  2. Announcements
  • Roberto Mo CaR
    Roberto Mo CaR
    Roberto Mo Ca
    what means "5VReg -> 3.3V" in raspberry? can connect directly to 3.3V or if requied connecto to 5V with regulator to obtain 3.3v?
      macvictor
      Hi :) Does anybody know how to use MY_SIGNING_NODE_WHITELISTING in gateway raspbery pi? Where I must create/edit white list with my nodes?
      • OliverDogO
        OliverDogO
        OliverDog
        first sorry about the basics question but I think many people have the same questions and can't find the answers:
        After connecting the radio (including IRQ on 15pin) and the info LEDs to the GPIO, how to config it?
        1. Do I need to configure all the info on the same command, or can I send the command "./configure --" many times for different configs?
        2. Do I need to configure it as a MQTT gateway?
        3. Where did the 127.0.0.1 IP come from?
        4. Does MQTT use internet connection?
        5. Why do you talk about Serial Gateway here, once we have a specific type for it? this type is about using GPIO only, isn't it? That is confusing!!!
        • OliverDogO
          OliverDogO
          OliverDog
          trying to config on a Home Assistant Rpi.
          Sorry again for the newbie questions...!!!
          • Erik TammingaE
            Erik TammingaE
            Erik Tamminga
            Can I use pin 18 (GPIO 24) on my RPi3 for IRQ usage? Should I?
            If I compile with --my-rf24-irq-pin=18, no date is received when the gateway starts.
            I Cannot use pin 15 because that pin is covered by my Z-wave.me board.
            Regards,
            Erik
            • Roberto Mo CaR Roberto Mo Ca
              marceloaqno
              Code Contributor
              S 1 Reply Last reply
              • M macvictor
                marceloaqno
                Code Contributor
                wrote on last edited by marceloaqno
                #338
                @macvictor For the MY_SIGNING_NODE_WHITELISTING, you can uncomment and edit it in MyConfig.h or add it to the examples/mysgw.cpp.
                • OliverDogO OliverDog
                  marceloaqno
                  Code Contributor
                  @OliverDog
                  You execute ./configure once with all your options to set your gateway.
                  You need to decide what type of gateway you want to build: ethernet, serial or mqtt:
                  https://www.mysensors.org/build/select_gateway
                  Take a look at the link and let me know if you still have any questions.
                  • OliverDogO
                    OliverDogO
                    OliverDog
                    thaks @marceloaqno but I was wondering there was a new type of gateway named Raspberry Gateway, were we could connect the radio directly on the GPIO and config it locally, without internet, because of that I also would like to know if MQTT uses internet connection.
                    I actually use a serial gateway connected to Pi USG and it works without internet...
                    I just want to have only one device...
                      marceloaqno
                      Code Contributor
                      @OliverDog You can configure the RPi to be any of the 3 types: ethernet, serial or mqtt, with the nrf24 attached to it.
                      OliverDogO 1 Reply Last reply
                      • M marceloaqno
                        OliverDogO
                        OliverDogO
                        OliverDog
                        @marceloaqno WOWWW
                        now I understood... but I think this is not clear on the build steps...
                        I choose a Serial Gateway, but on that lines, they say:
                        "If for some reason you can't use the GPIO pins of the Raspberry Pi, you could connect the radio to a arduino with the GatewaySerial sketch and feed the pi through a serial port:"
                        So I assumed the serial gateway is the same I already use...
                        So, where do I get directions to config a serial gateway with the radio attached to the GPIO?
                          @marceloaqno WOWWW
                          marceloaqno
                          Code Contributor
                          @OliverDog Which controller are you using(or are planning to use)?
                          • Erik TammingaE Erik Tamminga
                            Regards,
                            Erik
                            marceloaqno
                            Code Contributor
                            @Erik-Tamminga Some pins may have some restrictions, I couldn't find any good info about that. Try using another pin (GPIO 25).
                            • M marceloaqno
                              OliverDogO
                              OliverDogO
                              OliverDog
                              @marceloaqno I already use Home Assistant with a Serial Gateway connected on pi USB.
                                marceloaqno
                                Code Contributor
                                @OliverDog Home Assistant supports ethernet gateways, I recommend you go with that.
                                ./configure --my-gateway=ethernet --my-transport=nrf24
                                (The default settings is to use ethernet and nrf24, so you could omit them)
                                and add to it any of your custom options.
                                • MadhiasM
                                  MadhiasM
                                  Madhias
                                  wrote on last edited by Madhias
                                  #347
                                  I have a question regarding the --my-serial-groupname option: since I start the gateway under an user account with sudo, the gateway device ([EDIT] symlink) will be created with ownership root:root. Shouldn't it be created with root:dialout (as I chose dialout as group in my case)?
                                  [DELETED]
                                  • MadhiasM Madhias
                                    [DELETED]
                                    marceloaqno
                                    Code Contributor
                                    @Madhias /dev/pts/2 it's the one who holds the specified group ownership
                                    MadhiasM 1 Reply Last reply
                                    • M marceloaqno
                                      MadhiasM
                                      MadhiasM
                                      Madhias
                                      @marceloaqno OK, many thanks for that hint!
                                      I was wrong from the beginning on, since I thought my configuration for the gateway was correct because of --my-serial-groupname=dialout - but that was not compiled. I edited now the mysgw.cpp manually (there was tty instead of dialout; and of course there was all the time the warning when compiling...). Now it works! Without chmod, or chowning anything later!
                                        macvictor
                                        @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
                                        Gateway:
                                        2. make
                                        3. sudo make install
                                        10. sudo mysgw --gen-aes-key
                                        Node:
                                        #define USE_SOFT_SIGNING
                                        #define STORE_SOFT_KEY
                                        #define USER_SOFT_KEY
                                        #define STORE_SOFT_SERIAL
                                        #define STORE_AES_KEY
                                        #define USER_AES_KEY
                                        EEPROM configuration:
                                        // Enable NRF24L01 radio type
                                        // Select soft signing
                                        #define MY_SIGNING_SOFT
                                        // Enable node whitelisting
                                        #define MY_REPEATER_FEATURE
                                        #define BUTTON_PIN  3   // Arduino Digital I/O pin number for button
                                        #define CHILD_ID 1      // Id of the sensor child
                                        #define RELAY_ON 1
                                        #define RELAY_OFF 0
                                        Bounce debouncer = Bounce();
                                        int oldValue = 0;
                                        bool state;
                                          // Setup the button
                                          pinMode(BUTTON_PIN, INPUT);
                                          // Activate internal pull-up
                                          debouncer.attach(BUTTON_PIN);
                                          debouncer.interval(5);
                                          pinMode(RELAY_PIN, OUTPUT);
                                          state = loadState(CHILD_ID);
                                          digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
                                        void presentation()  {
                                          debouncer.update();
                                          // Get the update value
                                          int value = debouncer.read();
                                        //  oldValue = value;
                                          delay(5000);
                                          if (message.isAck()) {
                                            // Change relay state
                                            state = message.getBool();
                                            // Store state in eeprom
                                        4 TSM:INIT
                                        5 TSF:WUR:MS=0
                                        11 TSM:INIT:TSP OK
                                        13 TSF:SID:OK,ID=105
                                        15 TSM:FPAR
                                        2065 !TSM:FPAR:NO REPLY
                                        2067 TSM:FPAR
                                        4117 !TSM:FPAR:NO REPLY
                                        4119 TSM:FPAR
                                        6169 !TSM:FPAR:NO REPLY
                                        6171 TSM:FPAR
                                        8221 !TSM:FPAR:FAIL
                                        8222 TSM:FAIL:CNT=1
                                        8224 TSM:FAIL:PDT
                                        and in gateway i see:
                                        sudo mysgw -d
                                        mysgw: Starting gateway...
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: TSM:INIT:TSP OK
                                        mysgw: TSM:INIT:GW MODE
                                        mysgw: MCO:REG:NOT NEEDED
                                        mysgw: MCO:BGN:STP
                                        mysgw: MCO:BGN:INIT OK,TSP=1
                                        mysgw: connected to 127.0.0.1
                                        mysgw: MQTT connected
                                        mysgw: !TSF:MSG:PVER,3=2
                                        mysgw: !TSF:MSG:PVER,1=2
                                        mysgw: TSF:MSG:REL MSG
                                        mysgw: !TSF:RTE:240 UNKNOWN
                                        mysgw: !TSF:MSG:PVER,0=2
                                        mysgw: !TSF:RTE:233 UNKNOWN
                                        mysgw: !TSF:RTE:51 UNKNOWN
                                        Where is problem?
                                        M pepsonP rajeev2301R 5 Replies Last reply
                                        • M macvictor
                                          Gateway:
                                          2. make
                                          Node:
                                          #define RELAY_ON 1
                                          #define RELAY_OFF 0
                                          int oldValue = 0;
                                          bool state;
                                            // Setup the button
                                            debouncer.update();
                                            delay(5000);
                                          4 TSM:INIT
                                          5 TSF:WUR:MS=0
                                          11 TSM:INIT:TSP OK
                                          15 TSM:FPAR
                                          2067 TSM:FPAR
                                          4119 TSM:FPAR
                                          6171 TSM:FPAR
                                          8221 !TSM:FPAR:FAIL
                                          8222 TSM:FAIL:CNT=1
                                          8224 TSM:FAIL:PDT
                                          sudo mysgw -d
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: MCO:BGN:STP
                                          Where is problem?
                                          marceloaqno
                                          Code Contributor
                                          @macvictor Did you also enable encryption on your node? (#define MY_RF24_ENABLE_ENCRYPTION)
