw: MCO:BGN:STP
                                      mysgw: MCO:BGN:INIT OK,TSP=1
                                      mysgw: connected to 127.0.0.1
                                      mysgw: MQTT connected
                                      mysgw: !TSF:MSG:PVER,3=2
                                      mysgw: !TSF:MSG:PVER,1=2
                                      mysgw: TSF:MSG:REL MSG
                                      mysgw: !TSF:RTE:240 UNKNOWN
                                      mysgw: !TSF:MSG:PVER,0=2
                                      mysgw: !TSF:RTE:233 UNKNOWN
                                      mysgw: !TSF:RTE:51 UNKNOWN
                                      Where is problem?
                                      M pepsonP rajeev2301R 5 Replies Last reply
                                      • M macvictor
                                        Gateway:
                                        2. make
                                        Node:
                                        #define RELAY_ON 1
                                        #define RELAY_OFF 0
                                        int oldValue = 0;
                                        bool state;
                                          // Setup the button
                                          debouncer.update();
                                          delay(5000);
                                        4 TSM:INIT
                                        5 TSF:WUR:MS=0
                                        11 TSM:INIT:TSP OK
                                        15 TSM:FPAR
                                        2067 TSM:FPAR
                                        4119 TSM:FPAR
                                        6171 TSM:FPAR
                                        8221 !TSM:FPAR:FAIL
                                        8222 TSM:FAIL:CNT=1
                                        8224 TSM:FAIL:PDT
                                        sudo mysgw -d
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: MCO:BGN:STP
                                        Where is problem?
                                        marceloaqno
                                        Code Contributor
                                        @macvictor Did you also enable encryption on your node? (#define MY_RF24_ENABLE_ENCRYPTION)
                                          macvictor
                                          @marceloaqno Thanks for help :+1: This was my problem 😀
